查看: 1387|回复: 0
[NI软件产品] NI RFmx W-CDMA/HSPA+ 2022 Q3 Win11 32/64bitENG RFmx W-CDMA/HSPA/HSPA+蜂窝测试22.5
    昨天 08:45
  • 签到天数: 3647 天
    连续签到: 9 天
     楼主| 发表于 2022-8-19 10:59:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx W-CDMA/HSPA+
    RFmx W-CDMA/HSPA+为W-CDMA、HSPA和HSPA+蜂窝测试应用提供信号生成和分析功能。
    RFmx W-CDMA/HSPA+是一款测量专用软件,旨在扩展NI RF仪器生成和分析W-CDMA、HSPA和HSPA+蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对W-CDMA、HSUPA和HSUPA+上行链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    32/64位完整版校验和:
    文件大小: 1213272064 字节 (1.13 GB)
    修改日期: 2022-07-23 10:00
    MD5: e25b5dd3b4c06278257bcffaaae90d3f
    SHA1: 8c9d9cd842c168e653c99437bcabb75cb18bf57f
    SHA256: 0ae1ad9415b3ef4b540b529d040c51c4d17a8c24e276bbf1bb89df4ddd81d846
    CRC32: c12e00f4
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx WCDMA22.5.txt (556 Bytes, 下载次数: 0, 售价: 10 圆)
    32位运行版校验和:
    CRC32: c12e00f4
    RFmx WCDMA22.5RTE32.txt (589 Bytes, 下载次数: 0, 售价: 5 圆)
    64位运行版校验和:
    CRC32: c12e00f4
    RFmx WCDMA22.5RTE64.txt (577 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WCDMA 2022 Q3 Readme
    July 2022
    This file contains important information about the RFmx WCDMA, including system requirements, and installation instructions.
    • RFmx WCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx WCDMA Manuals: New features, behavior changes, and other documentation
    RFmx WCDMA is an optimized API for performing physical layer measurements on WCDMA cellular standard signals. RFmx WCDMA is an application software that provides simple access to advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements.
    RFmx WCDMA 2022 Q3 includes the following new feature:
    RFmx WCDMA 21.8 includes the following new feature:
    • Support for Downlink in Link Direction property of ModAcc measurement
    RFmx WCDMA 21.3 includes the following new features:
    RFmx WCDMA has the following requirements:
    RFmx WCDMA 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx WCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WCDMA 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WCDMA 2022 Q3 to an unsupported OS. Additionally, after installing RFmx WCDMA 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WCDMA
    LabVIEW2019 SP1 f3 patch, 2020 SP1, 2021 SP1 f1 patch, 2022 Q3
    If you are using the RFmx WCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx WCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx WCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx WCDMA. For more information on RFmx WCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.WcdmaMX.Fx40.dll
    RFmx WCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » WCDMA palette.
    Documentation for RFmx WCDMA is located at Start » National Instruments » RFmx WCDMA Documentation.
    You can access all the installed RFmx WCDMA examples at Start » National Instruments » RFmx WCDMA Examples.
    The following is the behavior change in RFmx WCDMA 2022 Q3 from RFmx WCDMA 21.8.2
    The following is the behavior change in RFmx WCDMA 20.7 from RFmx WCDMA 20.6.
    The following are the behavior changes in RFmx WCDMA 19.1 from RFmx WCDMA 19.0.
    • Obsoleted RFmxWCDMA Analyze (IQ) and RFmxWCDMA Analyze (Spectrum) APIs. Use RFmxWCDMA Analyze (IQ, 1 Wfm) and RFmxWCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    GMT+8, 2025-9-10 06:56
