查看: 1641|回复: 0
[NI驱动程序] NI-SLSC 2022 Q4 Driver Win11 32/64bitEng NI开关负载信号调理设备驱动22.8版下载
    昨天 08:37
  • 签到天数: 3764 天
    连续签到: 15 天
     楼主| 发表于 2022-11-21 16:19:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    文件大小: 1250316288 字节 (1.16 GB)
    修改日期: 2022-10-13 09:54
    MD5: a96b07d004c5ecb29fb249390e053aa4
    SHA1: 1ce32b9b9df1ae7a87867d0dedebcc6b1756efd2
    SHA256: d0d5a33221833eaede571959f35e235322c347ae4d9430d9e65e2b88655cc6fb
    CRC32: e175121b
    请注册登录视觉论坛账号,购买附件查看下载地址
    NI-SLSC 2022Q4.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SLSC 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for NI-SLSC 2022 Q4.
    • NI-SLSC Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SLSC Documentation: New features, behavior changes, and other documentation
    NI-SLSC 2022 Q4 supports the following operating systems:
    • NI Linux® Real-Time
    NI-SLSC 2022 Q4 supports the following application software versions, including service packs.
    Versions Supported by NI-SLSC
    LabVIEW2019 and later
    LabVIEW Real-Time Module2019 and later
    Download the NI-SLSC installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    The "NI-SLSC Support for LabVIEW" package supports applications using NI-SLSC ​with LabVIEW 2023 or later. When installing NI-SLSC, this package will be recommended if you have already installed LabVIEW 2023 or later and installs to the LVAddons directory.
    The default device reservation timeout for the SLSC Initialize and SLSC Reserve nodes has been increased to five seconds. This change improves the robustness of device reservation in typical scenarios. Previously, the default reservation timeout value was zero seconds.
    For existing code that does not explicitly wire a reservation timeout, this change could cause the program to stall for up to 5 seconds upon an attempted reservation (a stall will occur only if the device in question is already reserved). If desired, the previous behavior can be restored by explicitly setting the timeout to zero seconds.
    Refer to the NI-SLSC Help, accessible by navigating to the Start»National Instruments»NI-SLSC Documentation, for information about the NI-SLSC driver software. You can also refer to the NI-SLSC VI Reference Help, accessible by selecting Help»NI-SLSC VI Reference Help in LabVIEW, for information about SLSC VIs.
    NI-SLSC no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2016–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-7 02:16
