查看: 1601|回复: 0
[NI软件产品] NI SignalExpress 2010 Win32德语/日语/法语/英文 数据记录软件Signal Express 2010
    昨天 16:03
     楼主| 发表于 2022-12-7 15:28:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2010/6/26
    包含的版本:2010
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 725568096 字节 (691.96 MB)
    修改日期: 2010-07-14 23:20
    MD5: 33612507eff39eeb48c8c94a3fb652ee(官方正确)
    SHA1: 8fe484d4c634b31affa2c7d724b6a8d3d313cde5
    SHA256: e76b6af1f17256838e4428a6ba16f323087fba9f3f99d8261c63d254e59b0bb2
    CRC32: 382bb29f
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress2010.txt (500 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW SignalExpress 2010 Readme
    Version 4.0.0
    June 2010
    This file contains important information about LabVIEW SignalExpress 2010, including known issues, installation instructions, and compatibility issues. Refer to Getting Started with LabVIEW SignalExpress for information about getting started with LabVIEW SignalExpress. You can access this PDF by selecting Help»Getting Started with»LabVIEW SignalExpress in the LabVIEW SignalExpress environment.
    This file contains the following information that you need to understand.
       Installing from the LabVIEW 2010 Platform DVDs
       Installing from the LabVIEW SignalExpress 2010 Installation Media
       Using Hardware with LabVIEW SignalExpress
    Activating LabVIEW SignalExpress
       LabVIEW SignalExpress Full Edition
       LabVIEW SignalExpress LE
    Compatibility
    LabVIEW SignalExpress is an interactive measurement program you can use to acquire, analyze, log, and present data from hundreds of data acquisition devices and instruments, with no programming required. Use LabVIEW SignalExpress to create projects that acquire, analyze, create, generate, and display signals. You can acquire signals from hardware devices installed on your computer, analyze the signals, and then send the resulting signals to hardware devices.
    You can run the LabVIEW SignalExpress installer on the following operating systems:
    • Windows XP (32-bit)
    LabVIEW SignalExpress runs as a 32-bit application on all operating systems.
    Note  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    LabVIEW SignalExpress does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    To run LabVIEW SignalExpress, National Instruments recommends that your system meet the following requirements:
    • 1 GB of memory (512 MB minimum)
    • 2 GB of free disk space (1.5 GB minimum)
    • Pentium 4 processor or equivalent (866 MHz minimum)
    Installation InstructionsInstalling from the LabVIEW 2010 Platform DVDs
    If you purchased LabVIEW 2010, you can install all of your LabVIEW products—including LabVIEW SignalExpress—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for LabVIEW SignalExpress along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    Complete the following steps to install LabVIEW SignalExpress 2010 from the LabVIEW SignalExpress installation media.
    • Insert the LabVIEW SignalExpress 2010 installation media and follow the instructions that appear on the screen.
    • (Optional) Activate LabVIEW SignalExpress when prompted by the installer, or activate at a later time using the NI License Manager.
    Complete the following steps to use LabVIEW SignalExpress with hardware.
    • Install the appropriate driver. For Multifunction DAQ, use NI-DAQmx. For high-speed digitizers, use NI-SCOPE. For signal generators, use NI-FGEN. For digital multimeters, use NI-DMM. All drivers are available on the Driver CD.
    • Shut down the computer.
    • Install the hardware.
    • Restart the computer to complete the software installation.
    LabVIEW SignalExpress is available in both a full and limited (LE) version. When you install LabVIEW SignalExpress, you have a 30-day trial of the Full Edition. After that period, you must purchase the Full Edition or activate LabVIEW SignalExpress LE.
    If you purchased the Full Edition of LabVIEW SignalExpress, you can activate from the software or the NI License Manager using the serial number included in your software kit. If you purchased the Full or Professional Edition of LabVIEW 2010, you can use the serial number included with LabVIEW 2010 to activate LabVIEW SignalExpress. If you purchased the Base Package of LabVIEW 2010, you must purchase LabVIEW SignalExpress separately to activate the Full Edition. Refer to the National Instruments Web site at ni.com/signalexpress to purchase the Full Edition.
    You can activate LabVIEW SignalExpress LE by clicking the Register Limited Edition button on the National Instruments License Dialog window that appears when you launch the application. You also can activate LabVIEW SignalExpress LE from the NI License Manager using the following serial number:
    S14X86755
    Refer to the LabVIEW SignalExpress Help, accessible by selecting Help»LabVIEW SignalExpress Help in LabVIEW SignalExpress, for information about LabVIEW SignalExpress.
    Example projects for LabVIEW SignalExpress are located in the signalexpress\examples folder. You can modify an example project to fit an application, or you can copy and paste from one or more examples into a project that you create.
    Compatibility
    To convert a LabVIEW SignalExpress project to a LabVIEW VI, you must have the LabVIEW 8.2 Full Development System or later installed.
    Note  LabVIEW SignalExpress does not support the 64-bit versions of LabVIEW 2009 or later.
    The Run LabVIEW 7.1 VI and Run LabVIEW 8.0 VI steps are deprecated in LabVIEW SignalExpress 2010. To run a project that contains these steps, you must download and install the appropriate support package from ni.com:
    • Run LabVIEW 7.1 VI Step Support
    • Run LabVIEW 8.0 VI Step Support
    LabVIEW SignalExpress is compatible with the following products:
    • NI-DAQmx 8.5 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DMM 2.4.1 or later
    • NI-DCPower 1.0 or later
    • IVI Driver Toolset 2.0 or later
    LabVIEW SignalExpress installs the NI Measurement Studio Network Variable and WindowsForms support in the .NET Global Assembly Cache for runtime purposes.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW SignalExpress.
    The following items are the IDs and titles of a subset of issues fixed between LabVIEW SignalExpress 2009 and LabVIEW SignalExpress 2010. This is not an exhaustive list of issues fixed in the current version of LabVIEW SignalExpress. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDFixed Issue
    3085749D8AELY"Signals too far apart" error when dragging time bar in Playback
    112206-Undo does not reestablish DAQ device synchronization and loses signal sources
    117001-TDMS file names do not update when you rename corresponding logs in LabVIEW SignalExpress
    128634-In Playback, time and date information is wrong on time waveform displays using absolute time
    136165-Conditional Repeat: "current iteration" output should be indexed if there is more than one Conditional Repeat step in the project
    145240-Changing the active log in Playback does not update the start time in the time bar
    150816-Slider display behaves incorrectly when the range is set to (-1,1)
    155464-The information obtained from the "Load from LVM" step does not get updated when a different LVM file is loaded
    158144-"Set Display Update Rate" option does not show values for specified rate
    159350-Time XY Graph displays data incorrectly when the data is decimated.
    160287-Changing axis units in Load from LVM doesn't work in certain cases
    161988-Create Digital Signal: "Reset to default" clears signal names
    162855-Two headers created when converting log to Excel spreadsheet
    163896-Exporting logs to Excel fails if the logs are set to be read-only
    164944-Number of sample errors or highlighted errors in Digital Compare step is wrong
    167087-Using Trigger step inside Conditional Repeat loop can stop project
    168688-Cursor locks up when the signal is removed from the graph
    168970-The Run LabVIEW VI step incorrectly loads values for arrays in certain cases
    170100-Project Documentation 'Set Object Size' does not work for images
    171701-Y-axis labels do not update when changing properties or dragging data onto a graph display
    172029-Format and precision of second Y scale cannot be changed
    172433-Occasional crash when changing the input of a step in Playback to the active log
    173909-Alarm set to "Generate Software Trigger" does not set the trigger
    173958-Frequency log cannot be viewed if "Prepare log data for viewing" is set to "After logging completes"
    174966-LabVIEW code generation error dialog does not support Korean characters
    175088-Limit Test: When outputs are added to the Data View, extra upper and lower limit signals appear in the "Signal Selection" dialog box
    175113-Time stamps for snapshots in Logged Data Window can display in 12- or 24-hour format depending on the type of display you use
    176888-Gauge and Meter displays can cause crashes when given an NaN value
    176975-Cannot change Playback work area options
    178107-The default unit of the Run LabVIEW VI step outputs should be amplitude and not voltage
    178352-Channels exported to clipboard paste in reverse order from how they appear in the Channel View
    180332-"Timing type" in Run LabVIEW VI steps defaults to "Periodic"
    180420-Statistics step doesn't apply custom units to output results
    181026-Improve "File is invalid or corrupted" for non-SignalExpress TDMS files
    181987-SignalExpress becomes unresponsive when trying to setup imaginary ASCII/LVM step
    182171-Logging start/stop conditions should not allow negative numbers
    182527-Run mode configuration is not saved with the project
    182572-In certain cases, SignalExpress locks up when running a project once with a log in the Data View
    182846-SignalExpress does not import TDMS files correctly if there is a "-" in the file name
    183821-Exporting logged data to the clipboard drops channel names
    186976-Placing a Sequence step before a Conditional Repeat step results in Error 50103
    187895-Screen turns white when floating a view and then switching between Playback and Monitor/Record work areas
    188466-Sweep step shows incorrect number of output signals for "List of Points" configuration type
    188568-Logging stop condition does not work if certain Boolean signals are used as the "Signal trigger"
    189370-"Delete the log from project and disk" option does not delete log files from disk
    189399-Cannot display logged data if "Store log files next to project file" option is set to "Yes"
    189596-Clicking the "Readme" link from the autorun installation dialog fails to open the HTML file in Internet Explorer 8.
    192836-In Playback, displays don't play the last block of data when a large number of discontinuities exist
    193766-Importing a text file into SignalExpress and plotting with the XY time graph results in several missing points
    194726-Cursors on a frequency graph do not link to plot correctly and display incorrect values
    195449-SignalExpress can crash if renaming a log file is cancelled while the name is highlighted
    196709-When importing a log, signals within a group will have the same unit irrespective of how they were recorded
    197381-Incorrect Data View behavior when closing a docked Step Setup tab
    198257-Power Spectrum does not interface with LabVIEW if "Magnitude scale" is set to "Linear"
    198777-Exporting multi-channel digital data to Microsoft Excel can result in duplicated data in the spreadsheet
    200017-Create Signal output parameter has incorrect name when signal type is multi-tone
    204900-Log file names disappear from Recording Options tab
    207185-Deleting multiple DAQ steps while they are running crashes SignalExpress
    209735-Project remains in Run Once mode after changing a step parameter
    211109-Selecting "Create Log Subset" in Playback loses units for sound pressure data
    21312345GDT6W9"Overlap (%)" option ignored in Playback
    221702-Inconsistent behavior with zooming and autoscaling on XY graphs
    222566-Can't select NI-SCOPE device in SignalExpress IVI Scope step
    224812-Time XY Graph scrollbar has an unexpected offset
    Important Information
    © 2004–2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-24 16:28
