查看: 1716|回复: 0
[NI软件产品] NI Battery Test System Software Toolkit 2022 Q4 Win11 64bitEng 电池测试系统软件工具包BTSST22.1.0
    4 小时前
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-11-22 12:23:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Battery Test System Software工具包包含了TestStand和VeriStand软件的软件组件,可与电池测试系统硬件一起使用。
    Battery Test System Software工具包是一款附加软件,可帮助您优化电池测试工作流程。此附加软件包括TestStand自定义步骤、TestStand流程模型插件、VeriStand自定义设备以及可以导入到VeriStand的配置。Battery Test System Software工具包还提供了一些示例项目,例如VeriStand项目和TestStand序列。此外,您可以使用提供的用户指南来学习如何使用所有随附的软件组件。
    NI Battery Test System Software Toolkit 2022 Q2
    发布日期:2022/10/11
    包含的版本:22.1.0完整版
    文件大小: 6890647552 字节 (6.42 GB)
    修改日期: 2022-10-11 21:48
    MD5: 55c310a2c34674b6247ad45b2e57dd93
    SHA1: 55cf754ec1b551a54b1ca0c8c6035ab7a983497b
    SHA256: 1f1c1625b1261422e9e90e53be01855b8b430053c8074f3ac89b5ff3aff05c29
    CRC32: a0311ebe
    请注册登录视觉论坛账号,购买附件查看下载地址
    BTSST22.1.0.txt (612 Bytes, 下载次数: 0, 售价: 20 圆)
    Battery Test System Software Toolkit 2022 Q4 Readme
    October 2022
    This file contains installation instructions and compatibility information for Battery Test System Software Toolkit 2022 Q4.
    Refer to the Battery Test System Software Toolkit Release Notes for additional information about this release, such as known issues and bugs fixed since the last release.
    Included Components
    Accessing Custom Devices
    The Battery Test System Software Toolkit is a software add-on that extends the NI platform to test electric vehicle (EV) battery packs and modules. The Battery Test System Software Toolkit helps you optimize your battery test workflow.
    Battery Test System Software Toolkit 2022 Q4 includes the following new features:
    • Added ability to reconnect from the Web UI to a running test
    Included Components
    Battery Test System Software Toolkit 2022 Q4 includes the following major components:
    • EVPTS Plugin for NI TestStand 2021 (64-bit)
    • VeriStand Steps for NI TestStand 2021 (64-bit)
    • Battery Test System Test Executor for NI TestStand
    • Custom Devices for NI VeriStand 2021, including:
      • Instrument Addon
      • Black Box Recorder
      • Embedded Data Logger
      • File Mover
      • Network DAQ
      • SystemLink
      • Scan Engine and EtherCAT
    Battery Test System Software Toolkit 2022 Q4 has the following minimum requirements:
    • 2.53 GHz Intel Core 2 Duo processor or equivalent
    • At least 4 GB of RAM
    • At least 1 GB of hard drive disk space
    • TestStand 2021 (64-bit)
    • VeriStand 2021
    Battery Test System Software Toolkit supports Windows 10 (64-bit).
    The Battery Test System Software Toolkit installs automatically when you install Battery Test System Software with default settings. You can also download the Battery Test System Software Toolkit separately from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note  Use the serial number that is listed on the Certificate of Ownership that shipped with your system to activate Battery Test System Software Toolkit. For more information on Battery Test System Software Toolkit activation, refer to Activating a Product.
    Refer to the following documents to learn more about the Battery Test System, Battery Test System Software, Battery Test System Server Software, and measurement rack. You can find this documentation on your host computer at: %Public%\Documents\National Instruments\Battery Test System\Documentation.
    Document
    Description
    Battery Test System User ManualContains primary help information for the Battery Test System, including:
    • Site preparation and uncrating instructions
    • Hardware reference information
    • Maintenance and service procedures
    • Battery Test System software setup, configuration, and usage
    BTS-16101 Battery Test System Measurement Rack SpecificationsLists the technical specifications for the Battery Test System.
    BTS-16101 Battery Test System Measurement Rack Safety, Environmental, and Regulatory InformationDetails important compliance precautions and connection information for your measurement rack.
    Battery Test System Software ReadmeProvides installation instructions, system requirements, and other information for Battery Test System Software.
    Battery Test System Server Software ReadmeProvides installation instructions, system requirements, and other information for Battery Test System Server Software.
    You can extend your system capabilities, including prototyping and debugging test execution, using simulated DUTs and instrumentation. Example files demonstrate the capabilities of the Battery Test System Software Toolkit. You can find these examples on your host computer at: %Public%\Documents\National Instruments\Battery Test System\Toolkit\BTSPackages and %Public%\Documents\National Instruments\Battery Test System\Toolkit\TestStand.
    The Battery Test System Software Toolkit provides several custom devices for you to design and implement applications.
    To access the Battery Test System Software Toolkit Custom Devices for VeriStand in your project, open the System Explorer window from VeriStand Editor, navigate to Targets»Controller»Custom Devices, and right-click Custom Devices. Select one of the following custom devices from the shortcut menu:
    • Instrument Addon
    • File Mover
    • Network DAQ
    • SystemLink
    For general information about each custom device, select the appropriate custom device from the System Explorer window in VeriStand Editor. For more information about how to use each custom device with the Battery Test System Software Toolkit, refer to the Battery Test System User Manual.
    © 2021–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-4-15 12:44
