查看: 1772|回复: 0
[NI软件产品] NI Spectral Measurements Toolkit 2.6.4 Win32/64Eng NI频谱测量工具包SMT2.6.4
    9 小时前
     楼主| 发表于 2022-12-1 16:14:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Spectral Measurements工具包
    Spectral Measurements工具包为时域和频域信号提供频谱分析和频谱测量工具。
    Spectral Measurements工具包是LabVIEW、C和.NET的一款附加软件,提供了用于频谱分析和频谱测量的功能和工具。借助该工具包,您可以对时域数据执行连续(实时)或块(无损)缩放FFT处理,以计算所需的结果,例如原始FFT、幅度谱、功率谱、互谱、频率响应和频谱图。使用Spectral Measurements工具包,您可以对处理后的数据,比如频带功率、相邻信道功率(ACP)、占用带宽(OBW)、峰值搜索等执行频谱测量。Spectral Measurements工具包还提供了高级处理参数,包括分辨率带宽(RBW)、加窗、滤波、单位转换和各种频谱均值法。
    发布日期:2013/06/28
    包含的版本:2.6.4
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    文件大小: 965591840 字节 (920.86 MB)
    修改日期: 2022-03-25 06:09
    MD5: 69bed5278435e1cc9ca3d3d792230798
    SHA1: cc6cbf1076a85cd3089ce5d198cb99b0d76cd508
    SHA256: b252b101d51207bb7a051bc444ef3c8a1938f5df36e94559b50c2c0fbd5bddc6
    CRC32: b1dedc2f
    请注册登录视觉论坛账号,购买附件查看下载地址
    SMT2.6.4.txt (499 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Spectral Measurements Toolkit Readme
    2013
    Version 2.6.4
    Thank you for using the NI Spectral Measurements Toolkit (SMT). This file contains important information about the toolkit and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Supported Drivers
    • Updates and Notifications
    • Uninstalling/Modifying NI Spectral Measurements Toolkit
    • Known Issues
    • Bug Fixes
    • Important Information
    NI Spectral Measurements Toolkit 2.6.4 adds support for LabVIEW 2012.
    NI Spectral Measurements Toolkit 2.6.2 adds support for LabVIEW 2011.
    NI Spectral Measurements Toolkit 2.6 includes the following new features:
    • Support for generating and applying pulse shaping filter on user-defined regions of a given spectrum through the addition of a new palette-level VI—SMT Filter Spectrum VI
    • Addition of the SMT Spectrum Peak Search (Advanced VI), and the SMTSpectrumPeakSearchMaxNPeaks function
    NI Spectral Measurements Toolkit 2.5 includes the following new feature:
    • Japanese localization for LabVIEW application programming interface (API) and documentation
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Vector Signal Transceiver
    • NI PXIe-5644R
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    System RequirementsSupported Operating SystemsNote   NI Spectral Measurements Toolkit 2.6.4 does not support Windows 8.
    NI Spectral Measurements Toolkit 2.6.4 and later supports the following operating systems:
    Note   NI Spectral Measurements Toolkit 2.6.4 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed.
    NI Spectral Measurements Toolkit 2.6.4 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • Free hard drive space—3 GB
    • RAM—256 MB
    Recommended System
    • Free hard drive space—4 GB
    • RAM—1 GB
    Note  The SMT run-time Engine must be installed on systems running applications built using the NI Spectral Measurements Toolkit and LabWindows/CVI. The SMT run-time installer is available on the NI Spectral Measurements Toolkit CD in the NISMTCVIRTE folder (setup.exe).
    Note  You should install ADEs, such as NI LabVIEW or NI LabWindows/CVI, before installing NI Spectral Measurements Toolkit. To add support for ADEs installed after installing NI Spectral Measurements Toolkit, modify your NI Spectral Measurements Toolkit installation or launch the NI Spectral Measurements Toolkit installer again.
    • NI LabVIEW 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), or 2012 SP1 (64-bit)
    • NI LabVIEW Real-Time Module 2009 SP1, 2010 SP1, 2011 SP1, or 2012 SP1
    • LabWindows™/CVI™ 9.0, 2009, 2010, or 2011
    Supported Drivers
    Install all the instrument drivers for the hardware you intend to use before installing the NI Spectral Measurements Toolkit. The toolkit supports the following drivers:
    • NI-RFSA 2.1 or later
    • NI-SCOPE 3.4 or later
    If you install one or more of the aforementioned drivers after installing the NI Spectral Measurements Toolkit 2.6.4, driver-specific toolkit examples and palette VIs are not present. To install these driver-specific files, you must run the Modify function from the NI Spectral Measurements Toolkit installer. To do so, follow the instructions found in the Uninstalling/Modifying NI Spectral Measurements Toolkit section.
      • Windows XP: \All Users\Shared Documents\National Instruments
      • Windows 7/Vista: \Public\National Instruments
      • Windows 7 (32-bit)/Vista (32-bit)/XP (32-bit)
        • LabVIEW (32-bit): Program Files\National Instruments
      • Windows 7 (64-bit)/Vista (64-bit)/XP (64-bit)
        • LabVIEW (32-bit): Program Files(x86)\National Instruments
        • LabVIEW (64-bit): Program Files\National Instruments
      • LabVIEW 2009 SP1 (32-bit): \LabVIEW 2009
      • LabVIEW 2009 SP1 (64-bit): \LabVIEW 2009
      • LabVIEW 2010 SP1 (32-bit): \LabVIEW 2010
      • LabVIEW 2010 SP1 (64-bit): \LabVIEW 2010
      • LabVIEW 2011 SP1 (32-bit): \LabVIEW 2011
      • LabVIEW 2011 SP1 (64-bit): \LabVIEW 2011
      • LabVIEW 2012 SP1 (32-bit): \LabVIEW 2012
      • LabVIEW 2012 SP1 (64-bit): \LabVIEW 2012
    ItemInstalled Location
    VIs\vi.lib\addons\Spectral Measurements Toolset
    Examples\Spectral Measurements Toolset
    LabWindows/CVI
    Header Files\Shared\CVI\Include
    Static Libraries (32-bit)\Shared\CVI\Bin\msvc
    Static Libraries (64-bit)\Shared\CVI\Bin\msvc64
    .lfp/.sub Files\Shared\CVI\Bin
    Examples\National Instruments\CVI\samples\smt
    C
    Header Files\Shared\ExternalCompilerSupport\C\include
    Import Library (32-bit)\Shared\ExternalCompilerSupport\C\lib32\msvc
    Import Library (64-bit)\Shared\ExternalCompilerSupport\C\lib64\msvc
    Notes On Creating Modulation Executables Using Spectral Measurements Toolkit and LabVIEW Application Builder, available on the National Instruments website, contains information about which VIs must be included as dynamic VIs in LabVIEW Application Builder for the executable file to run correctly.
    Documentation is available at Start»All Programs»National Instruments»Spectral Measurements Toolkit. The documentation set is composed of the following documents:
    • NI Spectral Measurements Toolkit Readme
    • NI LabVIEW Spectral Measurements Toolkit Help—HTML help format. Contains reference information about the Spectral Measurements LabVIEW VIs.
    • NI Spectral Measurements Toolkit Function Reference Help—HTML help format. Contains reference information about the Spectral Measurements LabWindows/CVI functions.
    • NI Spectral Measurements Toolkit User Guide—PDF format. Contains information about using the NI Spectral Measurements Toolkit for frequency-domain measurements.
    Spectral Measurements Toolkit Updates and Notifications
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    Uninstalling/Modifying the NI Spectral Measurements Toolkit
    Perform the following procedure to uninstall NI LabVIEW Spectral Measurements Toolkit 2.6.4:
    • Click Change/Remove.
    • Select NI LabVIEW Spectral Measurements Toolkit 2.6.4 from the dialog box that appears.
      Note  To uninstall or modify the NI Spectral Measurements Toolkit for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit 2.6.4 from the dialog box that appears.
      Note   To uninstall or modify the NI Spectral Measurements Toolkit Runtime for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit Runtime 2.6.4 from the dialog box that appears.
    You can access the software and documentation known issues list online. Refer to the NI Spectral Measurements Toolkit 2.6, 2.6.1, 2.6.2, 2.6.3, and 2.6.4 Known Issues at ni.com for an up-to-date list of known issues in NI Spectral Measurements Toolkit 2.6.4.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.4 from NI Spectral Measurements Toolkit 2.6.3.
    374121Fixed an issue where NI Spectral Measurements Toolkit did not install on LabVIEW 2012.
    404823Fixed an issue where multiple shortcuts to documents were present in the Start Menu folder for NI Spectral Measurements Toolkit.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.3 from NI Spectral Measurements Toolkit 2.6.2.
    320267Fixed an issue where license manager was unable to check out NI Spectral Measurements Toolkit license from certain packages in a volume license file.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.2 from NI Spectral Measurements Toolkit 2.6.1.
    309228Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Spectral Measurement Toolkit dependencies.
    307793Fixed an issue where the SMT filter spectrum function clears all the values of the spectrumInfo struct.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.1 from NI Spectral Measurements Toolkit 2.6.
    293100Fixed an issue where users were unable to install some of the components of the NI Spectral Measurements Toolkit on LabVIEW 2010.
    The following items are changes in NI Spectral Measurements Toolkit 2.6 from NI Spectral Measurements Toolkit 2.5.1.
    34854Fixed an issue where the SMT peak search routine does not detect peaks that fall on the power spectrum boundaries.
    © 2005–2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 19:07
