查看: 1337|回复: 0
[NI软件产品] NI RFmx CDMA2000 2022 Q3 Full/Runtime Win11 32/64bitENG RFmxCDMA2K完整版运行版下载22.5
    昨天 08:45
  • 签到天数: 3647 天
    连续签到: 9 天
     楼主| 发表于 2022-8-17 18:24:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    32/64位完整版校验和:
    文件大小: 819376128 字节 (781.42 MB)
    修改日期: 2022-07-23 09:58
    MD5: e3ff3491e8d2c21f31c0442d40759c9f
    SHA1: f6f37efea3cc5fe435c0c2d8b39220054e35be12
    SHA256: a2f9a743d62535e66888809702a8c40eb3f534d6175c10a5a8b8ab743c2ab7cc
    CRC32: 34a1f781
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K22.5.txt (553 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 610566144 字节 (582.28 MB)
    MD5: 81dc1bc9b707c2d5b8fee795f7551b16
    SHA1: 478b787cae9411b1b7739a778198d103ba55b32b
    SHA256: 15eea0ff87ff0e951188d24fd46dd72a1baf053f334bff1b34671e361bf4af18
    CRC32: 1baed26f
    RFmx CDMA2K22.5RTE32.txt (585 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 615147520 字节 (586.65 MB)
    MD5: 02eb1fad87c9d12ec68416774725c8b1
    SHA1: 09852e7bfe114b0bba53e2c9e9a2eadfe411ae1c
    SHA256: 0cd30dffd01221fe210ddd68ea591cf37f510aef8035c07c0641f997c81641b6
    CRC32: 42934196
    RFmx CDMA2K22.5RTE64.txt (573 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx CDMA2k 2022 Q3 Readme
    July 2022
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    RFmx CDMA2k is an application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development effort. Using this software, you can perform physical-layer analysis on CDMA2k cellular signals including MODACC, ACPR, CHP, OBW, QEVM, CDA, SlotPower, SlotPhase, and SEM. RFmx CDMA2k is completely interoperable with all RFmx APIs.
    RFmx CDMA2k 2022 Q3 includes the following new feature:
    RFmx CDMA2k 21.3 includes the following new feature:
    RFmx CDMA2k 20.0 includes the following new features:
    RFmx CDMA2k 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2022 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Versions Supported by RFmx CDMA2k
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following are the behavior changes in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    The following items are behavior changes in RFmx CDMA2k 19.0 from RFmx CDMA2k 3.0.
    GMT+8, 2025-9-10 07:02
