查看: 3178|回复: 0
[LV工具模块] LabVIEW 2022 Q4 OPC UA Toolkit Win11 32/64bitCHN/Eng/Jpn LabVIEW OPC UA工具包OPCUA22.8
    11 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2022-11-15 12:22:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW OPC UA工具包支持在LabVIEW中创建OPC UA客户端和服务器。
    LabVIEW OPC UA工具包是LabVIEW的一个软件附件。它包含OPC UA API,集成了安全可靠的通信。您可以使用此工具包创建OPC UA客户端,服务器和安全性管理。除OPC UA规范的数据访问方面外,LabVIEW OPC UA工具包还提供对历史访问和警报和条件方面的支持。该工具包适用于Windows和NI Linux实时操作系统。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    LabVIEW OPC UA工具包2022 Q4 32/64
    发布日期:22-10-12
    包含版本:22.8完整版
    程序位数:32/64位
    语言:英语,日语,中文
    文件大小: 1081784320 字节 (1.01 GB)
    修改日期: 2022-10-13 09:50
    MD5: f93754e490a6125ef638c2d347cc02a9
    SHA1: 5e85f687cec4be192ff56e4fb65e5738717e0cbb
    SHA256: 0c2a6c79efe32bc109b1a0bd7d895b59e1eb2914e5b62dc1d88c7e752c75f265
    CRC32: e4b4eed5
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    OPCUA2022Q4.txt (592 Bytes, 下载次数: 5, 售价: 10 圆)
    LabVIEW OPC UA Toolkit 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for LabVIEW OPC UA Toolkit 2022 Q4.
    • LabVIEW OPC UA Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW OPC UA Toolkit Documentation: New features, behavior changes, and other documentation
    The OPC UA toolkit contains the OPC UA API that was formerly part of the LabVIEW Datalogging and Supervisory Control (DSC) Module and the LabVIEW Real-Time Module. From the 2017 release, the OPC UA Toolkit becomes a standalone product. The DSC Module and the Real-Time Module no longer contain the OPC UA API. The OPC UA toolkit integrates secure and reliable communications in your LabVIEW applications. The OPC UA toolkit incorporates a series of features for the creation of OPC UA clients, servers, and security management. In addition to the Data Access (DA) facet of the OPC UA Specifications, the OPC UA Toolkit also adds support for the Historical Access (HA) and Alarms & Conditions (AC) facets. The OPC UA Toolkit is compatible with both Windows and NI Linux Real-Time operating systems.
    Note To deploy standalone applications, you must use the OPC UA Runtime and activate the OPC UA Toolkit deployment license.
    In addition to the system requirements for the LabVIEW Development System, the LabVIEW OPC UA Toolkit 2022 Q4 has the following requirements:
    • LabVIEW 2022 (32-bit or 64-bit)
    • LabVIEW 2022 Real-Time Module (required only if you use NI Linux Real-Time targets with the OPC UA Toolkit)
    • NI CompactRIO Device Drivers 2022 Q3 or later (required only if you use CompactRIO devices with the OPC UA Toolkit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW OPC UA Toolkit 2022.
    LabVIEW OPC UA Toolkit 2022 Q4 supports the following operating systems:
    Note LabVIEW OPC UA Toolkit no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Note  The OPC UA Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. The OPC UA Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the OPC UA Toolkit to an unsupported OS. Additionally, after installing the OPC UA Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    LabVIEW OPC UA Toolkit 2022 Q4 supports the following application software versions, including service packs.
    Versions Supported by LabVIEW OPC UA Toolkit 2022 Q4
    LabVIEW2022
    Download the OPC UA Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "LabVIEW OPC UA Toolkit Support for LabVIEW" package supports applications using LabVIEW OPC UA Toolkit ​with LabVIEW 2022 or later. When installing LabVIEW OPC UA Toolkit, this package will be recommended if you have already installed LabVIEW 2022 minimum supported version or later and installs to the LVAddons directory.
    • Added reentrant support for OPC UA VIs
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help in LabVIEW, for information about the OPC UA Toolkit. You can also find the help at C:\Program Files\NI\LVAddons.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»OPC UA folder to access the examples.
    You also can find the examples for the OPC UA Toolkit in the C:\Program Files\NI\LVAddons directory.
    LabVIEW OPC UA Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2017–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-8 19:09
