查看: 1857|回复: 0
[NI软件产品] NI Spectral Measurements Toolkit 2.7.0 Win32/64Eng NI频谱测量工具包SMT2.7.0
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2022-12-1 16:51:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Spectral Measurements工具包
    Spectral Measurements工具包为时域和频域信号提供频谱分析和频谱测量工具。
    Spectral Measurements工具包是LabVIEW、C和.NET的一款附加软件,提供了用于频谱分析和频谱测量的功能和工具。借助该工具包,您可以对时域数据执行连续(实时)或块(无损)缩放FFT处理,以计算所需的结果,例如原始FFT、幅度谱、功率谱、互谱、频率响应和频谱图。使用Spectral Measurements工具包,您可以对处理后的数据,比如频带功率、相邻信道功率(ACP)、占用带宽(OBW)、峰值搜索等执行频谱测量。Spectral Measurements工具包还提供了高级处理参数,包括分辨率带宽(RBW)、加窗、滤波、单位转换和各种频谱均值法。
    发布日期:2014/06/12
    包含的版本:2.7.0
    受支持的操作系统
    Windows 8.1 (32-bit and 64-bit)
    Windows 8 (32-bit and 64-bit)
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 3 (32-bit)
    Windows Server 2012 R2 (64-bit)
    文件大小: 879338272 字节 (838.60 MB)
    修改日期: 2022-03-25 17:28
    MD5: f845cc720f88ea91f2fca1bcb3939146(秒传)
    SHA1: 5da99a669e35468611b8f85c9e62412b02ccf801
    SHA256: e67516b9bbfa1cb0cf8f4bbd8d4ab3b59ae85f856632395b4bc06d53a0e9298d
    CRC32: 44be960c
    请注册登录视觉论坛账号,购买附件查看下载地址
    SMT2.7.0.txt (497 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Spectral Measurements Toolkit Readme
    Version 2.7
    Thank you for using the NI Spectral Measurements Toolkit (SMT). This file contains important information about the toolkit and is organized into the following sections:
    Accessing VIs and Functions
    Uninstalling/Modifying NI Spectral Measurements Toolkit
    NI Spectral Measurements Toolkit 2.7 adds support for LabVIEW 2013 and 2014.
    NI Spectral Measurements Toolkit 2.6.4 adds support for LabVIEW 2012.
    NI Spectral Measurements Toolkit 2.6.2 adds support for LabVIEW 2011.
    NI Spectral Measurements Toolkit 2.6 includes the following new features:
    • Support for generating and applying pulse shaping filter on user-defined regions of a given spectrum through the addition of a new palette-level VI—SMT Filter Spectrum VI
    • Addition of the SMT Spectrum Peak Search (Advanced VI), and the SMTSpectrumPeakSearchMaxNPeaks function
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Vector Signal Transceivers
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    NI Spectral Measurements Toolkit 2.7 and later supports the following operating systems:
    Note   NI Spectral Measurements Toolkit 2.7 and later does not support Windows Server non-R2 editions.
    NI Spectral Measurements Toolkit 2.7 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows 8.1/8/7/Vista: 2 GB*
      • Windows XP SP3: 256 MB*
    • Windows 8.1/8/7/Vista/XP SP3, with all available critical updates and service packs
    • If you are running your application on an RT target, 128 MB of memory or more is recommended.
    Recommended System
    • RAM—
      • Windows 8.1/8/7/Vista: 4 GB*
      • Windows XP SP3: 2 GB*
    Note  The SMT run-time Engine must be installed on systems running applications built using the NI Spectral Measurements Toolkit and LabWindows/CVI. The SMT run-time installer is available on the NI Spectral Measurements Toolkit CD in the NISMTCVIRTE folder (setup.exe).
    Note  You should install ADEs, such as NI LabVIEW or NI LabWindows/CVI, before installing NI Spectral Measurements Toolkit. To add support for ADEs installed after installing NI Spectral Measurements Toolkit, modify your NI Spectral Measurements Toolkit installation or launch the NI Spectral Measurements Toolkit installer again.
    • NI LabVIEW 2011 SP1 (32-bit and 64-bit), 2012 SP1 (32-bit and 64-bit), 2013 SP 1 (32-bit and 64-bit), 2014 (32-bit and 64-bit)
    • NI LabVIEW Real-Time Module 2011 SP1, 2012 SP1, 2013 SP 1, 2014
    • LabWindows™/CVI™ 8.1 and later.
    Supported Drivers
    Install all the instrument drivers for the hardware you intend to use before installing the NI Spectral Measurements Toolkit. The toolkit supports the following drivers:
    • NI-RFSA 2.9 or later
    • NI-SCOPE 4.0.5 or later
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\National Instruments
      • Windows 8.1 (64-bit)/8 (64-bit) /7 (64-bit)/Vista (64-bit): Program Files (x86)\National Instruments
      • Windows 8.1/8/7/Vista/XP: \LabVIEW
    ItemInstalled Location on Windows 8.1/8/7/Vista/XP
    VIs\vi.lib\addons\Spectral Measurements Toolset
    Examples\examples\Spectral Measurements Toolset
    Documentation for NI Spectral Measurements Toolkit is located at Start»All Programs»National Instruments»Spectral Measurements Toolkit. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI LabVIEW Spectral Measurements Toolkit HelpHTML/Windows HelpContains primary help content for NI Spectral Measurements Toolkit products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI Spectral Measurements Toolkit
    • A complete reference for all NI Spectral Measurements Toolkit programming VIs
    NI Spectral Measurements Toolkit Function Reference HelpHTML/Windows HelpContains reference information about the Spectral Measurements LabWindows/CVI functions.
    NI Spectral Measurements Toolkit ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI Spectral Measurements Toolkit palette VIs are available from the Functions»RF Communications»Spectral Measurements Toolkit palette.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI Specatral Measurements Toolkit examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and NI Spectral Measurement Toolkit examples) and their descriptions:
    • Click the Browse tab to locate spectral measurement examples by task at Toolkit and Modules»Spectral Measurements or by directory structure at Spectral Measurements Toolset.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Spectral" to locate all NI Spectral Measurement Toolkit examples.
    You can also access all the installed NI Spectral Measurement Toolkit examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»Spectral Measurements Toolkit»Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the NI Spectral Measurements Toolkit. Refer to ni.com/examples for these examples and for more information.
    • Click Change/Remove.
    • Select NI LabVIEW Spectral Measurements Toolkit 2.7 from the dialog box that appears.
      Note  To uninstall or modify the NI Spectral Measurements Toolkit for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit 2.7 from the dialog box that appears.
      Note  To uninstall or modify the NI Spectral Measurements Toolkit Runtime for LabWindows/CVI, select NI LabWindows/CVI Spectral Measurements Toolkit Runtime 2.7 from the dialog box that appears.
    For Windows 8.1/8, complete the following steps:
    • Select Programs»Programs and Features.
    • Click the Uninstall button.
    • Select NI Spectral Measurement Toolkit 2.7 from the dialog box that appears.
    The following are the behavior changes in NI Spectral Measurement Toolkit 2.7 from NI Spectral Measurement Toolkit 2.6.4:
    • The VIs present in the directory, /addons/Spectral Measurements Toolset/LVSupport/SMT niScope Utilities/SMT RFSA Dependent, are no longer in niSMT.lvlib. The location of these VIs on the disk has not changed.
      Applications using the VIs present in this directory need to be manually relinked.
    • Removed Japanese localization support.
    You can access the software and documentation known issues list online. Refer to the NI Spectral Measurements Toolkit 2.7 Known Issues at ni.com for an up-to-date list of known issues in NI Spectral Measurements Toolkit 2.7.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.4 from NI Spectral Measurements Toolkit 2.6.3.
    374121Fixed an issue where NI Spectral Measurements Toolkit did not install on LabVIEW 2012.
    404823Fixed an issue where multiple shortcuts to documents were present in the Start Menu folder for NI Spectral Measurements Toolkit.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.3 from NI Spectral Measurements Toolkit 2.6.2.
    320267Fixed an issue where license manager was unable to check out NI Spectral Measurements Toolkit license from certain packages in a volume license file.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.2 from NI Spectral Measurements Toolkit 2.6.1.
    309228Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Spectral Measurement Toolkit dependencies.
    307793Fixed an issue where the SMT filter spectrum function clears all the values of the spectrumInfo struct.
    The following items are changes in NI Spectral Measurements Toolkit 2.6.1 from NI Spectral Measurements Toolkit 2.6.
    293100Fixed an issue where users were unable to install some of the components of the NI Spectral Measurements Toolkit on LabVIEW 2010.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    NI LabVIEW Spectral Measurements Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Spectral Measurements Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI LabVIEW Spectral Measurements Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes.
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2001–2014 National Instruments. All rights reserved.
    GMT+8, 2026-4-15 13:42
