查看: 1605|回复: 0
[NI驱动程序] NI-488.2 2022 Q4 Driver Online Download Linux64Eng NI IEEE488.2仪器驱动22.8在线版下载
    3 小时前
  • 签到天数: 3538 天
    连续签到: 8 天
     楼主| 发表于 2022-11-18 11:29:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-488.2为使用NI GPIB控制器和带有GPIB端口的NI嵌入式控制器的客户提供支持。
    NI-488.2仪器驱动程序包含了几个实用程序,用于应用程序开发和调试。NI-488.2包含了可自动处理所有总线管理的高级命令,因而用户就无需了解GPIB硬件产品或IEEE 488.2协议的编程细节。为了提供最大灵活性和功能,NI-488.2还包含了底层命令。
    20.0版自述文件有中文版的,官方说明中也说支持中文, 日语, 英文, 韩语等,但是翻看资源包的Documents目录下,只有英文和日文的,估计仍然是只有安装界面与自述文件有中文,内在的资源仍然是没有中文化的。
    NI-488.2 2022Q4
    发布日期:2022/10/14
    包含的版本:22.8.0完整版
    RedHat
    SUSE
    Ubuntu
    文件大小: 408542 字节 (398.97 KB)
    修改日期: 2022-10-15 09:49
    MD5: f3914fd71ace97a8cb399e5c9b127b6e
    SHA1: 02cae55c43769c5e03810c58c79ff24a38798a69
    SHA256: bddf9878db0c3bcf1b6d67d9f84bcf4a6ce744b48cc138183281962715efd39e
    CRC32: a0611b43
    请注册视觉论坛会员,购买附件查看下载地址
    NI Linux Device Drivers 2022Q4.txt (535 Bytes, 下载次数: 0, 售价: 5 元)
    NI-488.2 2022 Q4 for Linux/x86 64-bit Architecture Readme
    October 2022
    This file contains installation instructions and compatibility information for NI-488.2 2022 Q4.
    • NI-488.2 Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-488.2 Documentation: New features, behavior changes, and other documentation
    Device Configuration
    Linux Limitations
    FAQs
    Linux Limitations
    NI-488.2 for Linux software for the Linux/x86 64-bit architecture has been tested on the following distributions:
    • openSUSE Leap 15.4
    • openSUSE Leap 15.3
    • Red Hat Enterprise Linux 9
    • Red Hat Enterprise Linux 8
    • Ubuntu 22.04
    • Ubuntu 20.04
    NI-488.2 for Linux requires a 64-bit distribution and does not support 32-bit applications.
    NI provides a repository add-on for all supported drivers that you can install using your Linux distribution's native package manager.
    • For detailed instructions, refer to Download and Install NI Driver Software on Linux Desktop on ni.com.
    • Download the installer for the repository add-on for your Linux distribution.
    • Install the repository add-on using the rpm command.
    • Select and install the following NI-488.2 for Linux driver package through your Linux distribution's package manager:
      • ni-488.2
      • libni4882-devel (optional, C and C++ support)
      • ni-488.2-iotrace-support (optional, NI IO Trace support)
    After the driver package(s) are installed, you must rebuild the new packages for the system kernel. NI recommends that you run the command 'dkms autoinstall' after installation, and before rebooting the system, to install the latest revision of all modules that have been installed for other kernel revisions. After doing so, the installed device drivers will function immediately on the next system start.
    Description of Utilities
    gpibexplorerGPIB Explorer is used to browse, configure, add, and delete GPIB interfaces.
    gpibtswGPIB Troubleshooting Wizard is used to verify your hardware and software installation.
    gpibintctrlGPIB Interactive Control is used to communicate with GPIB devices interactively.
    C/C++ Language Interface
    ni4882.hNI-488.2 header file
    libni4882.soDynamic library
    libni4882.aObject file that allows explicit loading of libni4882.so
    To configure a supported GPIB interface, refer to the Installation Guide located in /usr/share/doc/ni-488.2-documentation.
    To have the ni4882 library loaded explicitly when the program makes the first call into the library:
    gcc prog.c libni4882.a -ldl
    g++ prog.cpp libni4882.a -ldl
    For more NI-488.2 API use examples, refer to /usr/share/ni4882/examples/README.
    You can access NI-488.2 Help from GPIB Explorer.
    Linux Limitations
    Some features discussed in the NI-488.2 for Linux documentation are unavailable on Linux.
    NI-488.2 supports the two application development environments:
    • LabVIEW 2019, LabVIEW 2020, and LabVIEW 2021
    • C and C++ (gcc)
    NI-488.2 for Linux does not support 32-bit LabVIEW, LabVIEW Real-Time Module, or LabWindows/CVI ADEs.NI-488.2 for Linux supports the NI-VISA APINI-488.2 does not provide the Measurement and Automation Explorer (MAX) graphical configuration utility that is available for other operating systems. To configure a supported GPIB interface, refer to the Installation Guide located in /usr/share/doc/ni-488.2-documentation.NI-488.2 software for Linux does not support power management. You must disable the power management settings or make sure all GPIB handles are offline before the system enters the power management modes.NI-488.2 software for Linux does not work with the fork() system call. Specifically, the interface and device handles opened by the parent process are not properly inherited by the child process. Any attempt to use already opened handles in the child process will result in a Segmentation Fault for the child process. A workaround is either to open a new interface/device handle in the child process or to use threads instead of processes to implement multitasking. Linux provides a POSIX-compliant thread library called pthreads.FAQs
    Q1: When I try to open Help from GPIB Explorer, I am prompted for my default web browser. What does this do?
    A1: This problem only occurs on systems where htmlview is not installed. Each user's response to this dialog box is stored in ~/natinst/.lvbrowser (where ~ is the user's home directory). If you need to change this response, you can edit this file or just delete it so that you will be prompted again when entering help.
    Q2: Why can't I discover a GPIB-ENET/1000 device in GPIB Explorer?
    A2: It is likely that your firewall is blocking the discovery of the device. You can get around this by disabling the firewall during discovery. This can be reverted after you have added the device.
    Q3: Launching gpibintctrl through GPIB Explorer causes the text utility to launch twice in different terminals.
    A3: This problem is due to a bug (#646317 bugzilla) in gnome-terminal (2.32.1-6.1). This causes GPIB Explorer to believe that gnome-terminal has failed to launch, so it re-launches the utility in another terminal. You can either close the duplicated window or update gnome-terminal to version 3.2.1 or above.
    © 2007–2022 National Instruments Corporation. All rights reserved.
    • Notices are located in the /usr/share/doc/ni-488.2/NOTICES directory.
    • EULAs are located in the /usr/share/ni/licenses directory.
    For patents covering the NI products/technology, refer to the NI Patent Notice at ni.com/patents.
    GMT+8, 2025-5-13 11:39
