查看: 1582|回复: 0
[NI驱动程序] NI RF Signal Generators 2022 Q4 Win11 32/64bitEng NI RF信号发生器NI-RFSG22.8
    7 小时前
  • 签到天数: 3731 天
     楼主| 发表于 2022-11-21 11:18:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    文件大小: 4623892480 字节 (4.31 GB)
    修改日期: 2022-10-13 09:53
    MD5: bd779d0260e4e0fb7e86487044e257d7
    SHA1: b5a0e32c6eda395f91c762b9e7a8dfc5cb9e4b30
    SHA256: b9e5e7fe5841ce512823bf003605016a560be899742c87eebd39c4a7ef9e1f14
    CRC32: 087ac43f
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFSG 2022Q4.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    暂未发布2022Q4版本自述说明,参考2022Q3版本:
    NI-RFSG 2022 Q3 Readme
    July 2022
    This file contains installation instructions and compatibility information for NI-RFSG.
    • NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Manuals: New features, behavior changes, and other documentation
    This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSG 2022 Q3 includes the following new feature:
    • Support for LabVIEW 2022
    NI-RFSG 21.8 includes the following new feature:
    • Support for NI Linux® Real-Time
    NI-RFSG 21.5 includes the following new feature:
    • Support for RF list mode on PXIe-5840/5841 for LO Source, Upconverter Frequency Offset Mode, and Signal Bandwidth attributes
    • 4 GB RAM*
    Note  NI-RFSG 2022 Q3 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2022 Q3.
    NI-RFSG and NI-RFSG SFP support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2019, 2020, 2021, and 2022
    LabWindows/CVI2018 to current
    LabVIEW Real-Time Module2021 and 2022
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Few other documentation for NI-RFSG is located at Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-3 15:54
