查看: 1730|回复: 0
[NI驱动程序] NI RMX-412x Power Supply Driver 1.0 Win32Eng NI RMX-412x可编程电源设备驱动程序1.0版下载 G语言
 楼主| 发表于 2022-11-21 14:44:33 | 显示全部楼层 |阅读模式
RMX-412x Power Supply Driver为RMX-412x设备提供支持。
RMX-412x Power Supply Driver是一款驱动软件,可以与RMX-412x系列可编程电源设备搭配使用。该驱动程序可支持通过将可编程仪器标准命令(SCPI)抽象化来简化常见任务的编程。RMX-412x Power Supply Driver还随附多个示例。
发布日期:2017/1/9
编程语言:G语言
包含的版本:1.0完整版
Windows 7
Windows 10
Windows 8.1
Windows XP
Windows 8
应用程序位数:32位
文件大小: 446598 字节 (436.13 KB)
修改日期: 2022-03-25 17:46
MD5: d4579e1bd82c076d4f0c36ec3695edd0(重复一致)
SHA1: e57facb2a7731d36a2a8a9a43c27be7817a4dda2
SHA256: 56ec61071f527830eacd9ace1a33130a6eadd83be44beb22d37b096125f8891f
CRC32: 2e4e32de
请注册登录视觉论坛账号,购买附件查看下载地址
NI-RMX-412x Power Supply Driver 1.0.txt (569 Bytes, 下载次数: 0, 售价: 10 圆)
National Instruments RMX-412X Series Instrument Driver Readme
1. Overview
Instrument Driver Technology:LabVIEW Plug and Play (project-style)Manufacturer:National Instruments
Supported Language(s):LabVIEWSupported Model(s):RMX-4120,RMX-4121,RMX-4122,RMX-4123,RMX-4124,RMX-4125,RMX-4126,RMX-4127
Model(s) Tested:RMX-4124
Interface(s):GPIB, USB, Ethernet
Firmware Revision(s) Tested:
Certified:Yes
NI Supported:Yes
Source Code Available:Yes
Driver Revision:1.0
Original Release Date:12/09/2016
Current Revision Date:12/09/2016
2. Required Software
Some software components need to be installed before using this instrument driver. The minimum versions of these components are listed below, and can be downloaded from the Download Site.
The support software required by the driver: VISA 5.0 or later
LabVIEW Help
For LabVIEW 8.2 and LabVIEW 2009 Refer to the LabVIEW Help for more information about software requirements. You access the LabVIEW Help by selecting Help»Search the LabVIEW Help.
For LabVIEW 2010 or later Refer to the LabVIEW Help for more information about software requirements. You access the LabVIEW Help by selecting Help»LabVIEW Help.
3. Known Issues
    Instrument Multichannel Setup
  • The instruments must be configured for multichannel setup using the instrument front panel, selecting a master and slave units.
  • Then instruments must be restarted, turning on the slave units first and the master unit last.
  • Please see the users manual and programmers manual for details on how to configure a multichannel setup.
4. Revision History
REV 1.0, 12/09/2016
Modified by: Madeline Stager and Ilan Buzzetti, Austin,TX.
Original release.
QQ|LabVIEW视觉
GMT+8, 2026-4-8 15:31
