查看: 1545|回复: 0
[NI驱动程序] NI RF Signal Analyzers 2022 Q4 Win11 32/64bitEng NI PXI矢量信号分析仪驱动NI-RFSA 22.8.0
    15 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2022-11-21 11:11:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSA
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    文件大小: 4108920832 字节 (3.83 GB)
    修改日期: 2022-10-13 09:50
    MD5: 490d3df81fcdad512e78208863259314
    SHA1: 30c1e029443c7fc21040840314278ddc22458732
    SHA256: ea0473d3a9df3a1a0671530f6344dbd51536244397c9c838c4036f05fa6e9aa5
    CRC32: 8bdfb9aa
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFSA 2022Q4.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSA 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for NI-RFSA 2022 Q4.
    • NI-RFSA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSA Documentation: New features, behavior changes, and other documentation
    This software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    NI-RFSA 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022
    NI-RFSA 21.8 includes the following new feature:
    • Support for NI Linux® Real-Time
    • 4 GB RAM*
    • Windows 10 with all available critical updates and service packs
    NI-RFSA 2022 Q4 and NI-RFSA SFP 2022 Q4 support the following operating systems:
    • NI Linux® Real-Time
    Note NI-RFSA no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Versions Supported by NI-RFSA
    LabVIEW2019, 2020, 2021, and 2022
    LabWindows/CVI2019 and later
    LabVIEW Real-Time Module2021 and 2022
    Download the NI-RFSA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    You can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development.
    NI-RFSA SFP
    To launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel
    Documentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSA is located at Program Files\IVI Foundation\IVI\Drivers\niRFSA\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-RFSA no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-5 23:53
