查看: 2257|回复: 0
[NI软件产品] NI Automotive Diagnostic Command Set Toolkit 2022 Q4 Win11 32/64bitEng 汽车诊断命令集工具包ADCS22.8
    6 小时前
  • 签到天数: 3775 天
    连续签到: 26 天
     楼主| 发表于 2022-11-22 10:19:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    汽车诊断命令集工具包Automotive Diagnostic Command Set Toolkit
    汽车诊断命令集工具包为ECU生产测试设计和开发汽车诊断应用程序。
    汽车诊断命令集(ADCS)工具包是LabVIEW、LabWindows/CVI和Microsoft Visual Studio的软件附件。该附件适用于一系列汽车诊断应用,通常包括读取和写入参数、访问故障诊断代码(DTC)、闪存ECU固件以及启动ECU诊断测试模式。借助ADCS工具包,您可以开发单个应用程序,并根据需要随时进行部署,而无需额外部署或runtime许可证。该附件与许多NI汽车接口设备兼容,可简化各种便携式和车载诊断应用的开发,并提供对UDS、OBD、WWH-OBD等协议的支持。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    发布日期:2022/10/12
    包含的版本:22.8.0完整版
    文件大小: 1205118976 字节 (1.12 GB)
    修改日期: 2022-10-13 09:50
    MD5: a21f4e64545a15bf96d80848c5d13ff1
    SHA1: 74f802862de2dfe4a645df49a2f28b723cc31664
    SHA256: 392080e297e99b3cea4c8a975b0e7965108d9d2080793a6623b2ae33b88e32c1
    CRC32: 3f469cce
    请注册登录视觉论坛账号,购买附件查看下载地址
    ADCS 2022 Q4.txt (545 Bytes, 下载次数: 1, 售价: 10 圆)
    Automotive Diagnostic Command Set Toolkit 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for Automotive Diagnostic Command Set Toolkit 2022 Q4.
    • Automotive Diagnostic Command Set Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Automotive Diagnostic Command Set Toolkit Documentation: New features, behavior changes, and other documentation
    ECU Simulator
    Using NI-XNET with the Automotive Diagnostic Command Set Toolkit
    Additional Programming Topics and Known Issues
    The Automotive Diagnostic Command Set Toolkit helps you design and implement automotive diagnostic applications for ECU production test.
    Automotive Diagnostic Command Set Toolkit 2022 Q4 supports the following operating systems:
    Note  Automotive Diagnostic Command Set Toolkit no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Automotive Diagnostic Command Set Toolkit 2022 Q4 supports the following application software versions, including service packs.
    Versions Supported by Automotive Diagnostic Command Set Toolkit 2022 Q4
    LabVIEW2019 and later
    LabVIEW Real-Time Module2019 and later
    Microsoft Visual C/C++2008 and later
    Note  Automotive Diagnostic Command Set Toolkit software does not support LabWindows™/CVI™ Real-Time Module.
    Download the Automotive Diagnostic Command Set Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • If applicable, install an application development environment (ADE), such as LabVIEW, LabWindows/CVI, or Microsoft Visual Studio.
    • MSVC and LabWindows/CVI users should always install the MSVC Support feature.
    The "Automotive Diagnostic Command Set Toolkit Support for LabVIEW" package supports applications using Automotive Diagnostic Command Set Toolkit ​with LabVIEW 2022 or later. When installing Automotive Diagnostic Command Set Toolkit, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    • Added support for LabVIEW 2022 Q3.
    Refer to the Automotive Diagnostic Command Set Toolkit Help, accessible from \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Documentation, for information about Automotive Diagnostic Command Set.
    The help includes an introduction to diagnostic protocols. It also explains how to get started with application development and includes a complete reference forall Automotive Diagnostic Command Set Toolkit functions.
    ECU Simulator
    The Automotive Diagnostic Command Set Toolkit software provides an ECU simulation for CAN and LIN. All examples of the Automotive Diagnostic Command Set Toolkit are preconfigured to communicate with the ECU simulation.
    • Until LabVIEW 2021 users can find the ECU simulator under \\examples\Automotive Diagnostic Command Set\ADCS Demo ECUs.llb.
    • From LabVIEW 2022 and later ECU Simulator can be found under LVAddons directory C:\Program Files\NI\LVAddons.
    Microsoft Visual C/C++ and LabWindows/CVI users can find the ECU simulators at
    • \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C\ADCS Demo ECU CAN Ethernet, or
    • \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C\ADCS Demo ECU LIN.
    The Automotive Diagnostic Command Set Toolkit software installs the necessary C/C++ support files in the following locations:
    • The typical path to the C examples folder is \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C.
    • The header file for Visual C/C++ 2008 and 2015 is in the Program Files\National Instruments\Shared\ExternalCompilerSupport\C\include folder.
    • The library file is in the Program Files\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc folder.
    Using the VW Transport protocol with NI-XNET:
    • If you are using the VW Transport Protocol on NI-XNET hardware, we suggest using the Frame Stream Input and Output Mode. Example: CAN1@ni_genie_nixnet uses CAN interface 1 on NI-XNET with Frame Stream Mode.
    Automotive Diagnostic Command Set Toolkit 20.0 has fixed parameter lists and calling conventions of a subset of functions introduced with Automotive Diagnostic Command Set Toolkit 19.0. Requires recompiling all C/C++/CVI applications built with Automotive Diagnostic Command Set 19.0 and using one of the following functions:
    • ndDoIPSendVehicleIdentReqEIDAllVersions
    • ndDoIPSendVehicleIdentRequestAllVersions
    • ndDoIPSendVehicleIdentReqVINAllVersions
    • ndDoIPGetEntitiesAllVersions
    • ndDoIPConnectVersion
    If you are using NI hardware that is supported by NI-XNET, it is recommended that you use NI-XNET 19.0 or later with this version of Automotive Diagnostic Command Set Toolkit.
    CAN FD support with the Automotive Diagnostic Command Set Toolkit
    CAN FD features are only supported with NI-XNET version 17.0.1 or later.
    Recommended Maximum Message Length for CAN FD
    NI recommends the following maximum message length for CAN FD based on the system RAM size.
    System RAM Size
    ≤512 MB8 MB
    512 MB – 3.5 GB64 MB
    >3.5 GB256 MB
    Automotive Diagnostic Command Set Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2009-2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-17 16:42
