查看: 1743|回复: 0
[NI驱动程序] NI-FieldPoint 6.0.6 Win32/64Eng NI Compact FieldPoint可编程自动化控制器驱动程序6.0.6
    3 小时前
  • 签到天数: 3765 天
    连续签到: 16 天
     楼主| 发表于 2022-11-30 18:10:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-FieldPoint
    NI-FieldPoint为Compact FieldPoint可编程自动化控制器提供LabVIEW支持。
    NI-FieldPoint是一款驱动软件,可通过LabVIEW和LabVIEW Real-Time模块创建Compact FieldPoint应用程序和实时任务。LabVIEW可搭配NI-FieldPoint使用,为Compact FieldPoint库中的本地或分布式I/O自动创建FieldPoint I/O标签和读取/写入函数。您还可以使用LabVIEW中的共享变量,将I/O数据自动发布至网络。
    NI-FieldPoint 6.0.6
    发布日期:2010/1/20
    包含的版本:6.0.6完整版
    受支持的操作系统
    Windows 7 (32-bit and 64-bit*)
    Windows Vista (32-bit and 64-bit*)
    Windows XP (32-bit)
    Windows Server 2008 R2 (64-bit*)
    文件大小: 581798432 字节 (554.85 MB)
    修改日期: 2022-03-25 22:42
    MD5: 730800c184f735ebadd4062f45cba02e(重复一致)
    SHA1: 1cbeda88f5927feee37f4994f887be1bd272d484
    SHA256: eb346040a1466800f4b751d65a2c4ffb43f71be58b2c84c9170abc56d12af246
    CRC32: b44a4ea9
    请注册登录视觉论坛账号,购买附件查看下载地址
    FieldPoint6.0.6.txt (490 Bytes, 下载次数: 0, 售价: 10 圆)
    National Instruments FieldPoint™ 6.0.6 Readme
    © 2010 National Instruments Corporation. All rights reserved.
    CVI™, FieldPoint™, LabVIEW™, National Instruments™, and ni.com™ are trademarks of National Instruments Corporation.
    Product and company names mentioned herein are trademarks or trade names of their respective companies.
    This document contains important information about using the FieldPoint software with National Instruments application development environments. Please read this document completely before using the FieldPoint software.
    You can run the FieldPoint installer on the following operating systems:
    • Windows XP (32-bit)
    • Windows 2000
    The FieldPoint installer does not support Windows NT/Me/98/95 or the Windows Server non-R2 editions.
    Note  National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. However, NI has become aware of a number of issues of potential significance regarding Microsoft Windows 7. To learn how Windows 7 affects your use of NI products, visit ni.com/info and enter the info code windows7.
    New in FieldPoint 6.0.6Support for LabVIEW 2009 SP1FieldPoint 6.0.6 Bug Fixes
    The following items are changes from FieldPoint 6.0.5 to FieldPoint 6.0.6.
    Bug IDFixed Issue
    #195541cFP-AO 200 Range Configuration doesn't update if Watchdog and Power-Up Values are out of range.
    #184453NI-FP 6.0.5 Full Package Installation doesn't work with LabVIEW 8.5.1.
    #182228Scaling doesn't work for AI channels with non-default names on systems with multiple FieldPoint targets.
    #167414LabVIEW may hang when adding an offline FP RT target to a LabVIEW project
    Known Issues in FieldPoint 6.0.6cFP-180x User LED Is Inaccessible through Serial Port
    The cFP-180x User LED channel is accessible only through an Ethernet connection. You cannot read or control the User LED through a serial connection.
    Remote I/O Error Reporting May Not Match Host VI Error Reporting
    A VI running embedded on an RT controller may report errors for remote I/O that do not match the errors reported by the same VI running on a host computer. For example, if an AI channel is out of range, an FP Read running on a host computer reports an Out of Range error. The same VI running on an RT controller returns channel-specific error A or B. Refer to the Attributes, Ranges, and Commands topic of the FieldPoint LabVIEW Interface Help for information about error messages (channel status). Doing remote I/O over serial may result in an Unknown Tag error (32812) if initialization with the module fails.
    Upgrading FieldPoint RT Controllers to LabVIEW Real-Time Module 8.2.1, 8.5.1, 8.6.1, and 2009
    The cFP-22xx controllers require LabVIEW Real-Time Module 8.5.1 or later. The cFP-21xx controllers require LabVIEW Real-Time Module 8.0 or later. National Instruments recommends LabVIEW Real-Time Module 7.1.1 for use on the [c]FP-20xx controllers. The [c]FP-20xx controllers do not support LabVIEW Real-Time Module 8.6 or later. Some features of LabVIEW Real-Time Module 8.x require more than 16 MB RAM, and the [c]FP-2000 and some other [c]FP-20xx controllers have only 16 MB RAM. Use the Remote Systems Install Software Wizard in MAX to install LabVIEW and FieldPoint software on FieldPoint controllers. For more information about memory and storage requirements of different LabVIEW versions, go to ni.com/info and enter the Info Code rdlrmf.
    LabVIEW Real-Time and FieldPoint Software on FieldPoint RT Controllers
    For information about which versions of the LabVIEW Real-Time Module and FieldPoint software components on the FieldPoint RT controller are compatible with each other, go to ni.com/info and enter the Info Code fpswlist.
    FieldPoint 6.0.5 Bug Fix
    The following items are changes from FieldPoint 6.0.4 to FieldPoint 6.0.5.
    Bug IDFixed Issue
    #153619WSN IOV cannot run on FieldPoint target.
    FieldPoint 6.0.4 Bug Fix
    The following items are changes from FieldPoint 6.0.3 to FieldPoint 6.0.4.
    Bug IDFixed Issue
    #124852FieldPoint installer should install FieldPoint OPC Server with interactive user access by default.
    FieldPoint 6.0.3 Bug Fix
    The following items are changes from FieldPoint 6.0.2 to FieldPoint 6.0.3.
    Bug IDFixed Issue
    #124187MAX and LabVIEW do not detect I/O modules located in the 8th slot of the [c]FP backplane
    FieldPoint 6.0.2 Bug Fixes
    The following items are changes from FieldPoint 6.0.1 to FieldPoint 6.0.2.
    Bug IDFixed Issue
    #94982Fixed "Error 2961: The following files had problems ...\project.iak" when a user checks a project into source code control.
    #55186Fixed problem with FP Publish Data VIs truncating strings with NULL characters.
    #55314Removed FieldPoint Express VI from the FieldPoint Palette.
    #45053FieldPoint 6.0.2 supports MAX feature that can delete all disconnected remote systems.
    FieldPoint 6.0 Bug Fixes
    The following items are changes from FieldPoint 5.0.1 to FieldPoint 6.0.
    Bug IDFixed Issue
    3GCDKL6BFixed an issue with the Ethernet Config VIs that prevented the use of these VIs with several modules.
    3LDGT7J9Fixed the Measure Frequency VI to use the correct Gating Pulse Frequency.
    3V69AHXLFixed an issue where LabVIEW Built DLLs that used FieldPoint I/O Control would return a Pure Virtual Function Call Error.
    3YDDHMX8Fixed an issue that prevented serial device addresses from being detected in LabVIEW.
    3ZJ9NMHLFixed an issue where modifying channels within a FieldPoint item in MAX changed channel scaling assignments.
    439AGCU9Fixed an issue that prevented writing to cFP-PG-522 tags when using an OPC Client.
    43F8891YFixed an issue where LabVIEW would sometimes return a Pure Virtual Function Call error upon exit.
    46K6QN00Fixed an issue where scaling would be assigned to the wrong channel if scaling was enabled for "ALL" channels.
    49GFMBX6Fixed an issue that did not allow the FieldPoint I/O Server to run without the LabVIEW Development Environment.
    4AAG6AZ3Fixed an issue where embedded programs on FieldPoint RT controllers would abort if the first read was performed on a remote offline module.
    MiscellaneousNI-FieldPoint 6.0.X supports the following LabVIEW Versions:
    This table shows only major versions but includes all maintenance releases.
    NI-Fieldpoint Supported LabVIEW Versions
    6.07.1/8.0/8.2/8.5
    6.0.17.1/8.0/8.2/8.5
    6.0.27.1/8.2/8.5/8.6
    6.0.37.1/8.2/8.5/8.6
    6.0.47.1/8.2/8.5/8.6
    6.0.58.2/8.5/8.6/2009
    6.0.68.2/8.5/8.6/2009
    FieldPoint IAK Configuration File Included in Application
    With FieldPoint 6.0.2, you can include FieldPoint configuration files in the data directory of a LabVIEW application. Check Include hardware configuration files on the Advanced tab in Application Properties to use this feature. The built application will use the IAK configuration file in the data directory instead of the IAK file registered with the system.
    Which IAK file LabVIEW uses for a VI depends on the type of VI, whether or not the VI is part of a LabVIEW project, and whether or not the VI has been built into an executable. The table below describes which IAK file is used in each case.
    Type of VIVI in a LabVIEW ProjectVI not in a LabVIEW ProjectVI built into an EXE
    Polymorphic FP Read, FP Write and FP Write/ReadIAK file associated with the ProjectMost recently opened IAK fileIAK file distributed with EXE
    FP Get Configuration.viIAK file associated with the LabVIEW ProjectMost recently opened IAK fileIAK file distributed with EXE
    Legacy VIs (FP Open, FP Create Tag, FP Close)Most recently opened IAK fileMost recently opened IAK fileMost recently opened IAK file
    Support for Measurement & Automation Explorer (MAX) 4.5 to Delete Disconnected Remote Systems
    To delete a disconnected remote system, right-click Remote Systems in MAX and select Delete Disconnected Systems. Offline FieldPoint systems with saved configurations will not be deleted.
    Creating a FieldPoint Distribution Kit
    If you are deploying a FieldPoint executable built with LabVIEW 8.0, you can include FieldPoint 5.0 in the installer. You also must copy the .iak file associated with the project to your application.
    If you are deploying a FieldPoint executable built with LabVIEW 7.0 for systems that do not have LabVIEW installed, you should install the LabVIEW support from the FieldPoint installation CD.
    To create a FieldPoint executable using LabWindows/CVI, you must include FPCVIMgr.DLL in the distribution kit. By default this file is installed in the \WINNT\system32 folder for Windows 2000/NT/XP.
    The .iak file created in MAX also must be included with the FieldPoint distribution kit.
    The latest FieldPoint OPC server supports version 2.04 of the OPC Interface Specifications.
    NOTE: The return value for tags of type VT_BOOL has changed from +1 to -1 (0xFFFF - VARIANT_TRUE) to comply with the OPC specifications. All discrete input and output items (except the "All" item) for FieldPoint channels are defined to be of type VT_BOOL. If you have an OPC application that checks for data values strictly equal to +1 for discrete items, change it to check for -1 or for a non-zero value (recommended).
    GMT+8, 2026-1-7 12:36
