查看: 2005|回复: 0
[NI软件套件] NI Test Workflow 2022 Q3 Standard Win11 32bitEng NI测试工作流程22.5标准版-32位英文
    前天 16:03
     楼主| 发表于 2022-8-12 15:52:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    测试工作流程是NI推荐的软件集合,适用于研究、验证和生产测试应用程序的工程师。
    测试工作流程为工程师提供了针对特定应用的工具,从图形化编程环境到无代码和交互式软件应用程序,从而为其选择合适的工具。工程师可以使用测试工作流软件来执行快速特定测试、构建自动化测试系统、自动化数据分析和报告、开发测试序列等。
    标准版包含:
    应用程序软件
    LabVIEW完整版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem高级版
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版/标准版 版本号22.3.0
    应用程序位数:32位
    文件大小: 2914533376 字节 (2.71 GB)
    修改日期: 2022-08-01 17:36
    MD5: 13468844eeb23561b7dba6a03aced24b
    SHA1: a48aa5b4aa0ee96b7f76b078de2d8e8b3a0785a7
    SHA256: a2869d4500a30b832a7e6f6ed9f325bec3dbb50fa07152287c695bdc19e498b8
    SHA512: ab0f8a48f0e22800e1440b7b40eb2d7229137c9752a3b53002f71c35d5ca0848fe07e2d75baf941d62f52b3ee4b895edd4233a4c5d15a029b3e56a24c16b8ff0
    注册登录视觉论坛,购买附件查看下载地址
    TestWorkflow2022Q3标准版32位Eng.txt (760 Bytes, 下载次数: 0, 售价: 20 圆)
    Test Workflow Standard 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for Test Workflow Standard 2022 Q3.
    • Test Workflow Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Test Workflow Standard Bundle
    Test Workflow is a bundle of select NI software featuring engineering-specific tools that help test professionals accomplish anything from their day-to-day work to overcoming their most challenging obstacles.
    Test Workflow Standard 2022 Q3 supports the following operating systems:
    Note Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Test Workflow Standard 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Test Workflow Standard 2022 Q3 to an unsupported OS. Additionally, after installing Test Workflow Standard 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following products are included in the Test Workflow Standard installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    DIAdem2022 Q264-bit
    G Web Development Software2022 Q364-bit
    LabVIEW2022 Q332-bit and 64-bit
    FlexLogger12022 Q264-bit
    InstrumentStudio2022 Q364-bit
    1 Product does not support LabVIEW 2022 Q3.
    If you are using the Test Workflow .NET Class Library, .NET Framework 4.0 (minimum) is required. The Test Workflow Standard 2022 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Test Workflow installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow. For more information on Test Workflow activation, refer to Activating a Product.
    Test Workflow no longer installs IVI Compliance Package (ICP). Test Workflow supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    Refer to the readme of each product for where to find examples.
    Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2021–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 06:21
