查看: 1495|回复: 0
[NI驱动程序] NI-SCOPE .NET Class Libraries 1.1.0 Win32/64Eng NI示波器.NET驱动1.1.0
    27 分钟前
  • 签到天数: 3750 天
     楼主| 发表于 2022-11-21 15:55:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SCOPE .NET Class Libraries为特定NI示波器提供.NET支持。
    NI-SCOPE .NET Class Libraries是一款驱动软件,旨在扩展NI-SCOPE仪器驱动的功能。该软件支持.NET应用程序与所有支持的NI示波器设备和PXI示波器之间的通信。此外,该软件提供兼容可互换虚拟仪器(IVI)类的.NET API接口,并提供一组支持特定NI示波器功能的操作和属性。NI-SCOPE .NET Class Libraries需要安装NI-SCOPE仪器驱动才能运行。
    发布日期:2008/3/1
    包含的版本:1.1.0完整版
    Windows Vista 64-bit
    Windows Vista
    Windows XP
    文件大小: 26268377 字节 (25.05 MB)
    修改日期: 2022-03-25 22:53
    MD5: f358426f070d9de84fc0b7e70e8b70f0(官方正确)
    SHA1: 7e5d34b8506abf725f01f9f35fc79294c4447c4a
    SHA256: e08ab6c3b75fb1f7a894ef0fa58cb7358b597f3a9cac66018b25af2cd26d16d4
    CRC32: 1d94d154
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-SCOPE .NET Class Libraries1.1.0.txt (556 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE .NET Class Libraries 1.1 Readme
    This section describes new features that have been introduced in NI-SCOPE .NET Class Libraries 1.1.
    Support for Onboard Signal Processing
    For more information about fetching complex data, refer to Using Single Record Complex Reader and Using Multiple Record Complex Reader in the NI Measurement Studio Help.
    Memory Optimized Read Methods
    For more information about memory optimized read methods, refer to Using Memory Optimized Methods in the NI Measurement Studio Help.
    Documentation Updates
    This section lists the minimum system requirements and the recommended system requirements for using the NI-SCOPE .NET Libraries.
    Note    NI-SCOPE .NET Libraries will not install if the Microsoft .NET Framework 2.0 is not installed. The installer also gives a warning if the NI-SCOPE 3.4 or later instrument driver is not installed.
    Minimum System Requirements
    • Pentium 200 MHz or equivalent processor
    • 64 MB RAM
    • NI-SCOPE 3.4 driver or later—If you have an earlier version of NI-SCOPE installed, refer to ni.com/idnet to download the correct version.
    • Microsoft .NET Framework 2.0
    • Windows XP
    Recommended System Requirements
    • Pentium III/Celeron 600 MHz or equivalent processor
    • 256 MB RAM
    • A screen resolution of 640×480 with 256 colors
    • Windows Vista SP1/XP with all available critical updates and service packs installed
    • Microsoft Visual Studio 2005 with all service packs installed— required only for design-time support
    Installing NI-SCOPE .NET Class Libraries
    The .NET class libraries for NI-SCOPE include a .NET API for NI-SCOPE, NI-TClk, and NI-ModInst instrument drivers. These class libraries provide a .NET interface to the underlying driver API.
    Note    This installation does not include any instrument drivers. You must install the NI-SCOPE 3.4 or later instrument driver for the NI-SCOPE .NET Class Libraries 1.1 to function.
    You can find examples for NI-SCOPE in Start»All Programs»National Instruments»NI-SCOPE»Examples».NET 2.0 Languages Support.
    .NET Class Libraries for NI-SCOPE
    Frequently Used Classes: ScopeSession, ScopeSingleRecordMeasurementReader, ScopeSingleRecordReader, ScopeMultipleRecordMeasurementReader, and ScopeMultipleRecordReader.
    Namespace: NationalInstruments.ModularInstruments.SystemServices.TimingServices
    Description: Uses the NI-SCOPE .NET classes to synchronize modular instrument devices.
    Note    If Visual Studio 2005 is installed, you can access the NI-TClk components from the Measurement Studio group on the Visual Studio Toolbar. Select View»Toolbar and expand the Measurement Studio group to access the NI-TClk components.
    .NET Class Libraries for NI-ModInst
    Frequently Used Classes: ModularInstrumentsSystem and DeviceInfo
    NI-SCOPE .NET Class Libraries 1.1 installs the following files to the following locations:
    Item
    Default Installed Location
    ([INSTALLDIR]=Program Files\National Instruments\MeasurementStudioVS2005)
    Assemblies
    [INSTALLDIR]\DotNET\Assemblies\Current\
    NationalInstruments.ModularInstruments.Common.dll
    NationalInstruments.ModularInstruments.ModularInstrumentsSystem.dll
    NationalInstruments.ModularInstruments.Scope.dll
    NationalInstruments.ModularInstruments.TClock.dll
    Global Assembly Cache (GAC)
    NationalInstruments.MeasurementStudio.dll
    NationalInstruments.MeasurementStudio.Interfaces80.dll
    NationalInstruments.ModularInstruments.Scope.Design.dll
    NationalInstruments.ModularInstruments.TClock.Design.dll
    [INSTALLDIR]\Common\Scope
    Examples — Each example has C# and VB subdirectories corresponding to Visual C# and Visual Basic .NET. By default, [IVIDIR] is C:\Program Files\IVI.
    [IVIDIR]\Drivers\niScope\Examples\DotNET2.0
    [IVIDIR]\Drivers\niModInst\Examples\DotNET2.0
    Redistributables
    C:\Program Files\Common Files\Merge Modules\NIModularInstrumentsCommon.2005.msm
    C:\Program Files\Common Files\Merge Modules\NIModularInstrumentsSystem.2005.msm
    C:\Program Files\Common Files\Merge Modules\NIScope.2005.msm
    C:\Program Files\Common Files\Merge Modules\NITClock.2005.msm
    NationalInstruments.ModularInstruments. ToolboxInstaller.exe — Installs NI-SCOPE components into the Visual Studio 2005 Toolbox
    [INSTALLDIR]\Common
    Help
    [INSTALLDIR]\Help
    Uninstalling or Modifying NI-SCOPE .NET Class LibrariesUsing Windows XP
    For Windows Vista, complete the following steps:
    • Launch the Control Panel by selecting Start » Control Panel.
    • Double-click Programs and Features
    • Select NI-SCOPE .NET 1.1 Class Library from the dialog box that appears.
    Caution    Do not attempt to uninstall by deleting files, which may be shared with other programs.
    Bug Fixes in NI-SCOPE .NET Class Libraries 1.1
    © Copyright 2006-2008 National Instruments Corporation. All rights reserved.
    To comment on National Instruments documentation, refer to the National Instruments Web site.
    GMT+8, 2025-12-23 08:49
