查看: 1582|回复: 0
[NI软件产品] NI RFmx 2022 Q3 Full Win11 32/64bitEng NI Wireless Test Standard Software完整版ni-rfmx-suite_22.5
    9 小时前
     楼主| 发表于 2022-8-16 16:09:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期:2022/7/23
    包含的版本:2022Q3完整版,版本号22.5.0
    文件大小: 2842333184 字节 (2.65 GB)
    修改日期: 2022-07-23 09:59
    MD5: 537c5b8f62962b729b92219fde6644b0
    SHA1: 4159f1040bf3a36f63dcc67e4d46f455aca50ec8
    SHA256: ea387fa5cb153a46284dc21bd0349329d7fd78c3529903afd459c97539e7398d
    CRC32: a3bc9a34
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx22.5.txt (556 Bytes, 下载次数: 2, 售价: 10 圆)
    RFmx 2022 Q3 Readme
    July 2022
    • RFmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx WLAN
    • RFmx for Bluetooth® Test
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    RFmx 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx 2022 Q3 to an unsupported OS. Additionally, after installing RFmx 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx 2022 Q3 supports the following application software versions, including service packs.
    Versions Supported by RFmx
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, or 2022 Q3
    LabWindows™/CVI™2017 or later
    Download the RFmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    GMT+8, 2025-12-8 19:08
