查看: 2221|回复: 0
[LV工具模块] LabVIEW Modulation Toolkit 4.3.4 Win32/64Eng LabVIEW调制工具包4.3.4
    11 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2022-12-5 12:42:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW调制工具包
    LabVIEW调制工具包为LabVIEW提供了调制信号生成和分析功能,适用于研究、设计、原型,验证和测试应用。
    LabVIEW调制工具包是LabVIEW的一个软件附件,提供了用于生成、分析、处理和可视化模拟和数字调制信号的功能和工具。该工具包可让您使用各种调制方案(包括AM、FM、PM、ASK、FSK、MSK、PSK和QAM)对信号进行调制和解调。使用LabVIEW调制工具包,您可以执行信道编码、交织编码和均衡等等高级信号处理,也可以测量频率误差、误差矢量幅度(EVM)和误码率(BER)等参数,以验证信号质量。使用LabVIEW调制工具包,您还可以应用常见的信号减损,并通过星座图、眼图和网格图等可视化工具查看信号。
    发布日期:2012/06/28
    包含的版本:4.3.4
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    文件大小: 683447072 字节 (651.79 MB)
    修改日期: 2022-03-25 06:09
    MD5: 5d2dd5893731026d590694f652eff9bb(秒传)
    SHA1: 5d177800d407d4fefcf523acf430b60cee14c1a0
    SHA256: 0be88cb40b10a43207b0dd5dbd66cc315388f8bed5c626457fe3f028bf1e9a4c
    CRC32: 15679867
    请注册登录视觉论坛账号,购买附件查看下载地址
    Modulation4.3.4.txt (575 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW Modulation Toolkit Readme
    2013
    Version 4.3.4
    Thank you for using the NI LabVIEW Modulation Toolkit (MT). This file contains important information about the toolkit and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Supported Drivers
    • Updates and Notifications
    • Uninstalling/Modifying NI LabVIEW Modulation Toolkit
    • Known Issues
    • Bug Fixes
    • Important Information
    NI LabVIEW Modulation Toolkit 4.3.4 adds support for LabVIEW 2012.
    NI LabVIEW Modulation Toolkit 4.3.2 adds support for LabVIEW 2011.
    NI LabVIEW Modulation Toolkit 4.3 includes the following new features:
    • Support for MLSE demapper for CPM and MSK
    • Support for non-systematic encoder-decoder for BCH and Hamming codes
    • Support for clock frequency offset estimation and correction for FSK, PSK, and QAM
    • Support for palette-level function for autoconfiguring and performing CCDF measurement
    NI LabVIEW Modulation Toolkit 4.2 includes the following new feature:
    Japanese localization for LabVIEW application programming interface (API) and documentation
    Supported HardwareVector Signal Generators
    • NI PXI-5670
    • NI PXI-5671
    • NI PXIe-5672
    • NI PXIe-5673
    • NI PXIe-5673E
    Device-specific information about these modules is included in the NI RF Signal Generators Help.
    Arbitrary Waveform Generators
    • NI PXIe-5442
    • NI PXIe-5450
    • NI PXIe-5451
    Vector Signal Analyzers
    • NI PXI-5660
    • NI PXI-5661
    • NI PXIe-5663
    • NI PXIe-5663E
    • NI PXIe-5665
    Vector Signal Transceiver
    • NI PXIe-5644R
    Digitizers
    • NI PXI-5621
    • NI PXI-5620
    • NI PXI-5122
    • NI PXI-5124
    • NI PCI-5122
    • NI PCI-5124
    • NI PXI-5922
    • NI PXI-5142
    • NI PXIe-5122
    • NI PXIe-5622
    System RequirementsSupported Operating SystemsNote   NI LabVIEW Modulation Toolkit 4.3.4 does not support Windows 8.
    NI LabVIEW Modulation Toolkit 4.3.4 and later supports the following operating systems:
    Note   NI LabVIEW Modulation Toolkit 4.3.4 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed.
    NI LabVIEW Modulation Toolkit 4.3.4 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • Free hard drive space—1 GB
    • RAM—256 MB
    Recommended System
    • Free hard drive space—4 GB
    • RAM—1 GB
    Note  Instrument drivers are not required for NI LabVIEW Modulation Toolkit operation in simulation mode. However, the toolkit installs examples for the supported drivers if they are present on the system. Refer to the Supported Drivers section of this document for more information.
    Note  You should install ADEs, such as NI LabVIEW before installing NI LabVIEW Modulation Toolkit. To add support for ADEs installed after installing NI LabVIEW Modulation Toolkit, modify your NI LabVIEW Modulation Toolkit installation or launch the NI LabVIEW Modulation Toolkit installer again.
    • NI LabVIEW 2009 SP 1 (32-bit), 2009 SP 1 (64-bit), 2010 SP 1 (32-bit), 2010 SP 1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 SP1 (32-bit), or 2012 SP1 (64-bit)
    • NI LabVIEW Real-Time Module 2009 SP 1, 2010 SP 1, 2011 SP1, or 2012 SP1
    Supported Drivers
    Install all the instrument drivers for the hardware you intend to use before installing the NI LabVIEW Modulation Toolkit. The toolkit supports the following drivers:
    • NI-RFSA 2.1 or later
    • NI-SCOPE 3.4 or later
    • NI-RFSG 1.4 or later
    • NI-FGEN 2.5.1 or later
    If you install one or more of the aforementioned drivers after installing the NI LabVIEW Modulation Toolkit 4.3.4, driver-specific toolkit examples and palette VIs are not present. To install these driver-specific files, you must run the Modify function from the NI LabVIEW Modulation Toolkit installer. To do so, follow the instructions found in the Uninstalling/Modifying NI LabVIEW Modulation Toolkit section.
      • Windows 7 (32-bit)/Vista (32-bit)/XP (32-bit)
        • LabVIEW (32-bit): Program Files\National Instruments
      • Windows 7 (64-bit)/Vista (64-bit)/XP (64-bit)
        • LabVIEW (32-bit): Program Files(x86)\National Instruments
        • LabVIEW (64-bit): Program Files\National Instruments
      • LabVIEW 2009 SP1 (32-bit): \LabVIEW 2009
      • LabVIEW 2009 SP1 (64-bit): \LabVIEW 2009
      • LabVIEW 2010 SP1 (32-bit): \LabVIEW 2010
      • LabVIEW 2010 SP1 (64-bit): \LabVIEW 2010
      • LabVIEW 2011 SP1 (32-bit): \LabVIEW 2011
      • LabVIEW 2011 SP1 (64-bit): \LabVIEW 2011
      • LabVIEW 2012 SP1 (32-bit): \LabVIEW 2012
      • LabVIEW 2012 SP1 (64-bit): \LabVIEW 2012
    ItemInstalled Location
    VIs\vi.lib\addons\Modulation
    Examples\examples\Modulation
    Documentation\Modulation
    Palettes
    NI LabVIEW Modulation Toolkit palette VIs are available from the Functions»RF Communications»Modulation palette. NI LabVIEW Modulation Toolkit controls are available from the Controls»RF Communications»Modulation palette.
    Documentation is available at Start»All Programs»National Instruments»Modulation Toolkit»LabVIEW Support. The documentation set is composed of the following documents:
    • NI LabVIEW Modulation Toolkit Readme
    • NI LabVIEW Modulation Toolkit Help—HTML help format. Contains digital communication system fundamentals and LabVIEW reference sections.
    Modulation Toolkit Updates and Notifications
    National Instruments posts information about critical updates and security notifications on ni.com. Visit ni.com/info, and enter the info code updates to access this information.
    Uninstalling/Modifying the NI LabVIEW Modulation Toolkit
    Perform the following procedure to uninstall NI LabVIEW Modulation Toolkit 4.3.4:
    • Click Change/Remove.
    • Select NI LabVIEW Modulation Toolkit 4.3.4 from the dialog box that appears.
    You can access the software and documentation known issues list online. Refer to the NI LabVIEW Modulation Toolkit 4.3, 4.3.1, 4.3.2, 4.3.3, and 4.3.4 Known Issues at ni.com for an up-to-date list of known issues in NI LabVIEW Modulation Toolkit 4.3.4.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.4 from NI LabVIEW Modulation Toolkit 4.3.3.
    362507Fixed an issue where installing NI LabVIEW Modulation Toolkit 4.3.3 did not install Digital Modulation Toolkit VIs on LabVIEW 2012.
    374121Fixed an issue where NI LabVIEW Modulation Toolkit did not install on LabVIEW 2012.
    404822Fixed an issue where multiple shortcuts to documents were present in the Start Menu folder for NI LabVIEW Modulation Toolkit.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.3 from NI LabVIEW Modulation Toolkit 4.3.2.
    322185Fixed an issue where some files were missing in the Modulation Toolkit after upgrading LabVIEW and reinstalling the toolkit for the upgraded version.
    320449Fixed an issue where license manager was unable to check out Modulation Toolkit license from certain packages in a volume license file.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.2 from NI LabVIEW Modulation Toolkit 4.3.1.
    294171Fixed an issue where an error message about conflicts between different dir.mnu is displayed when opening a VI from a LabVIEW project that has Modulation Toolkit dependencies.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3.1 from NI LabVIEW Modulation Toolkit 4.3.
    294170Fixed an issue where LabVIEW projects that have Modulation Toolkit dependencies take a long time to load.
    294916Fixed an issue where an error message is displayed while compiling a project that refers to mod_Symbols to Bits.vi.
    298309Fixed an issue where analog modulation VIs are not installed on upgrading from MT 4.1 to 4.3.1.
    293100Fixed an issue where Modulation Toolkit does not install properly on LabVIEW versions after 2010 SP1.
    The following items are changes in NI LabVIEW Modulation Toolkit 4.3 from NI LabVIEW Modulation Toolkit 4.2.1.
    147127Fixed an issue where the offsets seem to be off by one sample in the MT Phase Noise example.
    176993Fixed an issue where the sideband rejection in AM-SSB is correlated to the sample rate of the message signal, and cannot be reduced below a certain dB level.
    223422Fixed an issue where the Gaussian pulse does not integrate to unity.
    233207Fixed an issue in FSK modulation, where the pulse shape filter rampup that needs to be deleted must be equal to the length of the filter.
    239324Fixed an issue where the search (+/- % of Fsampl) parameter of the pilot extraction filter cluster is used incorrectly during AM-SSB and AM-VSB demodulation.
    244292Fixed an issue where the constellation trace shows ghost points when a BPSK symbol is defined in PSK simulation.
    © 2005–2013 National Instruments. All rights reserved.
    GMT+8, 2026-4-8 19:46
