查看: 1471|回复: 0
[NI驱动程序] NI-RDMA 2022 Q4 Win11 32/64bitEng NI远程直接内存访问22.8
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2022-11-18 16:12:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RDMA
    NI-RDMA支持远程直接内存访问(RDMA)可兼容的网络接口控制器。
    NI-RDMA是一种驱动软件,它为两个或多个使用RDMA技术的系统在以太网上交换数据提供支持。此外,NI-RDMA提取出了对RDMA可兼容接口进行编程的低级细节,并为传输数据提供了简单而高效的API。
    NI-RDMA 2022 Q4
    发布日期:2022/10/12
    包含的版本:22.5.0完整版
    文件大小: 1125752832 字节 (1.05 GB)
    修改日期: 2022-10-13 09:53
    MD5: 2dabde76d1f50a57dfd7cc082840233f
    SHA1: e5dda324a6c640b95638b49660f1a617f90d986e
    SHA256: 8cb6896f835062b0df91a6555862e241ab1c9ac04b912501ed8eda55738b8d87
    CRC32: 23651e3f
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI-RDMA 2022Q4.txt (514 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RDMA 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for NI-RDMA 2022 Q4.
    • NI-RDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RDMA Documentation: New features, behavior changes, and other documentation
    NI-RDMA is driver software that provides support for two or more systems to exchange data over Ethernet using remote direct memory access (RDMA) technology. This driver software features a simple and efficient API for transferring data. NI-RDMA supports RDMA-compatible network interface controllers.
    NI-RDMA 2022 Q4 supports the following operating systems:
    NI-RDMA 2022 Q4 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RDMA 2022 Q4
    LabVIEW2020, 2020 SP1, 2021, 2021 SP1, 2022
    LabVIEW Real-Time (RT)2020 and later
    Programming Languages
    Microsoft Visual C/C++Visual Studio 2003 and later
    Download the NI-RDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "NI-RDMA Support for LabVIEW" package supports applications using NI-RDMA ​with LabVIEW 2022 or later. When installing NI-RDMA, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    • Added support for LabVIEW 2022
    © 2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-23 12:13
