查看: 1731|回复: 0
[NI驱动程序] NI-Industrial Communications for DeviceNet 2022 Q4 Win11 32bitEng NI-DNet设备网络工业通信软件驱动程序22.8
    4 小时前
  • 签到天数: 3810 天
     楼主| 发表于 2022-11-18 15:28:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI DeviceNet工业通信软件
    NI-Industrial Communications for DeviceNet可帮助您配置和控制DeviceNet网络上DeviceNet设备。
    NI-Industrial Communications for DeviceNet是一种驱动程序软件,为您使用DeviceNet接口设备、C系列DeviceNet接口模块和PXI DeviceNet接口模块提供所需的支持。它包含丰富的LabVIEW VI和属性库,因此您可以为兼容的硬件设备创建自定义的DeviceNet应用程序。
    发布日期:2022/10/12
    包含的版本:22.8.0完整版
    应用程序位数:32位
    校验和
    文件大小: 1203705856 字节 (1.12 GB)
    修改日期: 2022-10-13 09:51
    MD5: f5269ea6d43a3a16683d9025f3247920
    SHA1: 8756f81b2f737164d1d5e406d5dcdb15e33f662a
    SHA256: a0bc01acc53a7683a620c885f1339970f7c734df1d00ed035632c2f3aeeb9e39
    CRC32: 0c67ad3e
    注册登录视觉论坛账号,购买附件查看下载地址
    NI-DNET 2022Q4.txt (571 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for DeviceNet 2022 Q4 Readme
    October 2022
    This file contains important information about NI-Industrial Communications for DeviceNet for Windows and LabVIEW Real-Time environment, including supported application software and hardware, installation instructions, and new features.
    • NI-Industrial Communications for DeviceNet Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Industrial Communications for DeviceNet Manuals: New features, behavior changes, and other documentation
    Caution   The NI-Industrial Communications for DeviceNet 18.0 software or later requires the NI-9882 module with the updated firmware. When you upgrade your software to the 18.0 version or later, check the software version of the media shipped with your NI-9882 module. If the version is not 18.0 or later, or you are not sure of the version number, NI recommends that you update the firmware. Otherwise, when you use NI-Industrial Communications for DeviceNet 18.0 or later, firmware images corrupt or get mismatched. Ensure that you have appropriate hardware and software installed and complete the following task to update the firmware.
    • Double-click Firmware_Update_Instructions.html in the \NI-IndCom for DeviceNet directory and follow the instructions to use a LabVIEW example project to update the firmware.
    Compatibility with NI-DNET 1.x
    The NI-Industrial Communications for DeviceNet software provides the DeviceNet driver and VIs for you to configure and control DeviceNet devices on a DeviceNet network and to communicate with FPGA targets.
    NI-Industrial Communications for DeviceNet supports the following operating systems:
    Note    NI-Industrial Communications for DeviceNet no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    Refer to KB 6CCA8MEG, Supported Hardware and Software for NI-Industrial Communications for DeviceNet, for a complete list of NI hardware and software supported by each version of the NI-Industrial Communications for DeviceNet.
    The maximum number of devices you can connect to a DeviceNet interface depends on the electrical characteristics of the devices on the network. If all of the devices on the network meet the DeviceNet specifications, you may connect 64 devices to the network.
    Caution  The NI-Industrial Communications for DeviceNet software does not support the previous generation of the DeviceNet hardware products such as NI PCI-DNET, NI PCMCIA-DNET, and NI PXI-8461/D. Those products require an NI-DNET 1.x driver.
    The following table lists the application software versions, including service packs, supported by NI-Industrial Communications for CANopen. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-Industrial Communications for CANopen
    LabVIEW2019 or later
    LabVIEW Real-Time Module2019 or later
    Download the NI-Industrial Communications for DeviceNet installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installing the Software on the RT Target
    Complete the following steps to install the NI-Industrial Communications for DeviceNet software on the RT target in NI Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand the RT target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the RT target is a CompactRIO controller, select the Custom software installation option.
    • Select the NI-IndCom for DeviceNet item in the feature list and click the Next button.
    • Follow the remaining installation instructions until installation is complete.
    The "NI-Industrial Communications for DeviceNet Support for LabVIEW" package supports applications using NI-Industrial Communications for DeviceNet ​with LabVIEW 2022 or later. When installing NI-Industrial Communications for DeviceNet, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    New FeaturesDeviceNet 2022 Q4
    • Added support for LabVIEW 2022 (32-bit) and LabVIEW 2022 Real-Time Module.
    DeviceNet 21.5
    • Added support for LabVIEW 2021 (32-bit) and LabVIEW 2021 Real-Time Module.
    • Added support for PXI and PXIe controllers with NI Linux RealTime through .ipk installation
    DeviceNet 20.0
    • Added support for LabVIEW 2020 (32-bit) and LabVIEW 2020 Real-Time Module.
    The following are the behavior changes in DeviceNet 2022 Q4 from DeviceNet 21.5.
    • Extended the LabVIEW version support with NI Linux RealTime to include LabVIEW 2020 and later.
    Refer to the NI-Industrial Communications for DeviceNet Help, accessible by selecting Help»NI-Industrial Communications for DeviceNet in LabVIEW, for information about using the NI-Industrial Communications for DeviceNet software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the NI-Industrial Communications for DeviceNet software are in the labview\examples\NI-Industrial Communications for DeviceNet folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    NI-Industrial Communications for DeviceNet 2.1 or later is not an update for NI-DNET 1.x and the two products can be installed on the same system side by side. DeviceNet 2.1 or later provides NI-DNET 1.x compatible VIs, so the application using NI-DNET 1.x VIs can work with DeviceNet 2.1 or later on PCI-8532, PXI-8532 and NI 9882 with very limited code change.
    © 2009–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-27 13:33
