查看: 1459|回复: 0
[LV工具模块] LabVIEW 2014 Third-Party Licensing and Activation Toolkit Win32/64Eng LV2014第三方许可和激活工具包NITPLAT2014
    昨天 07:50
  • 签到天数: 3724 天
    连续签到: 51 天
     楼主| 发表于 2022-12-1 14:35:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Third-Party Licensing and Activation工具包
    Third-Party Licensing and Activation工具包可帮助您向LabVIEW应用程序和VI添加许可技术。
    Third-Party Licensing and Activation工具包是LabVIEW的一款附加软件。借助该附加软件,您可以实现许可和激活功能,包括开发许可(为基于VI的API或库提供许可证,供其他LabVIEW开发人员使用)或部署许可(为通过LabVIEW构建的应用程序或可执行文件提供许可证,供用户实现相关功能)。Third-Party Licensing and Activation工具包提供了自动Web激活和手动激活机制。您还可以实施过期评估。
    LabVIEW 2014 Third-Party Licensing & Activation Toolkit
    发布日期:2014/6/15
    包含的版本:2014完整版
    受支持的操作系统
    Windows 10
    Windows 8.1
    Windows 7
    文件大小: 63439136 字节 (60.50 MB)
    修改日期: 2022-03-25 06:10
    MD5: 257db81cad448e1bf8c564cb80ac29d4(官方正确)
    SHA1: 075f86ffd4b7b2e60002690737957b2024a951c8
    SHA256: ab355bca959d391020b5c542fd3bf7a71a6a535e55753c3fdcd03476cc75922f
    CRC32: 36b0d60d
    请注册登录视觉论坛账号,购买附件查看下载地址
    NITPLAT2014.txt (616 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2014 Third Party Licensing & Activation Toolkit Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW Third Party Licensing & Activation Toolkit, including installation instructions, new features, a partial list of bugs fixed for LabVIEW 2014 Third Party Licensing & Activation Toolkit, and known issues.
    Upgrade Issues
    The Third Party Licensing & Activation Toolkit enables you to license the add-ons that you create with LabVIEW. Users of a licensed add-on must evaluate or activate the add-on according to the activation methods you allow.
    In addition to the system requirements for the LabVIEW Development System, the Third Party Licensing & Activation Toolkit has the following requirements:
    • LabVIEW 2011, 2012, 2013, or 2014 Base, Full, or Professional Development System
    • At least 50 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    You can download and install Third Party Licensing & Activation Toolkit from LabVIEW Tools Network. For more information about the toolkit, visit the Third Party Licensing & Activation Toolkit community.
    Third Party Licensing & Activation Toolkit Updates and Notifications
    The Third Party Licensing & Activation Toolkit 2014 includes support for deactivation, which allows you to move licenses and reactivate add-ons. You can include the option to deactivate an add-on using Standard Mode or Advanced Mode. To deactivate an add-on in LabVIEW 2014, select Help»Activate Add-ons to open the Third Party Add-on Activation Wizard. Select the add-on, click Deactivate, and follow the steps in the wizard.
    The Third Party Licensing & Activation Toolkit 2014 also includes enhancements to examples. Refer to the Finding Examples section of this readme for more information on locating examples for this toolkit.
    Upgrade Issues
    If you use the Application Builder to build installers for add-ons, update the executable that automatically runs and calls RegisterAddon.exe when an installer runs. National Instruments recommends that you call RegisterAddon.exe with the following command line: RegisterAddon.exe -- -s -l path_to_lvlib. The -s parameter enforces a more secure form of licensing when customers install the add-on for use with LabVIEW 2011 SP1 and later. For each installer, update the VI that serves as source for the executable that calls RegisterAddon.exe, rebuild the executable, and then rebuild the installer.
    Refer to the Toolkits»Third Party Licensing & Activation Toolkit»Licensing a Development Add-on»Adding Standard Licensing»Final Step: Package the Add-on for Distribution topic on the Contents tab of the LabVIEW Help for more information about building and distributing add-on installers.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Third Party Licensing & Activation Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the Third Party Licensing & Activation Toolkit. This is not an exhaustive list of issues fixed in the current version of the Third Party Licensing & Activation Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    ID
    Fixed Issue
    430940The Activate Add-ons dialog resets the activation codes for offline activation when users mistakenly click submit with '0' and '0' set as the user codes.
    307045Deactivation/Reactivation features of SOLO server do not work with TPLAT licensed addons.
    Refer to the Toolkits»Third Party Licensing & Activation Toolkit book on the Contents tab in the LabVIEW Help for more information about the Third Party Licensing & Activation Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Third Party Licensing & Activation Toolkit are located in the labview\examples\addonlicensing directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    NI LabVIEW Third Party Licensing & Activation Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Third Party Licensing & Activation Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Third Party Licensing & Activation Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2010–2014 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-11-27 07:23
