查看: 1849|回复: 0
[NI软件产品] NI Multisim Component Evaluator Analog Devices Edition 12.0.0 Win32 Eng/Ger/Jpn NI电路设计软件Miltisim CE ADE 12.0.0
  • 签到天数: 3858 天
    连续签到: 51 天
     楼主| 发表于 2022-12-7 12:11:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Multisim Component Evaluator Analog Devices Edition电路设计软件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    Multisim_Component_Evaluator_Analog_Devices_Edition_12_0_0
    文件大小: 467303136 字节 (445.65 MB)
    修改日期: 2022-03-25 06:09
    MD5: b58c4c77c38820ed40ee3fa765d1a2f5
    SHA1: 9ff9d3140ccca841a2ee80bf589b616a3e5c4b99
    SHA256: 27dcb27464efcfb24d18b6d5121c738413ac20592b3983a94bfdf16733cc4fa3
    CRC32: 84ea66fc
    NIMSMCEADI12.0.txt (533 Bytes, 下载次数: 0, 售价: 10 圆)
    National Instruments Multisim Component Evaluator Analog Devices Edition Readme for Windows
    December 2012
    This file contains important last-minute information about Multisim Component Evaluator for Windows.
    Refer to the Multisim Tutorial chapter of the Getting Started with NI Circuit Design Suite manual for information about getting started with the component evaluator edition of Multisim. You can access this PDF from Start»All Programs»National Instruments»Multisim Component Evaluator 12.0»Analog Devices Edition»Documentation»Getting Started.
    Supported Platforms
    Database Improvements
    How to Use NI Software with Windows 8
    Supported Platforms
    Multisim Component Evaluator supports Windows XP 32-bit edition, Windows Vista 32-bit and 64-bit editions, Windows 7 32-bit and 64-bit editions, Windows 8 32-bit and 64-bit editions, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Multisim Component Evaluator does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Multisim Component Evaluator on Windows Vista Starter edition.
    Multisim
    • In Pentium III machines, NI Multisim cannot load LV Instruments created in NI LabVIEW 2011 and 2012; this also affects LVM and TDM sources and export. This is due to the use of SSE2 optimizations in LV Application Builder when LabVIEW components used in Multisim were compiled. For more information, please read KB 60CCP0XL: I Get LV-related Error Messages When Opening Multisim in a Pentium III Machine.
    • Multisim leaks GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behaviour and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    Release Notes
    • The "snippet" feature includes code from libpng 1.4.3, licensed by a third party or parties pursuant to the libpng license. For more information, refer to Notifications.pdf at ... \National Instruments\Multisim Component Evaluator 12.0\Licenses\.
    The following is a subset of the issues fixed between Multisim Component Evaluator 12.0. and Multisim Component Evaluator 12.0.1.
    Multisim ( 33 )
    Bug IDDescription
    363133Expand/collapse tree items in Rename/Renumber dialog may crash in some cases.
    360449Power variable should not appear in the analysis variables list.
    349258Simulation throws errors found by the netlist generator after using the In Use List.
    348533Right-click does not cancel wiring unless the first junction has been placed/connected.
    348103Some long equation models may cause simulator failures.
    347337Thermal noise source doesn't accept values from the dialog.
    346778Pulse current source not generating correct output in some cases.
    343779Noise analysis is generating incorrect spice statement.
    342877New wire names are in random order when using drag drop a component to link a set of pins.
    342841Incorrect pin assignment in the NI-sbRIO-9605 and NI-sbRIO-9606 symbols.
    335504Time delayed switch gives incorrect results.
    335288Autowire component on move list box in the Global preferences allows for invalid values to be entered.
    329492Relay doesn't behave as expected in some cases.
    328669Grid does not appear in Multisim for some magnifications.
    327944Adding spaces before component names using Multisim's component search yields no results.
    326744Multi-select deleting empty rows in digital Grapher doesn't delete the selections.
    325947Deleting a wired up component causes net names to get mixed up in some cases.
    324614Aligning parts with wires sometimes aligns them to the edge of the design.
    321970F1 doesn't go to the right topic for the text block.
    321715Automatic wiring produces scrambled paths when connections are too close.
    318565Using Undo after searching the component browser will not restore the browser to the previously selected family and group.
    317110Pressing the Escape key In Component Wizard Quits Without Prompting.
    315848"Auto Resize" changes comments so that they are cut off.
    314297Short Fault does not allow more than 2 shorted connections.
    313574Digital Clock and Digital Ground do not work together in purely digital circuits.
    301516The schematic symbol for the NDS8858H is incorrect.
    296710Multisim is slow when wiring to a component with high pin count.
    274870Dummy pin names showing up for connectors.
    274775Canceling the action to create a floating wire on schematic, will leave a floating junction behind.
    274530Multisim leaves junctions behind if user cancels place wire command.
    372125Printing unsaved designs or the spreadsheet view does not work in Windows 8.
    377814Noise analysis does not appear in Analyses toolbar.
    358660Japanese installer has duplicate text in the destination directory description.
    This edition of Multisim Component Evaluator includes 80+ new Analog Devices components, including 14 new simulation models, 56 new simulation-only photodiodes (models provided by Analog Devices), and 70+ new NI components, including GPIB, M-series DAQ, and connectors.
    Refer to NI Multisim Component Evaluator Analog Devices Edition Components for a detailed list of the components included in Multisim Component Evaluator Analog Devices Edition.
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, and the Measurement & Automation Explorer (MAX).
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX from the Start screen.
    Finding All Programs
    Important Information
    © 2007–2012 National Instruments. All rights reserved.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments. Electronics Workbench, Multisim and Ultiboard are trademarks of National Instruments. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    The EKV MOST model used in this software was developed, implemented and tested by the Electronics Laboratory (LEG) of the Swiss Federal Institute of Technology (EPFL).
    GMT+8, 2026-4-16 10:50
