查看: 1845|回复: 0
[NI驱动程序] NI-845x Driver Software 2022 Q3 Win11 32/64bitEng NI-845x驱动软件22.5
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
     楼主| 发表于 2022-8-22 11:25:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-845x支持I2C/SPI接口设备。
    NI-845x是一个驱动程序软件,用于对消费电子产品和集成电路的内部集成电路(I2C)、SCSI并行接口(SPI)或SMBus通信进行配置、编程和故障排除。NI-845x还提供一个通用数字I/O API,适用于各种应用,比如I2C设备的地址配置、LED切换或选通转换以及模拟转换器芯片常见的数据收发线等。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    文件大小: 641085440 字节 (611.39 MB)
    修改日期: 2022-07-23 09:48
    MD5: 871933bcdf2b75f2a7739c6e9d41fab4
    SHA1: f44c1fe76e00cd83bf1fb981c6280115a2765621
    SHA256: b49ea86040d119a51865a54a82cd6cad1cf07afacce9daebe95fdb2ed35f72eb
    CRC32: b3cfef74
    请注册登录视觉论坛账号,购买附件查看下载地址
    845x22.5.txt (537 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-845x Driver Software 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for NI-845x Driver Software 2022 Q3.
    • NI-845x Driver Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-845x Driver Software Manuals: New features, behavior changes, and other documentation
    NI-845x Driver Software is required to use the NI USB-8451 and NI USB-8452 I2C and SPI interfaces.
    NI-845x Driver Software 2022 Q3 supports the following operating systems:
    NI-845x Driver Software 2022 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-845x Driver Software 2022 Q3
    LabVIEW2019 and later
    NI-845x supports the following Microsoft Visual Studio versions and associated programming languages.
    Programming Languages
    Microsoft Visual C++2015 (or later)
    Download the NI-845x Driver Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    The "NI-845x Driver Software Support for LabVIEW" package supports applications using NI-845x Driver Software ​with LabVIEW 2019 or later. When installing NI-845x Driver Software, this package will be recommended if you have already installed LabVIEW 2019 or later and installs to the LVAddons directory.
    NI-845x Driver Software installer 2022 Q3 includes the following new feature:
    • Added support for LabVIEW 2022
    Refer to the NI-845x Hardware and Software Help, accessible from National Instruments»NI-845x Documentation, for information about the NI-845x Driver Software.
    NI-845x Driver Software no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2005–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-3 00:45
