查看: 1526|回复: 0
[NI软件产品] NI RFmx for Bluetooth Test 2022 Q3 Win11 32/64bitEng RFmx蓝牙测试NIRFmxBluetooth22.5
    9 小时前
     楼主| 发表于 2022-8-17 18:11:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    32/64位完整版校验和:
    文件大小: 1192830976 字节 (1.11 GB)
    修改日期: 2022-07-23 09:57
    MD5: f8b162209060f62cce10a6955dcea67f
    SHA1: ed0f37a3452d38f00083870fd1ae8d24cf801083
    SHA256: 73c4a39b58bc6a866d40ac22b6930a0bbf6fc181f4f31b9406651ee47755b68c
    CRC32: 5fe005a3
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx Bluetooth22.5.txt (561 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 641259520 字节 (611.55 MB)
    MD5: a2e448cad4e36cc6f9dc9ae8c9eed264
    SHA1: 356ff6ffd81572dba124b5e0bd38f6c6bc8532d6
    SHA256: eccd131f84e7852235097fe1171cc676976a62db13a0f71e2a2b6f54890ef7e9
    CRC32: 1588e41c
    RFmx Bluetooth22.5RTE32.txt (594 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 655888384 字节 (625.50 MB)
    MD5: 6fe353f4c9b908d0baad40e3f14373bf
    SHA1: 16bed032453b51c85acb82cf9ec62d8944824484
    SHA256: a8c050de8fdeb9a84e05f58ae0f08738a687e7dc4f85ce2b60aa89da446f991f
    CRC32: 4171e7f4
    RFmx Bluetooth22.5RTE64.txt (582 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx for Bluetooth® Test 2022 Q3 Readme
    July 2022
    This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions.
    • RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
    RFmx for Bluetooth® Test supports the following features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.3, and the Bluetooth RF PHY test specifications RF.TS.p32 and RFPHY.TS.p17.
    • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.3.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power, frequency range and 20 dB bandwidth measurements on Basic Rate physical layer signals.
    • Support for modulation accuracy (frequency error, differential EVM (DEVM)), transmit power, adjacent channel power (in-band spurious emissions) measurements on Enhanced Data Rate physical layer signals.
    • Support for modulation accuracy (df1, df2, frequency error), transmit power, adjacent channel power (in-band emissions) measurements on Low Energy physical layer signals.
    RFmx for Bluetooth® Test 2022 Q3 includes the following new feature:
    RFmx for Bluetooth® Test 21.8 includes the following new features:
    • Support for Initial Frequency Error Maximum result for LE packets in ModAcc measurement
    RFmx for Bluetooth® Test 21.3 includes the following new features:
    • Support for DEVM magnitude and phase error results in ModAcc measurement
    RFmx for Bluetooth® Test has the following requirements:
    RFmx for Bluetooth® Test 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 2022 Q3 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx for Bluetooth® Test
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    If you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » RFmx » BT palette.
    Documentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx for Bluetooth® Test Documentation.
    You can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx for Bluetooth® Test Examples.
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q3 from RFmx for Bluetooth® Test 21.8.2:
    The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7.
    • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
    The following are the behavior changes in RFmx for Bluetooth® Test 20.7 from RFmx for Bluetooth® Test 20.6.
    GMT+8, 2025-12-8 19:07
