查看: 1882|回复: 0
[NI软件产品] NI G Web Development Software 2022Q3 Community Win11 64bitEng G网络开发软件2022 Q3社区版G-WEB22.3
     楼主| 发表于 2022-8-15 11:44:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    G网络开发软件
    G Web开发软件可以帮助您为测试和测量应用程序创建基于Web的用户界面,无需Web开发技能。
    G网络开发软件是一种应用软件,您可以使用图形化编程为您的测试和测量应用程序创建网络应用。您可以在任何现代网络浏览器中运行由G网络开发软件创建的应用程序,而无需插件或安装程序。此外,该软件还能帮助您通过行业标准技术在网络上快速可视化及分享来自分布式系统的数据。
    G网络开发软件2022Q3
    发布日期:2022/7/26
    包含的版本:2022 Q3社区版 版本号22.3.0
    文件大小: 1443860480 字节 (1.34 GB)
    修改日期: 2022-07-26 23:54
    MD5: cda8d10c1a743f472f0ba7d13bf0d6f5
    SHA1: 5911a3a7254b1a1b2535109bea78cb0cc96f5650
    SHA256: 59317c68b0776e5292485b79d4adaecca0cad06002f6ccf2707be2bee5073d39
    CRC32: 3c33d92b
    百度网盘和NI官方下载:
    请注册登录视觉论坛账号,购买附件查看下载地址
    G WEB 22.3Community.txt (588 Bytes, 下载次数: 0, 售价: 10 圆)
    G Web Development Software 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for G Web Development Software.
    • G Web Development Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • G Web Development Software Manuals: New features, behavior changes, and other documentation
    G Web Development Software 2022 Q1 has the following requirements:
    • Pentium 4 G1 equivalent (Intel i5 equivalent or higher recommended)
    • 10 GB of disk space (20 GB or higher recommended)
    • Installation on a solid state drive (SSD) recommended
    • 2 GB RAM
    • .NET Framework 4.6.2
    • 1024x768 resolution (1366x768 or higher recommended)
    G Web Development Software 2022 Q3 supports the following operating systems:
    • Windows 10 (version 1909)
    Supported BrowsersG Web Development Software 2022 Q3 supports the latest version of the following browsers:
    • Chrome
    • Edge
    • Firefox
    • Safari
    Download the G Web Development Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate G Web Development Software. For more information on G Web Development Software activation, refer to NI Software Activation.
    Visit ni.com/security to view and subscribe to receive security notifications and to view critical updates about NI products.
    New FeaturesG Web Development Software 2022 Q3
    • Added new CLI command - Distribution (can be used to build lvdist file from command line tool)
    • Support for debugging Web VI
    Refer to the G Web Development Software Manual for more information.
    G Web Development Software Help
    View context help in G Web Development Software by pressing and hovering over an object.
    Search for items using the search bar in the upper right corner of the G Web Development Software window. You can also view context help for the search results.
    G Web Development Software Lessons and Examples
    Launch G Web Development Software and click the Learning tab to access Lessons.
    G Web Development Software Examples are located in the Examples tab.
    G Web Development Software does not support Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. G Web Development Software 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherNet/IP 2022 Q3 to an unsupported OS.
    © 2021-2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-23 12:53
