查看: 1993|回复: 0
[RTE运行引擎] NI RFmx 2022 Q3 Runtime Win11 32bitEng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_22.5
     楼主| 发表于 2022-8-16 16:13:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx
    发布日期:2022/7/23
    包含的版本:2022Q3运行版,版本号22.5.0
    应用程序位数:32位
    文件大小: 757127168 字节 (722.05 MB)
    修改日期: 2022-07-23 09:59
    MD5: 6cadb39f7a02e75e6fd161870eeacd8f
    SHA1: 670652f854e8e4752a0dc16b1ffc166f1575d828
    SHA256: e733fbbdff09f212824fb68bd0564d0474a9ce4fbb27e81996956fedc85607e5
    CRC32: ce06e6dd
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx22.5RTE32.txt (594 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx Runtime (32-Bit) 2022 Q3 Readme
    July 2022
    This file contains important information about the RFmx Runtime (32-Bit), including system requirements, and installation instructions.
    • RFmx Runtime (32-Bit) Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    The following products are included in the RFmx Runtime (32-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (32-Bit)
    • RFmx Demod Runtime (32-Bit)
    • RFmx WLAN Runtime (32-Bit)
    • RFmx for Bluetooth® Test Runtime (32-Bit)
    • RFmx NR Runtime (32-Bit)
    • RFmx LTE Runtime (32-Bit)
    • RFmx WCDMA Runtime (32-Bit)
    • RFmx TD-SCDMA Runtime (32-Bit)
    • RFmx EV-DO Runtime (32-Bit)
    • RFmx CDMA2k Runtime (32-Bit)
    • RFmx GSM Runtime (32-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    RFmx Runtime (32-Bit) has the following requirements:
    RFmx Runtime (32-Bit) 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx Runtime (32-Bit) no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx Runtime (32-Bit) 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx Runtime (32-Bit) 2022 Q3 to an unsupported OS. Additionally, after installing RFmx Runtime (32-Bit) 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Download the RFmx Runtime (32-Bit) installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    GMT+8, 2025-12-8 08:29
