查看: 1155|回复: 0
[NI驱动程序] NI-FieldPoint 6.0.10 Win32/64Eng NI Compact FieldPoint可编程自动化控制器驱动程序6.0.10
    15 小时前
  • 签到天数: 3534 天
     楼主| 发表于 2022-11-30 12:26:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-FieldPoint
    NI-FieldPoint为Compact FieldPoint可编程自动化控制器提供LabVIEW支持。
    NI-FieldPoint是一款驱动软件,可通过LabVIEW和LabVIEW Real-Time模块创建Compact FieldPoint应用程序和实时任务。LabVIEW可搭配NI-FieldPoint使用,为Compact FieldPoint库中的本地或分布式I/O自动创建FieldPoint I/O标签和读取/写入函数。您还可以使用LabVIEW中的共享变量,将I/O数据自动发布至网络。
    发布日期:2012/2/29
    包含的版本:6.0.10完整版
    受支持的操作系统
    Windows 7 32-bit
    Windows Vista 32-bit
    Windows 7 64-bit
    Windows Vista 64-bit
    Windows XP 32-bit
    文件大小: 830212704 字节 (791.75 MB)
    修改日期: 2022-03-25 22:42
    MD5: 00de74f9711d0be8ad549a2724ffb94e
    SHA1: 93a6840b9f7b6994fec8bb9454632d9e35d62fbf
    SHA256: cc1a7f00334fe27503a21391a273f67bd8204e27a96b52990f470b9d7f11a358
    CRC32: fb272fef
    请注册登录视觉论坛账号,购买附件查看下载地址
    FieldPoint6.0.10.txt (499 Bytes, 下载次数: 0, 售价: 10 元)
    National Instruments FieldPoint™ 6.0.10 Readme
    © 2012 National Instruments Corporation. All rights reserved.
    CVI™, FieldPoint™, LabVIEW™, National Instruments™, and ni.com™ are trademarks of National Instruments Corporation.
    Product and company names mentioned herein are trademarks or trade names of their respective companies.
    This document contains important information about using the FieldPoint software with National Instruments application development environments. Please read this document completely before using the FieldPoint software.
    You can run the FieldPoint installer on the following operating systems:
    • Windows 7 (32-bit and 64-bit*)
    • Windows Vista (32-bit and 64-bit*)
    • Windows XP SP2(32-bit)
    • Windows Server 2008 R2 (64-bit*)
    The FieldPoint installer does not support Windows 2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    Operating system versions marked with an asterisk (*) will run within the 32-bit emulation layer, Windows on Windows (WOW64).
    New in FieldPoint 6.0.10Support for LabVIEW 2011 SP1FieldPoint 6.0.10 Bug Fixes
    The following items are changes from FieldPoint 6.0.9 to FieldPoint 6.0.10
    [tr][/tr]
    Bug IDFixed Issue
    #305637cFP-2220 crash with exception code 0x0000070.
    #307830LabVIEW crash on save of project.
    Known Issues in FieldPoint 6.0.10cFP-180x User LED Is Inaccessible through Serial Port
    The cFP-180x User LED channel is accessible only through an Ethernet connection. You cannot read or control the User LED through a serial connection.
    Remote I/O Error Reporting May Not Match Host VI Error Reporting
    A VI running embedded on an RT controller may report errors for remote I/O that do not match the errors reported by the same VI running on a host computer. For example, if an AI channel is out of range, an FP Read running on a host computer reports an Out of Range error. The same VI running on an RT controller returns channel-specific error A or B. Refer to the Attributes, Ranges, and Commands topic of the FieldPoint LabVIEW Interface Help for information about error messages (channel status). Doing remote I/O over serial may result in an Unknown Tag error (32812) if initialization with the module fails.
    Upgrading FieldPoint RT Controllers to LabVIEW Real-Time Module 8.6.1, 2009 SP1, 2010 SP1 and 2011 SP1
    The cFP-22xx controllers require LabVIEW Real-Time Module 8.5.1 or later. The cFP-21xx controllers require LabVIEW Real-Time Module 8.0 or later. National Instruments recommends LabVIEW Real-Time Module 7.1.1 for use on the [c]FP-20xx controllers. The [c]FP-20xx controllers do not support LabVIEW Real-Time Module 8.6 or later. Some features of LabVIEW Real-Time Module 8.x require more than 16 MB RAM, and the [c]FP-2000 and some other [c]FP-20xx controllers have only 16 MB RAM. Use the Remote Systems Install Software Wizard in MAX to install LabVIEW and FieldPoint software on FieldPoint controllers. For more information about memory and storage requirements of different LabVIEW versions, go to ni.com/info and enter the Info Code rdlrmf.
    LabVIEW Real-Time and FieldPoint Software on FieldPoint RT Controllers
    For information about which versions of the LabVIEW Real-Time Module and FieldPoint software components on the FieldPoint RT controller are compatible with each other, go to ni.com/info and enter the Info Code fpswlist.
    MiscellaneousNI-FieldPoint 6.0.X supports the following LabVIEW Versions:
    This table shows only major versions but includes all maintenance releases.
    NI-Fieldpoint Supported LabVIEW Versions
    6.07.1/8.0/8.2/8.5
    6.0.17.1/8.0/8.2/8.5
    6.0.27.1/8.2/8.5/8.6
    6.0.37.1/8.2/8.5/8.6
    6.0.47.1/8.2/8.5/8.6
    6.0.58.2/8.5/8.6/2009
    6.0.68.2/8.5/8.6/2009
    6.0.78.5/8.6/2009/2010
    6.0.88.5/8.6/2009/2010
    6.0.98.6/2009/2010/2011
    6.0.108.6/2009/2010/2011
    FieldPoint IAK Configuration File Included in Application
    With FieldPoint 6.0.2 or later, you can include FieldPoint configuration files in the data directory of a LabVIEW application. Check Include hardware configuration files on the Advanced tab in Application Properties to use this feature. The built application will use the IAK configuration file in the data directory instead of the IAK file registered with the system.
    Which IAK file LabVIEW uses for a VI depends on the type of VI, whether or not the VI is part of a LabVIEW project, and whether or not the VI has been built into an executable. The table below describes which IAK file is used in each case.
    Type of VIVI in a LabVIEW ProjectVI not in a LabVIEW ProjectVI built into an EXE
    Polymorphic FP Read, FP Write and FP Write/ReadIAK file associated with the ProjectMost recently opened IAK fileIAK file distributed with EXE
    FP Get Configuration.viIAK file associated with the LabVIEW ProjectMost recently opened IAK fileIAK file distributed with EXE
    Legacy VIs (FP Open, FP Create Tag, FP Close)Most recently opened IAK fileMost recently opened IAK fileMost recently opened IAK file
    Support for Measurement & Automation Explorer (MAX) 4.5 or later to Delete Disconnected Remote Systems
    To delete a disconnected remote system, right-click Remote Systems in MAX and select Delete Disconnected Systems. Offline FieldPoint systems with saved configurations will not be deleted.
    Creating a FieldPoint Distribution Kit
    If you are deploying a FieldPoint executable built with LabVIEW 8.0 or later, you can include FieldPoint 5.0 or a later version in the installer. You also must copy the .iak file associated with the project to your application.
    To create a FieldPoint executable using LabWindows/CVI, you must include FPCVIMgr.DLL in the distribution kit. By default this file is installed in the \WINNT\system32 folder for Windows 7/VISTA/XP.
    The .iak file created in MAX also must be included with the FieldPoint distribution kit.
    FieldPoint OPC Server
    The latest FieldPoint OPC server supports version 2.04 of the OPC Interface Specifications.
    NOTE: The return value for tags of type VT_BOOL has changed from +1 to -1 (0xFFFF - VARIANT_TRUE) to comply with the OPC specifications. All discrete input and output items (except the "All" item) for FieldPoint channels are defined to be of type VT_BOOL. If you have an OPC application that checks for data values strictly equal to +1 for discrete items, change it to check for -1 or for a non-zero value (recommended).
    GMT+8, 2025-5-9 22:46
