查看: 1278|回复: 0
[LV工具模块] LabVIEW 2012 Wireless Sensor Network Module Pioneer Win32Eng LabVIEW无线传感器网络模块开发者2012
  • 签到天数: 3602 天
    连续签到: 10 天
     楼主| 发表于 2022-12-5 15:36:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2012/6/10
    包含的版本:2012
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista with Service Pack 1.0 (32-bit)
    Windows XP with Service Pack 3 (32-bit)
    应用程序位数:32位
    文件大小: 980126344 字节 (934.72 MB)
    修改日期: 2022-03-25 06:04
    MD5: ff9f051bd558e2fbe6f9a85cd99a7ade(秒传)
    SHA1: 9530a7db9dc438c03b7b35ff93b206d73ca82191
    SHA256: 999f280b4d98802a3b4927e38c7811f004ba5311d2c09b3059d190b3688a27cc
    CRC32: bb9cb037
    请注册登录视觉论坛账号,购买附件查看下载地址
    LVWSN2012.txt (543 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2012 Wireless Sensor Network Module Pioneer Readme
    Version 12.0.0
    June 2012
    This file contains important information about the Wireless Sensor Network Module, including installation instructions, a partial list of bugs fixed for the Wireless Sensor Network Module, and known issues.
    Resources
    In addition to the system requirements for the LabVIEW Development System, the Wireless Sensor Network Module has the following requirements:
    • LabVIEW 2012 Base, Full, or Professional Development System (32-bit)
    • NI WSN-9791 Ethernet Gateway or NI 9792 WSN Real-Time Gateway
    • NI WSN-32xx WSN Nodes
    The Wireless Sensor Network Module supports the following operating systems:
    • Windows 7 (32-bit)
    • Windows Vista with Service Pack 3.0 (32-bit)
    • Windows XP with Service Pack 2 (32-bit)
    The Wireless Sensor Network Module does not support Windows NT/Me/98/95/2000, Windows Server non-R2 editions, or the Windows Server 2008 R2 edition.
    Refer to the documentation for your NI Wireless Sensor Network devices for information about system requirements for hardware devices.
    Refer to the LabVIEW readme for additional system requirements and supported operating systems for LabVIEW 2012.
    Complete the following steps to install the Wireless Sensor Network Module.
    • Log in as an administrator or as a user with administrator privileges.
    • Install LabVIEW using the LabVIEW 2012 Platform DVDs, if not already installed. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
      To request additional LabVIEW Platform DVDs, refer to the National Instruments website at ni.com.
    • Insert the NI LabVIEW Wireless Sensor Network Module media. If the installer does not automatically begin, double-click autorun.exe on the media to begin installation.
    • Select Install LabVIEW Wireless Sensor Network Module.
    • Follow the instructions on the screen for installing the Wireless Sensor Network Module.
    • Activate the Wireless Sensor Network Module.
      You must activate the Wireless Sensor Network Module before you can build VIs into WSN applications. The Wireless Sensor Network Module runs in evaluation mode if you do not activate it. You also can use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate National Instruments products. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the National Instruments License Manager, for more information about activating NI products.
    • Install and configure the NI Wireless Sensor Network devices. Refer to the NI Wireless Sensor Network Devices Getting Started Guide manual for installation instructions.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Wireless Sensor Network Module.
    Refer to the National Instruments website for an up-to-date list of fixed issues in the Wireless Sensor Network Module. This is not an exhaustive list of issues fixed in the current version of the Wireless Sensor Network Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    Resources
    The following documents include more information about the Wireless Sensor Network Module and NI Wireless Sensor Network devices.
    • LabVIEW Help, which you can access by selecting Help»LabVIEW Help from LabVIEW. Refer to the Wireless Sensor Network Module book on the Contents tab of the LabVIEW Help for information specific to the Wireless Sensor Network Module.
    • NI Wireless Sensor Network Devices Getting Started Guide
    • User guide/specifications for your gateway—This documentation contains system-level information about the WSN gateway, including device features, mounting information, and specifications. These documents are available as PDFs in the WSN\manuals directory.
    • NI WSN-32xx User Guide and Specifications
    • Measurement & Automation Explorer Help for WSN, which you can access from the National Instruments Measurement & Automation Explorer (MAX).
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Wireless Sensor Network Module are located in the labview\examples\lvemb\wsn directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2009–2012 National Instruments. All rights reserved.
    GMT+8, 2025-7-23 12:13
