查看: 1443|回复: 0
[LV工具模块] NI LabVIEW for FTC 2012 Toolkit Win32Eng LabVIEW用于FTC科技挑战赛工具包2012
     楼主| 发表于 2022-12-5 15:05:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2012/08/10
    包含的版本:2012
    受支持的操作系统
    应用程序位数:32位
    文件大小: 197089928 字节 (187.96 MB)
    修改日期: 2022-03-25 06:04
    MD5: f2af61c6d07ca6fcb6f45da85f662317
    SHA1: da553c0df361abc752a4b186d9c0a01bc3a9d9c6
    SHA256: 980e440b3be95d518166614560361be803df3a82bca188b3a593abf6f6904202
    CRC32: 75297615
    请注册登录视觉论坛账号,购买附件查看下载地址
    LV4FTC2012.txt (519 Bytes, 下载次数: 0, 售价: 10 圆)
    NI LabVIEW for FTC 2012-2013 Toolkit Readme
    August 2012
    This file contains information to introduce you to the LabVIEW for FTC 2012-2013 Toolkit. This file also provides help resources that you can use while working with the LabVIEW for FTC Toolkit.
    Updating the NXT Brick Firmware
    Features and Changes
    The LabVIEW for FTC Toolkit contains VIs that are specifically designed to help you program a robot for an FTC competition. Use the LabVIEW for FTC Toolkit with LabVIEW for LEGO® MINDSTORMS® provided in the FTC 2012-2013 Kit to program the NXT brick to control FTC-specific sensors and motors.
    The LabVIEW for FTC Toolkit has the following requirements:
    • LabVIEW for LEGO MINDSTORMS—You must have LabVIEW for LEGO MINDSTORMS installed on the computer before you download the LabVIEW for FTC Toolkit.
      Refer to the LabVIEW for LEGO MINDSTORMS DVD packaging for information about installing and activating LabVIEW for LEGO MINDSTORMS.
    • (Windows) 37.6 MB of additional disk space
    • (Mac OS X) 17.2 MB of additional disk space
    Complete the following steps to download and install the LabVIEW for FTC Toolkit.
    • Ensure LabVIEW for LEGO MINDSTORMS is closed.
    • Disable any automatic virus detection programs.
    • Visit the National Instruments website at ni.com/info and enter the info code FTCsoftware.
    • Follow the instructions that appear on the web page to download and install the LabVIEW for FTC Toolkit for the operating system you are using.
    • After installation, enable any virus detection programs you disabled.
    You must download version 1.31 of the NXT brick firmware to your NXT brick to compete in the FTC competition. The field control system (FCS) at the FTC competition cannot communicate with your robot unless you use version 1.31 of the firmware on the NXT brick. The LabVIEW for FTC Toolkit provides the correct version of the firmware.
    To update the firmware in LabVIEW, select Tools»NXT Terminal to open the NXT Terminal dialog box, and click Update Firmware. Make sure that LEGO MINDSTORMS NXT Firmware V1.31 is selected and click Update.
    The LabVIEW for FTC Toolkit includes the following features and changes:
    • The LabVIEW for FTC Toolkit supports the Samantha Wi-Fi Module, which the FTC 2012-2013 competition requires all users to connect to. Refer to the FIRST website to install and set up your wireless connection with the Samantha Wi-Fi Module.
    You can access known issues about the LabVIEW for FTC Toolkit by visiting the National Instruments website at ni.com/first.
    Refer to the FTC Arm & Gripper template project for examples of autonomous and teleop programs in the LabVIEW for FTC Toolkit. Select File»New and under Robot Project, select FTC Arm & Gripper to access the FTC Arm & Gripper project. Modify the project to fit an application for your robot.
    Refer to the following resources for more information about the LabVIEW for FTC Toolkit:
    • TETRIX Robotics website—Use the TETRIX Robotics website to access the TETRIX Getting Started Guide, the FTC Extension, and the TETRIX Mastery LabVIEW Tutorials to familiarize yourself with building and programming an FTC robot that moves according to commands you send from a game controller.
    • LabVIEW FTC Tools VIs Help—Use the LabVIEW FTC Tools VIs Help to access reference information about the FTC Tools VIs. (Windows) Select Help»NXT Module Help to display the LabVIEW NXT Module Help, click the Contents tab if necessary, and then navigate to the VI & Function Reference»FTC Tools VIs topic. (Mac OS X) Select Help»FTC Tools Help to display the LabVIEW FTC Tools VIs Help. You also can right-click an FTC VI on the block diagram and select Help from the shortcut menu.
    Important Information
    © 2012 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-8 07:36
