查看: 1912|回复: 0
[NI软件产品] NI RFmx WLAN 2022 Q4 Win11 64bitENG RFmx无线局域网络22.8
    昨天 08:15
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-11-25 10:49:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2022/10/12
    包含的版本:2022 Q4完整版,版本号22.8.0
    64位完整版校验和:
    文件大小: 1186797568 字节 (1.11 GB)
    修改日期: 2022-10-13 09:53
    MD5: 66c95320bbfeb6f5de16440c35772994
    SHA1: 3d1cb09419783a28a7c1a03b4ea5d41e1ce5437c
    SHA256: e3dcdf873c22df8b59aa301d87330683e0920da189b757ea6cc12e33df0f7ce2
    CRC32: 9f1e5640
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx WLAN 2022Q4Full.txt (537 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 631234560 字节 (601.99 MB)
    MD5: fa0d2ff3b2a763a728d8e79af5d15329
    SHA1: e1afc904828659dc7358150da97f6e0026b34890
    SHA256: c89fe27840ecedd86caba23e1943a5985212233ac067aadec12f8772455d08d5
    CRC32: e5dac1ee
    RFmx WLAN 2022Q4RTE.txt (561 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx WLAN 2022 Q4 Readme
    October 2022
    RFmx WLAN supports the following features:
    • Support for OFDM physical layer of 802.11be MU PPDU in SISO and MIMO configurations
    • Support for OFDM physical layer of 802.11n, 802.11ac, and 802.11ax in MIMO configuration
    • Support for OFDM physical layer of 802.11ax SU, MU, Extended Range SU, and trigger-based PPDUs in single transmit chain configuration, conforming to IEEE P802.11ax/D8.0.
    • Support for OFDM physical layers of 802.11a, 802.11j, 802.11p, 802.11n, and 802.11ac in single transmit chain configuration.
    • Support for channel bandwidths of 20 MHz, 40 MHz, 80 MHz, 160 MHz, and 320 MHz for OFDM physical layers.
    • Support for modulation accuracy, transmit power, and spectrum emission mask measurements on OFDM physical layer signals.
    • Support for DSSS physical layer of 802.11b/g.
    • Support for modulation accuracy, transmit power, power ramp, and spectrum emission mask measurements on DSSS physical layer signals.
    RFmx WLAN 2022 Q4 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D2.1.1
    • Support for calculating EVM for WLAN Preamble fields
    • Support for analyzing 320 MHz non-HT duplicate mode frame format
    • Support for PXIe-5842
    RFmx WLAN 2022 Q3 includes the following new features:
    • Support for LabVIEW 2022 Q3 (64-bit)
    • 802.11be standard support has been updated to comply with IEEE P802.11be/D2.0 specification
    • Support for dB Units in Common Pilot Error Magnitude trace
    RFmx WLAN 21.8 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D1.5
    • Support for auto level in MIMO OFDMModAcc measurement
    • Support for skipping decoding of header fields for 802.11be standard
    • Support for auto detection of phase rotation parameters for 802.11be 320 MHz
    • Support for 802.11be gated power measurement
    • Support for Wiener interpolation filter for 802.11ax and 802.11be standards
    • Support for 802.11be auto detection of Standard property
    • Support for phase noise PSD measurement
    • Support for burst start time result in OFDMModAcc measurement
    RFmx WLAN 2022 Q4 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2022 Q4 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2022 Q4 to an unsupported OS. Additionally, after installing RFmx WLAN 2022 Q4, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®;, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    LabVIEW2019 SP1 f3 patch, 2020 SP1, or 2021 SP1 f1 patch, 2022 Q3
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2026-4-16 07:42
