查看: 1943|回复: 0
[NI软件产品] NI RFmx NR 2022 Q3 Win11 64bitENG RFmx 5G新空口蜂窝测试22.5
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-8-18 11:37:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx NR
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    64位完整版校验和:
    文件大小: 1510299648 字节 (1.41 GB)
    修改日期: 2022-07-23 09:58
    MD5: f9d6b4259dca5ccd9ace33f88823ca04
    SHA1: 428640640ba8c1bfe956e7db57e975ae95da01e0
    SHA256: 017667ae08a2e2a78d078238f6f5ea8a4c6f17b37e6581d5688e0b8f5da9e890
    CRC32: 6938b91d
    NI官方下载和百度网盘下载地址:
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx NR22.5.txt (565 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 644335616 字节 (614.49 MB)
    MD5: c3d8f67bed57df530f60ec7ebf1d18e9
    SHA1: 4c0aff24ce4f45257b4113f3394269cc5ec626a0
    SHA256: de1e7844568788fff2a680574a0db4e8af2a2a2218e315d92b5be58ddb39d3a4
    CRC32: 64abb759
    NI官方下载和百度网盘下载地址:
    RFmx NR22.5RTE64.txt (589 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx NR 2022 Q3 Readme
    July 2022
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    • RFmx NR Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx NR Manuals: New features, behavior changes, and other documentation
    The RFmx NR personality is a highly optimized API for performing physical layer measurements on 5G New Radio (NR) signals. RFmx NR is completely interoperable with all RFmx APIs. It provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is extremely fast and high-quality measurements with minimal software development efforts.
    RFmx NR 2022 Q3 includes the following new features:
    • Support for LabVIEW 2022 Q3 (64-bit)
    • Support for demodulation of multiple shared channels that are orthogonal in time or frequency in Uplink and Downlink ModAcc measurement
    • Support for SEM measurement in band n46, n96, and n102 with full bandwidth transmission based on 3GPP Release 17 (March-2022)
    • Support for 1024-QAM modulation type in Downlink Testmodels TM2b and TM3.1b based on 3GPP Release 17 (March-2022)
    • Support for bands n101 and n102 based on 3GPP Release 17 (March-2022)
    RFmx NR 21.8 includes the following new features:
    • Support for Half Radio Frame Index to indicate location of SSB with periodicity greater than 5 msec
    • Support for demodulating non-3GPP compliant short frames with Sync Mode as Frame and Trigger Type as None
    • Support for additional phase tracking modes in ModAcc measurement
    • Support for n46 and n96 bands in ACP and PVT measurements and IBE result in ModAcc measurement
    • Support for configurable Cell ID in Downlink Test Models
    • Support for Release 17 specifications of 3GPP NR based on (Dec-2021)
    RFmx NR 21.3 includes the following new features:
    • Support for all trigger types and synchronization modes in ModAcc measurement for downlink mixed numerology SSB/SCH configurations
    • Support for List Mode feature on PXIe-5840/5841/5830/5831/5832
    • Support for TXP measurement
    • Support for SSB Periodicity of 5, 10, 20, 40, 80, and 160 msec
    • Support for PVT measurement in downlink
    • Support for Custom configuration for ACP measurement
    • Support for Intra-band non-contiguous carrier aggregation in FR1 bands for SEM measurement
    • Support for reference symbols input for EVM computation in the ModAcc measurement
    • Support for Auto Level for ModAcc measurement
    • Support for Release 17 specifications of 3GPP NR based on (June 2021):
      • Addition of 35 MHz and 45 MHz BW support
      • Addition of new Bands n13, n24, n67, n85, n97, n98
    • Support for EVM noise compensation in FR1 frequencies for ModAcc measurement with 5840, 5841, and 5831
    • Support for all FFT window types and user-defined overlap (%) for Sequential FFT measurement method in ACP measurement
    RFmx NR has the following requirements:
    RFmx NR 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx NR no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx NR 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx NR 2022 Q3 to an unsupported OS. Additionally, after installing RFmx NR 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx NR (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx NR installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    RFmx NR palette VIs are available from the Functions » Measurement I/O » RFmx » NR palette.
    Documentation for RFmx NR is located at Start » National Instruments » RFmx NR Documentation.
    You can access all the installed RFmx NR examples at Start » National Instruments » RFmx NR Examples.
    The following are the behavior changes in RFmx NR 2022 Q3 from RFmx NR 21.8:
    • RFmx Soft Front Panel has been replaced by InstrumentStudio.
    The following are the behavior changes in RFmx NR 21.8 from RFmx NR 21.5:
    • RFmx NR drops support for 32-bit user mode.
    • Deprecated PDSCH present in SSB Resource Block.
    • Deprecated Subblock Freq Definition property. Use Subblock Freq (Hz) property for configuring subblock frequency offset from the center frequency.
    The following are the behavior changes in RFmx NR 21.3 from RFmx NR 20.7/20.7.1:
    • Updated downlink subblock integration bandwidth for ACP, CHP, and SEM measurements as per 38.104 CR0262.
    • Increased acquisition length for ModAcc measurement in the case of DFT-s-OFDM with SCS 60 kHz, and above with trigger types other than digital and sync mode other than Frame.
    © 2018–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-3 05:27
