查看: 2088|回复: 0
[LV工具模块] LabVIEW Modulation Toolkit 4.3.2 Win32/64Eng LabVIEW调制工具包4.3.2
    昨天 16:03
     楼主| 发表于 2022-12-5 12:06:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW调制工具包
    LabVIEW调制工具包为LabVIEW提供了调制信号生成和分析功能,适用于研究、设计、原型,验证和测试应用。
    LabVIEW调制工具包是LabVIEW的一个软件附件,提供了用于生成、分析、处理和可视化模拟和数字调制信号的功能和工具。该工具包可让您使用各种调制方案(包括AM、FM、PM、ASK、FSK、MSK、PSK和QAM)对信号进行调制和解调。使用LabVIEW调制工具包,您可以执行信道编码、交织编码和均衡等等高级信号处理,也可以测量频率误差、误差矢量幅度(EVM)和误码率(BER)等参数,以验证信号质量。使用LabVIEW调制工具包,您还可以应用常见的信号减损,并通过星座图、眼图和网格图等可视化工具查看信号。
    发布日期:2011/09/14
    包含的版本:4.3.2
    受支持的操作系统
    Windows 7 (32-bit)
    Windows 7 (64-bit)
    Windows Vista (32-bit)
    Windows Vista (64-bit)
    Windows XP
    Windows Server 2003 (32-bit)
    Windows Server 2008 (32-bit)
    文件大小: 535560959 字节 (510.75 MB)
    修改日期: 2022-03-25 16:45
    MD5: 175b0fbe12d6b00970bbc776421dc969(秒传)
    SHA1: 03b4ad9bfc099cf9d0cb558264ddaf6c66fd9185
    SHA256: df477749f380cbb59b204d45a2db37f91e55f5499a8d57e9d250d984a7f98c78
    CRC32: 6b692f09
    请注册登录视觉论坛账号,购买附件查看下载地址
    Modulation4.3.2.txt (494 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW Modulation Toolkit Readme
    Version 4.3.2
    Thank you for using the NI LabVIEW Modulation Toolkit (MT). This file contains important information about the toolkit and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Licensing
    • Supported Drivers
    • Palettes
    • Examples
    • Documentation
    • Uninstalling/Modifying NI LabVIEW Modulation Toolkit
    • Known Issues
    • Bug Fixes
    • Notice Regarding Microsoft Silverlight Installation and Redistribution
    NI LabVIEW Modulation Toolkit 4.3 includes the following new features:
    • Support for MLSE demapper for CPM and MSK
    • Support for non-systematic encoder-decoder for BCH and Hamming codes
    • Support for clock frequency offset estimation and correction for FSK, PSK, and QAM
    • Support for palette-level function for autoconfiguring and performing CCDF measurement
    NI LabVIEW Modulation Toolkit 4.2 includes the following new feature:
    Japanese localization for LabVIEW application programming interface (API) and documentation
    Supported HardwareVector Signal Generators
    • NI PXI-5670
    • NI PXI-5671
    • NI PXIe-5672
    • NI PXIe-5673
    • NI PXIe-5673E
    Arbitrary Waveform Generators
    • NI PXIe-5442
    • NI PXIe-5450
    • NI PXIe-5451
    Vector Signal Analyzers
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    NI LabVIEW Modulation Toolkit 4.3.2 and later support the following operating systems:
    • Windows XP (32-bit)
    • Windows Server 2008 R2 (32-bit)
    It is recommended that you have the most recent service pack for your operating system installed.
    NI LabVIEW Modulation Toolkit 4.3.2 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    Before installing the NI LabVIEW Modulation Toolkit software, verify that your system meets the following requirements:
    • 1 GB of free hard drive space
    • RAM—256MB
    Recommended System
    For optimum performance with large waveforms, NI recommends that your system meets the following requirements:
    • 4 GB of free hard drive space
    • RAM—1GB
    Note:  Instrument drivers are not required for NI LabVIEW Modulation Toolkit operation in simulation mode. However, the toolkit installs examples for the supported drivers if they are present on the system. Refer to the Supported Drivers section of this document for more information.
    • LabVIEW 8.6.1, 2009 SP 1 (32-bit), 2009 SP 1 (64-bit), 2010 SP 1 (32-bit), 2010 SP 1 (64-bit), 2011 (32-bit), or 2011 (64-bit)
    • LabVIEW Real-Time Module 8.6.1, 2009 SP 1, 2010 SP 1, or 2011
    Licensing
    For details on activating NI LabVIEW Modulation Toolkit, refer to the Activating Your Software section in the help files. The evaluation mode for the NI LabVIEW Modulation Toolkit is 30 days from the date of installation. You can access all the features of the toolkit in the evaluation mode. Refer to the software license file for further licensing requirements.
    Supported Drivers
    Install all instrument drivers for the hardware you intend to use before installing the NI LabVIEW Modulation Toolkit. The toolkit supports the following drivers:
    • NI-RFSA 2.1 or later
    • NI-SCOPE 3.4 or later
    • NI-RFSG 1.4 or later
    • NI-FGEN 2.5.1 or later
    If you install one or more of the aforementioned drivers after installing NI LabVIEW Modulation Toolkit 4.3.2, driver-specific toolkit examples and palette VIs are not present. To install these driver-specific files, you can run the Modify function from the NI LabVIEW Modulation Toolkit installer. To do so, follow the instructions found in the Uninstalling/Modifying the NI LabVIEW Modulation Toolkit section.
    Verify that LabVIEW and any supported drivers you intend to use with the toolkit are installed on your system prior to installing the toolkit. Install the toolkit by inserting the toolkit CD into your drive and clicking setup.exe.
    Note:  When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run the installer in silent mode from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
      • Windows 7 (32-bit)/Vista (32-bit)/XP (32-bit)
        • LabVIEW (32-bit): Program Files\National Instruments
      • Windows 7 (64-bit)/Vista (64-bit)/XP (64-bit)
        • LabVIEW (32-bit): Program Files(x86)\National Instruments
        • LabVIEW (64-bit): Program Files\National Instruments
      • LabVIEW 2009 SP1 (32-bit): \LabVIEW 2009
      • LabVIEW 2010 SP1 (32-bit): \LabVIEW 2010
      • LabVIEW 2011 (32-bit): \LabVIEW 2011
      • LabVIEW 2011 (64-bit): \LabVIEW 2011
    FilesInstalled Location
    VIs\vi.lib\addons\Modulation
    Examples\examples\Modulation
    Documentation\Modulation
    Palettes
    NI LabVIEW Modulation Toolkit palette VIs are available from the Functions»RF Communications»Modulation palette. NI LabVIEW Modulation Toolkit controls are available from the Controls»RF Communications»Modulation palette.
    Examples
    With LabVIEW running, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI LabVIEW Modulation Toolkit examples) and their descriptions.
    • Click the Browse tab to locate modulation examples by task at Toolkits and Modules»Modulation or by directory structure at Modulation.
    • Click the Search tab to search all installed examples by keyword. Enter the keyword FM, for instance, to locate an example demonstrating FM signal generation using an NI RF signal generator and the NI LabVIEW Modulation Toolkit.
    Note:  A link to the LabVIEW Modulation Toolkit examples is also available from the Start menu at All Programs»National Instruments»Modulation»LabVIEW Support»Examples Folder.
    The product documentation is available at Start»All Programs»National Instruments»Modulation»LabVIEW Support. Visit ni.com/manuals for the latest versions of product documentation. The documentation for the NI LabVIEW Modulation Toolkit includes the following items:
    • NI LabVIEW Modulation Toolkit Help
    • NI LabVIEW Modulation Toolkit Readme (this document)
    Perform the following procedure to uninstall NI LabVIEW Modulation Toolkit 4.3.2:
    • Click Change/Remove.
    • Select NI LabVIEW Modulation Toolkit 4.3.2 from the dialog box that appears.
    You can access the software and documentation known issues list online. Refer to the NI LabVIEW Modulation Toolkit 4.3, 4.3.1, and 4.3.2 Known Issues List at ni.com for an up-to-date list of known issues in NI LabVIEW Modulation Toolkit 4.3.2.
    The following items are the changes in NI LabVIEW Modulation Toolkit 4.3.2 from NI LabVIEW Modulation Toolkit 4.3.1.
    294171Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Modulation Toolkit dependencies.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.1 from NI LabVIEW Modulation Toolkit 4.3.
    294170Fixed an issue where LabVIEW projects that have Modulation Toolkit dependencies take a long time to load.
    294916Fixed an issue where an error message is displayed while compiling a project that refers to mod_Symbols to Bits.vi.
    298309Fixed an issue where analog modulation VIs are not installed on upgrading from MT 4.1 to 4.3.1.
    293100Fixed an issue where Modulation Toolkit does not install properly on LabVIEW versions after 2010 SP1.
    The following items are the changes in NI LabVIEW Modulation Toolkit 4.3 from NI LabVIEW Modulation Toolkit 4.2.1.
    147127Fixed an issue where the offsets seem to be off by one sample in the MT Phase Noise example.
    176993Fixed an issue where the sideband rejection in AM-SSB is correlated to the sample rate of the message signal, and cannot be reduced below a certain dB level.
    223422Fixed an issue where the Gaussian pulse does not integrate to unity.
    233207Fixed an issue in FSK modulation, where the pulse shape filter rampup that needs to be deleted must be equal to the length of the filter.
    239324Fixed an issue where the search (+/- % of Fsampl) parameter of the pilot extraction filter cluster is used incorrectly during AM-SSB and AM-VSB demodulation.
    244292Fixed an issue where the constellation trace shows ghost points when a BPSK symbol is defined in PSK simulation.
    The following items are the changes in NI LabVIEW Modulation Toolkit 4.2.1 from NI LabVIEW Modulation Toolkit 4.2.
    195173Fixed an issue where Japanese language LabVIEW support may get installed for non-Japanese LabVIEW.
    The following items are the changes in NI LabVIEW Modulation Toolkit 4.2 from NI LabVIEW Modulation Toolkit 4.1.
    148059Fixed an issue where the phase continuous resampling VI (mod_PCResample.vi) returns unexpected results on subsequent calls if it is not unloaded from memory after the first call.
    Using Microsoft Silverlight
    © 2005–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-24 23:47
