查看: 1647|回复: 0
[NI驱动程序] NI PXI Firmware and Additional Drivers 2022 Q3 Win32/64Eng PXIe-8398固件及其他驱动22.5
    昨天 15:52
  • 签到天数: 3749 天
    连续签到: 76 天
     楼主| 发表于 2022-8-23 17:37:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    PXIe-8398固件及其他驱动
    PXIe-8398固件及其他驱动支持PXIe-8398 PXI远程控制模块。
    PXIe-8398固件及其他驱动包括PXIe-8398 PXI远程控制模块的固件。该固件可帮助您设置和控制PXIe-8398的运行方式。
    发布日期:2022/7/18
    包含的版本:2022 Q3完整版,版本号22.5
    语言:英文
    文件大小: 568098 字节 (554.78 KB)
    修改日期: 2022-07-12 09:47
    MD5: 58002a89ab7ee38b41e834a399d1ee2c
    SHA1: 489dbd42c5eed4f3b3235832c44c5f578d5a6cd1
    SHA256: ca3068a512dbca281fdb34ae6482c2ed07712dc2799242601e7e4378f4520862
    CRC32: 7bacdbf9
    请注册登录视觉论坛账号,购买附件查看下载地址
    PXIe-8398固件及其他驱动22.5.txt (545 Bytes, 下载次数: 0, 售价: 10 圆)
    MXI Express Firmware 2022 Q3 Readme
    July 2022
    This file contains important information about MXI Express Firmware 2022 Q3, including installation instructions.
    Include this section if your product supports Phar Lap ETS. NI no longer supports Phar Lap ETS Real-Time Operating System
    MXI Express Firmware includes firmware for the PXIe-83XX PXI Remote Control Modules. The firmware helps you set up and control how the PXIe-83XX series operates.
    MXI Express Firmware 2022 Q3 has the following requirements:
    • Updating the firmware on your MXI Express hardware requires:
      • PXI Platform Services 2022 Q3 (or later)
    MXI Express Firmware 2022 Q3 supports the following operating systems:
    Note  Product no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Download the corresponding MXI Express firmware installer from ni.com/downloads.
    Do NOT turn off or interrupt the system during the firmware update!
    • Download and save firmware image to the system containing the remote controller(s) to be updated.
    • On the system, run NI Measurement & Automation Explorer as Administrator.
    • Each controller must be updated separately. For each controller to be updated:
      • Locate and expand the chassis containing the remote controller to be updated.
      • Select the remote controller in the left most pane, then click the Update Firmware button in the right pane.
      • Navigate to and select the firmware image file saved in Step 1, then click the Open button.
        • A dialog box should open containing information about the firmware image selected.
      • Confirm the version number displayed is as you expected.
        • If the version is as you expected, select the Begin Update button.
        • If the version is not as you expected, select the Cancel button and confirm the download in Step 1.
      • After several minutes, a dialog box should appear:
        • If the dialog states "The firmware update completed successfully", power cycle the remote controller by following the additional instructions in the dialog box.
        • If the dialog states that an issue occurred, record the error number/message and Contact NI.
      • Note, firmware is updated on the hardware itself, so once updated the MXI Express device can be moved to different systems while still retaining the update.
    The following National Instruments PXI Express Remote Controller currently support firmware update:
    • NI PXIe-8301
    • NI PXIe-8360
    • NI PXIe-8370
    • NI PXIe-8375
    • NI PXIe-8381
    • NI PXIe-8388
    • NI PXIe-8389
    • NI PXIe-8398
    • NI PXIe-8399
    Product no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    NI No Longer Supports Phar Lap ETS Real-Time Operating SystemInclude this section if your product supports Phar Lap ETS.
    © 2013–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-22 11:40
