查看: 1654|回复: 0
[NI软件产品] NI RFmx WLAN 2022 Q3 Win11 64bitENG RFmx无线局域网络22.5
    昨天 08:45
  • 签到天数: 3647 天
    连续签到: 9 天
     楼主| 发表于 2022-8-19 11:09:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    64位完整版校验和:
    文件大小: 1243019264 字节 (1.16 GB)
    修改日期: 2022-07-23 09:48
    MD5: 7a6b2ff8ff6205b4f81a9c8fa2bd24cf
    SHA1: f7216d2c0d0604e5c85e6368ffd4426253ef60f3
    SHA256: 5c4e3e1677d1054799a8ecd8b974ac33a4edd54e3cffed2fb0e1c54ecd16bfe1
    CRC32: 57ebe064
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx WLAN22.5.txt (554 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 636278784 字节 (606.80 MB)
    修改日期: 2022-07-23 09:49
    MD5: 7cb05c7e30bf19b4fa4946c4eb8c741c
    SHA1: 478c4f3709748240eb88c393692033d9ffae408e
    SHA256: 5fcc58010a6d674c0001601d46ae1b6b6f96ef1ba4097674f435d9b601f2fb94
    CRC32: 7be82581
    RFmx WLAN22.5RTE64.txt (578 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 2022 Q3 Readme
    July 2022
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11be MU PPDU in SISO and MIMO configurations
    • Support for OFDM physical layer of 802.11n, 802.11ac, and 802.11ax in MIMO configuration
    • Support for OFDM physical layer of 802.11ax SU, MU, Extended Range SU, and trigger-based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D8.0.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, 160 MHz, and 320 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 2022 Q3 includes the following new features:
    • Support for LabVIEW 2022 Q3 (64-bit)
    • 802.11be standard support has been updated to comply with IEEE P802.11be/D2.0 specification
    • Support for dB Units in Common Pilot Error Magnitude trace
    RFmx WLAN 21.8 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.5
    • Support for auto level in MIMO OFDMModAcc measurement
    • Support for skipping decoding of header fields for 802.11be standard
    • Support for auto detection of phase rotation parameters for 802.11be 320 MHz
    • Support for 802.11be gated power measurement
    • Support for Wiener interpolation filter for 802.11ax and 802.11be standards
    • Support for 802.11be auto detection of Standard property
    • Support for phase noise PSD measurement
    • Support for burst start time result in OFDMModAcc measurement
    RFmx WLAN 21.5 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.3
    • Support for EVM noise compensation for MU OFDMA and trigger-based PPDU types
    RFmx WLAN 2022 Q3 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2022 Q3 to an unsupported OS. Additionally, after installing RFmx WLAN 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®;, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, or 2021 SP1 f1 patch, 2022 Q3
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-9-10 07:02
