查看: 1759|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2022 Q3 Win11 32/64bitENG RFmx蜂窝测试TD-SCDMA22.5
    9 小时前
     楼主| 发表于 2022-8-19 10:33:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    32/64位完整版校验和:
    文件大小: 1207953408 字节 (1.12 GB)
    修改日期: 2022-07-23 09:59
    MD5: b2d1daae92b4d32cbebcc5806abde553
    SHA1: a5c8f1cc8ca88bcf234e010bb9fd4614066a48a1
    SHA256: 7ff36f98a323babebefcbbcba2117f01df2e5a7323da530c0f1b6915362218ac
    CRC32: 6d5e2f09
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx TD-SCDMA22.5.txt (555 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    文件大小: 610779136 字节 (582.48 MB)
    MD5: 385800dbca1495e78677a21c39ca381a
    SHA1: f16906b761da9e833c10c44cc576843a94e52241
    SHA256: 291b8f1b00feb8dd4045e4715b94deae83a18bd8ea85d3b60dae394f6e007f0b
    CRC32: afa05327
    RFmx TD-SCDMA22.5RTE32.txt (588 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    文件大小: 615374848 字节 (586.87 MB)
    MD5: dc6f7b6185617fad9766916bb886e09a
    SHA1: 617c8816a8eb61c945031cfc4cc0fca1a389f033
    SHA256: 898bac6d3cf476b67efb884e7101bfb0318d886e0bf17ace88f9088182dd3ec1
    CRC32: dfd09a6c
    RFmx TD-SCDMA22.5RTE64.txt (576 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx TD-SCDMA 2022 Q3 Readme
    July 2022
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA is application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development efforts. Using this software, you can perform physical layer analysis on TD-SCDMA cellular signals including MODACC, ACPR, CHP, and SEM. RFmx TD-SCDMA is completely interoperable with all RFmx APIs.
    RFmx TD-SCDMA 2022 Q3 includes the following new feature:
    RFmx TD-SCDMA 21.3 includes the following new feature:
    RFmx TD-SCDMA 20.0 includes the following new features:
    RFmx TD-SCDMA 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2022 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    The following are the behavior changes in RFmx TD-SCDMA 19.1 from RFmx TD-SCDMA 19.0:
    • Obsoleted RFmxTDSCDMA Analyze (IQ) and RFmxTDSCDMA Analyze (Spectrum) APIs. Use RFmxTDSCDMA Analyze (IQ, 1 Wfm) and RFmxTDSCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    GMT+8, 2025-12-8 19:08
