查看: 1269|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2022 Q3 Win11 32/64bitEng NI-RFSG回放库22.5
    9 小时前
  • 签到天数: 3534 天
     楼主| 发表于 2022-8-23 12:28:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期:2022/7/23
    包含的版本:2022 Q3完整版,版本号22.5.0
    32/64位完整版校验和:
    文件大小: 488927232 字节 (466.28 MB)
    修改日期: 2022-07-23 10:00
    MD5: 8d4b0e9fd6f9568180aa66d4cf091123
    SHA1: 16c1a0f5c52e8ce0f4622cfbdedc8a9c3cb6bede
    SHA256: 0ad01d024cd0117a2aae8ff8cad674b8dc85971c66c144d17b9d04d1af0fd215
    CRC32: 01f1eed0
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFSG Playback22.5.txt (592 Bytes, 下载次数: 0, 售价: 10 元)
    32/64位运行版校验和:
    文件大小: 395460608 字节 (377.14 MB)
    MD5: 12bc47a5398d7a837f572987d4904ea0
    SHA1: 3606dcf190a47031b26e8af0592557c15e78686a
    SHA256: 60b8d921ae4dbeee2a6fd69aa1dbdbafa266ca0f779016368b3139e152a7e0f9
    CRC32: a3d04d17
    RFSG Playback22.5RTE.txt (615 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFSG Playback Library 2022 Q3 Readme
    July 2022
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    NI-RFSG Playback Library allows users to generate waveforms saved in the technical data management streaming (TDMS) file using the NI-RFSG driver. These TDMS files can be created from the NI RFmx Waveform Creator. You can use the NI-RFSG Playback Library to download multiple waveforms to the NI-RFSG vector signal generator memory. You can then generate all these waveforms using either a single script or multiple scripts. The playback library internally retrieves waveform properties from database to calculate and apply appropriate settings on the NI-RFSG driver.
    NI-RFSG Playback Library 2022 Q3 includes the following new features:
    NI-RFSG Playback Library 21.3 includes the following new features:
    NI-RFSG Playback Library 20.6 includes the following new features:
    • Support for PXIe-5832
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 2022 Q3 supports the following 64-bit operating systems:
    Note    NI-RFSG Playback Library no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-RFSG Playback Library 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 2022 Q3 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library
    LabVIEW2019 SP1, 2020 SP1, 2021, 2022 Q3
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library Documentation.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library Examples.
    GMT+8, 2025-5-9 16:09
