查看: 1492|回复: 0
[NI驱动程序] NI-SCOPE .NET Class Libraries 2.0 Win32/64Eng NI示波器.NET驱动2.0
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2022-11-21 16:06:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SCOPE .NET Class Libraries为特定NI示波器提供.NET支持。
    NI-SCOPE .NET Class Libraries是一款驱动软件,旨在扩展NI-SCOPE仪器驱动的功能。该软件支持.NET应用程序与所有支持的NI示波器设备和PXI示波器之间的通信。此外,该软件提供兼容可互换虚拟仪器(IVI)类的.NET API接口,并提供一组支持特定NI示波器功能的操作和属性。NI-SCOPE .NET Class Libraries需要安装NI-SCOPE仪器驱动才能运行。
    发布日期:2013/10/30
    包含的版本:2.0完整版
    Windows 7
    Windows Server 2008 R2 64-bit
    Windows Server 2003 R2 32-bit
    Windows XP (SP3) 32-bit
    Windows Vista
    Windows 8
    文件大小: 226149152 字节 (215.67 MB)
    修改日期: 2022-03-25 22:59
    MD5: a1e43e0a1582cbc9cde5d9803bce4481(官方正确)
    SHA1: c83686842dd57508aec4f405fb93b7e47c236211
    SHA256: 57487e6dd7b07475778e541bfd7326496a11640150cfba582fdce28f2f8fd9f4
    CRC32: 9f619280
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-SCOPE .NET Class Libraries2.0.txt (580 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SCOPE .NET Class Library 2.0.0 for Visual Studio 2012 Readme
    The .NET class library for NI-SCOPE support the 4.1 version of NI-SCOPE driver.
    For more information about NI-SCOPE .NET Class Library, refer to the Measurement Studio Support for NI-SCOPE Overview topic in the NI Measurement Studio Help. Select Start»All Programs»National Instruments»NI-SCOPE»Documentation to view the help.
    This section lists the system requirements and installation instructions for the NI-SCOPE .NET Class Library.
    Installation Requirements
    You can view the NI-SCOPE .NET class libraries Help from within the Microsoft Help Viewer by performing any one of the following:
    • Launch the Help Viewer from the NI-SCOPE folder within the NI Launcher in Windows 8.
    • Select Help»View Help from the Visual Studio menu.
    To deploy an application built with the NI-SCOPE .NET 4.5 Class Library, the target computer must have a Windows 8 (32-bit or 64-bit)/Windows 7 (32-bit or 64-bit)/Server 2008 R2 (64-bit) operating system and .NET Framework 4.5.
    Deployment Notes for Visual Studio 2012
    NI-SCOPE .NET Class Library installs files in the following locations:
    [NIPUBDOCS] is an alias for the following National Instruments file folder location:
    • Windows 8/Windows 7: C:\Users\Public\Documents\National Instruments
    [Program Files] is an alias for the following file folder location:
    • Windows 8 (64-bit)/Windows 7 (64-bit): C:\Program Files (x86)
    • Windows 8 (32-bit)/Windows 7 (32-bit): C:\Program Files
    The following are known issues in NI-SCOPE .NET Class Library 2.0.0
    • Uninstalling NI-SCOPE .NET Class Library does not uninstall the NI-SCOPE .NET API Help from Visual Studio.
    • The NI-SCOPE .NET examples may produce a warning - "Warning: Found conflicts between different versions of the same dependent assembly". You can safely ignore this warning. This has been explained in the following KnowledgeBase article.
    • The installer displays the message 'Installing Help', and installs help for the dependencies, even if you did not select Documentation during driver installation.
    • The installer displays the message 'Integrating Help into Visual Studio' even if Visual Studio is not installed on your computer.
    • Since PrecisionTimeSpan stores fractional seconds as fractional second ticks (2^(-64) seconds), some rounding may occur when initializing a new PrecisionTimeSpan instance.
    • This installer includes version 1.4 of NationalInstruments.ModularInstruments.Common.dll, which is not compatible with earlier versions. This incompatibility can cause compile or run time errors in some circumstances when you use types from NationalInstruments.ModularInstrument.Common.dll directly in your program. Refer to the following Knowledge Base article for more information.
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start page or the Taskbar on the desktop, as necessary:
    Current Application
    Icon Location
    Pin to Action
    Windows 8 Desktop
    Desktop Taskbar
    Right-click application and select Pin to Taskbar
    Windows 8 Desktop
    Start page
    Right-click application and select Pin to Start
    Windows 8 Start page
    Desktop Taskbar
    Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    Important Information
    © 2006–2013 National Instruments. All rights reserved.
    To comment on National Instruments documentation, refer to the National Instruments Web site.
    GMT+8, 2025-7-23 12:14
