查看: 1870|回复: 0
[NI驱动程序] NI-Digital Pattern Driver 2022 Q4 Win11 32/64bitEng NI数字向量仪器驱动程序22.8下载
    10 小时前
  • 签到天数: 3816 天
    连续签到: 9 天
     楼主| 发表于 2022-11-18 14:41:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    从NI-Digital Pattern Driver 21.0版本开始,仅支持64位的Win10/WinServer 2016/WinServer 2019系统,但是仍然支持64位系统下的32位LabVIEW。自2022Q4V22.8版本开始,支持Win11操作系统。
    发布日期:2022/10/12
    包含的版本:22.8.0
    受支持的操作系统
    语言:英文
    文件大小: 2060156928 字节 (1.92 GB)
    修改日期: 2022-10-13 09:51
    MD5: 6e5d8e8231d762dc40ac81f2c99ae264
    SHA1: 06559c7fe13210a269f6044f2a31e17d7c959efb
    SHA256: aaa61be1730347a66758fff2f539f5e862b7fce7abb0836566d578ebcc2a1be4
    CRC32: 0cc3382c
    注册登录视觉论坛,购买附件查看下载地址
    NI-Digital 2022Q4.txt (541 Bytes, 下载次数: 0, 售价: 10 圆)
    Digital Pattern Instrument, NI-Digital Pattern Driver, and Digital Pattern Editor 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for the Digital Pattern Instrument, the NI-Digital Pattern Driver, and the Digital Pattern Editor.
    • NI-Digital Pattern Driver Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Digital Pattern Driver Documentation: New features, behavior changes, and other documentation
    Accessing Documentation
    Use the Digital Pattern Editor with a Digital Pattern Instrument and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs).
    System RequirementsMinimum System Requirements
    • RAM—4 GB
    Recommended System
    • RAM—8 GB
    The NI-Digital Pattern Driver and the Digital Pattern Editor support the following operating systems with all available critical updates and service packs:
    Note NI-Digital Pattern Driver and the Digital Pattern Editor no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Note:  Refer to your ADE documentation for more information about creating a runtime deployment:
    • LabVIEW - "Building and Distributing Applications"
    • NI TestStand - "Deploying TestStand Systems"
    • Microsoft Visual Studio - "Deploying the .NET Framework and Applications"
    Note:  The Digital Pattern Editor does not support Guest user accounts on Windows.
    Note:  NI recommends that you install Microsoft Hotfix 2588507 for 64-bit Windows operating systems. Visit ni.com/r/mshotfix for more information about Microsoft Hotfix 2588507.
    Install Application Development Environments (ADEs), such as LabVIEW or Microsoft Visual Studio, before installing the NI-Digital Pattern Driver. To add support for ADEs installed after installing the NI-Digital Pattern Driver, modify your NI-Digital Pattern Driver installation or launch the NI-Digital Pattern Driver installer again.
    NI-Digital Pattern Driver and Digital Pattern Editor 2022 Q4 support the following ADE versions:
    Versions Supported by NI-Digital Pattern Driver and Digital Pattern Editor 2022 Q4
    LabVIEW2019 and later [1]
    NI TestStand2016 and later (64-bit)
    NI TestStand Semiconductor Module™2016 and later (64-bit)
    Microsoft Visual Studio2010 and later (.NET versions 4.0 and 4.5)
    Note:  You must install the NI-DCPower driver to access NI-DCPower-related functionality in the Digital Pattern Editor.
    Note:  You must install the NI-Sync driver to access NI-Sync-related functionality.
    If you are using the NI-Digital .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-Digital .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    Download the NI-Digital Pattern Driver installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the NI-Digital Pattern Driver and Digital Pattern Editor. For more information on NI-Digital Pattern Driver and Digital Pattern Editor activation, refer to NI Software Activation.
    Accessing the APILabVIEW
    The NI–Digital Pattern Driver palette VIs are available from the following location:
    • LabVIEW 2019 and later—Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    .NET Class Library
    C
    You can use the NI-Digital Pattern C dynamically linked library by adding a reference to C:\Program Files\IVI Foundation\IVI\Bin\niDigital_64.dll for 64-bit development.
    The "NI-Digital Pattern Driver Support for LabVIEW" package supports applications using NI-Digital Pattern Driver ​with LabVIEW 2022 or later [1]. When you install NI-Digital Pattern Driver on LabVIEW 2022 or later, this package is recommended and will install to the LVAddons directory.
    [1] Although NI-Digital Pattern Driver 2022 Q4 supports LabVIEW versions 2019 and later, applications that also require the LabVIEW FPGA Module are limited to LabVIEW versions 2020, 2021, or 2022 Q3.
    Refer to NI-Digital Help, accessible from Help»LabVIEW Help..., for information about using NI-Digital with LabVIEW. The installed documentation set is composed of the following document:
    • Digital Pattern Help—Contains information about using the Digital Pattern Editor with a Digital Pattern Instrument and NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). Includes references for the NI-Digital Pattern Driver VIs and properties, the NI-Digital Pattern Driver C functions, and the NI-Digital Pattern .NET Class Library.
    Digital Pattern Instrument manuals are available as PDFs. You must have Adobe Acrobat Reader installed to view the PDFs. You can install the viewer from www.adobe.com/acrobat.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/docs. Digital Pattern Instrument manuals include the following documents:
    • PXIe-6570 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6570.
    • PXIe-6570 Specifications—Lists technical specifications for the PXIe-6570.
    • PXIe-6570 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6570.
    • PXIe-6571 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6571.
    • PXIe-6571 Specifications—Lists technical specifications for the PXIe-6571.
    • PXIe-6571 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6571.
    Use the getting started examples, located by default in the \National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    LabVIEW Examples
    Microsoft .NET Examples
    The Microsoft .NET examples are located in the \National Instruments\NI-Digital\Examples\DotNET 4.x directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    C Examples
    The C examples are located in the \National Instruments\NI-Digital\Examples\C directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    The NI-Digital Pattern Driver and the Digital Pattern Editor no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-3-5 19:10
