查看: 1193|回复: 0
[NI驱动程序] NI-RFSG Playback Library 2022 Q4 Win11 32/64bitEng NI-RFSG回放库22.8
    昨天 10:56
  • 签到天数: 3592 天
    连续签到: 12 天
     楼主| 发表于 2022-11-21 11:33:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    32/64位完整版校验和:
    文件大小: 477169664 字节 (455.06 MB)
    修改日期: 2022-10-13 09:54
    MD5: f4d7ed3bc9e99ce35a9984eaea6f8717
    SHA1: a852953771cd8014c0a494c3601409b5afd8ae07
    SHA256: 5368ea1b07d0718316935f2994aa3ba19076fb9f07b2e32a3bc7798ad2e09ea1
    CRC32: 3657906f
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-RFSG Playback Library 2022Q4 Full.txt (594 Bytes, 下载次数: 0, 售价: 10 元)
    32/64位运行版校验和:
    文件大小: 383653888 字节 (365.88 MB)
    MD5: 8591ef68136e3431425b987b11c55f33
    SHA1: 95b986d3d95842af7a96379c5b7b57d9f6f63621
    SHA256: a6315946ff454c5cf9ec5946720e1d07f7d8c680358235142b53107d00428ec4
    CRC32: 56679fb2
    NI-RFSG Playback Library 2022Q4 RTE.txt (600 Bytes, 下载次数: 0, 售价: 5 元)
    NI-RFSG Playback Library 2022 Q4 Readme
    October 2022
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    • NI-RFSG Playback Library Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Playback Library Manuals: New features, behavior changes, and other documentation
    NI-RFSG Playback Library allows users to generate waveforms saved in the technical data management streaming (TDMS) file using the NI-RFSG driver. These TDMS files can be created from the NI RFmx Waveform Creator. You can use the NI-RFSG Playback Library to download multiple waveforms to the NI-RFSG vector signal generator memory. You can then generate all these waveforms using either a single script or multiple scripts. The playback library internally retrieves waveform properties from database to calculate and apply appropriate settings on the NI-RFSG driver.
    NI-RFSG Playback Library 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    NI-RFSG Playback Library 2022 Q3 includes the following new features:
    NI-RFSG Playback Library 21.3 includes the following new features:
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 2022 Q4 supports the following 64-bit operating systems:
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-RFSG Playback Library (64-bit only)
    LabVIEW2019 SP1, 2020 SP1, 2021, 2022 Q3
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    Item
    Installed Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » National Instruments » NI-RFSG Playback Library Documentation.
    You can access all the installed NI-RFSG Playback Library examples at Start » National Instruments » NI-RFSG Playback Library Examples.
    GMT+8, 2025-7-13 16:28
