查看: 1672|回复: 0
[NI软件产品] NI SignalExpress 2013 Win32德语/日语/法语/英文 数据记录软件Signal Express 2013
    9 小时前
     楼主| 发表于 2022-12-7 15:37:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SignalExpress
    SignalExpress​使​您​无​需​编​程​即可​记录、​分析​和​显示​测量​设备​的​数据。
    SignalExpress​是​一​款​交互​式​数据​记录​软件,​让​您​无​需​编​程,​即可​从​数百​种​数据​采集​仪器​和​设备​上​快速​采集、​分析​并​显示​数据。​SignalExpress​用户​可以​控制​400​多台​基于​PC​的​独立​仪器,​以及​来自​250​多个​数据​采集​设备​的​日志​数据。​该​软件​可以​处理​和​分析​信号,​并​将​结果​信号​发送​到​硬件​设备。​SignalExpress​还​提供​自动​LabVIEW​代码​生成​功能,​可​扩展​应用​程序。​用户​可以​轻松​创建​自​定义​报告,​并​将​其​导出​到​LabVIEW、​DIAdem​或​Microsoft Excel​中。
    发布日期:2013/6/23
    包含的版本:2013
    受支持的操作系统
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP (32-bit)
    语言:德语, 日语, 法语, 英文
    应用程序位数:32位
    文件大小: 983380768 字节 (937.82 MB)
    修改日期: 2014-06-14 03:22
    MD5: b0ed1f0e8305d8fd404e70dfe1682108(官方正确)
    SHA1: 81fd0147710c118acebfd7e21b093bef209eaeb8
    SHA256: 4ed5753a3c42cdca951bf0738e4afbc634433ba8d88afdf194e11a1bab95aff5
    CRC32: aab16f58
    请注册登录视觉论坛账号,购买附件查看下载地址
    SignalExpress2013.txt (590 Bytes, 下载次数: 0, 售价: 10 圆)
    SignalExpress 2013 Readme
    Version 7.0.0
    June 2013
    This file contains important information about SignalExpress 2013, including new features, known issues, installation instructions, and compatibility issues.
    Refer to the Getting Started with SignalExpress manual for getting started information by selecting Help»Getting Started with»Getting Started with SignalExpress in SignalExpress. You must have Adobe Reader installed to view the Getting Started with SignalExpress manual. Refer to the Adobe Systems Incorporated website at www.adobe.com to download the latest version of Adobe Reader.
       SignalExpress Updates and Notifications
       Installing from the LabVIEW 2013 Platform DVDs
       Installing from the SignalExpress 2013 Installation Media
       Using Hardware with SignalExpress
    Activating SignalExpress
       SignalExpress Full Edition
       SignalExpress Limited Edition
       Environment Enhancements
       Logging Enhancements
       Step Enhancements
    Compatibility
    Code Generation Compatibility
    NI SignalExpress Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    SignalExpress is an interactive measurement program you can use to acquire, analyze, log, and present data from hundreds of data acquisition devices and instruments with no programming required. You can acquire signals from hardware devices installed on your computer, analyze the signals, and then send the resulting signals to hardware devices.
    SignalExpress runs as a 32-bit application on all operating systems.
    Your system must meet the following requirements to run SignalExpress:
    • 1 GB of memory
    • 2 GB of free disk space
    • Pentium 4 processor or equivalent
      • Windows XP SP3 (32-bit)
      Note  Support for Windows Server 2003 R2 may require disabling Physical Address Extension (PAE). Refer to the National Instruments website to learn how disabling PAE might affect your use of Windows Server 2003 and what actions you might have to take.
    SignalExpress does not support Windows 2000/NT/Me/98/95, Windows XP (64-bit), or the Windows Server non-R2 editions.
    Installation InstructionsSignalExpress Updates and Notifications
    If you purchased LabVIEW 2013, you can install all of your LabVIEW products—including SignalExpress—using the LabVIEW 2013 Platform DVDs. Find installation instructions for SignalExpress, along with activation instructions, in the following locations:
    • LabVIEW Installation Guide, which is available in your LabVIEW software kit.
    • LabVIEW 2013 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2013 Platform DVDs, refer to the National Instruments website.
    Complete the following steps to install SignalExpress 2013 from the SignalExpress installation media.
    • Insert the SignalExpress 2013 installation media and follow the instructions that appear on the screen.
    • (Optional) Activate SignalExpress when prompted by the installer, or activate at a later time using the NI License Manager.
    If you purchased SignalExpress with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Complete the following steps to use SignalExpress with hardware:
    • Install the appropriate driver software, according to the following table.
      HardwareDriver software
      Multifunction DAQNI-DAQmx
      High-speed digitizersNI-SCOPE
      Signal generatorsNI-FGEN
      Digital multimetersNI-DMM
      All driver software is available on the NI Device Drivers DVD.
    • Shut down the computer.
    • Install the hardware.
    • Restart the computer to complete the software installation.
    SignalExpress is available in full and limited (LE) editions. When you install SignalExpress, you have a 7-day trial of the Full Edition. After that period, you must purchase the Full Edition or activate SignalExpress LE.
    If you purchased the Full Edition of SignalExpress, you can activate from the software or the NI License Manager using the serial number included in your software kit. If you purchased the Full or Professional Development System of LabVIEW 2013, you can use the serial number included with LabVIEW to activate SignalExpress.
    Refer to the National Instruments website at ni.com/signalexpress to purchase the Full Edition.
    SignalExpress Limited Edition (LE)
    You can activate SignalExpress LE by clicking the Register Limited Edition button on the National Instruments License Dialog window that appears when you launch the application. You also can activate SignalExpress LE from the NI License Manager using the following serial number:
    S14X86764
    SignalExpress 2013 includes the following changes from SignalExpress 2012:
    • Logged Data Window Enhancements
      • If you rename a log in the Logged Data window, the log folder on disk renames correspondingly.
      • You can delete a log from both the project and the disk without closing the project. Right-click a log in the Logged Data window and select Delete from the context menu to display the Delete Log? dialog box. Select Remove the log from the project and delete from disk immediately option in the Delete Log? dialog box. Use the Show delete log confirmation dialog option item on the General page of the Options dialog box to determine whether the Delete Log? dialog box appears. Select Tools»Options to display the Options dialog box. When you set the Show delete log confirmation dialog option item to No, SignalExpress removes the log from the project and deletes the log from disk after you close the project.
    • Playback Enhancements
      The Number of blocks option on the Playback Options tab changed from an indicator to a control. You can configure the Number of blocks option to set the number of blocks that you want to play back. If you modify the Number of blocks option, the Block size (samples) option and Stop time (s) option change correspondingly.
    • Importing Non-SignalExpress TDMS files
      You can import TDMS files that you create outside of SignalExpress. Select File»Import»Logged Signals from TDMS Files to choose the TDMS log files that you want to import. If the TDMS files you choose contain non-SignalExpress TDMS files, the Convert Non-SignalExpress TDMS File dialog box appears. In this dialog box, specify the non-SignalExpress TDMS files you want to import and where to import the files. You can then convert and import the non-SignalExpress TDMS files.
    • Copying Log Files Next to Project
      Configure the Copy log files next to project file when importing option item on the Logging page to specify whether to save a copy of the log files next to the project when you import log files. Select Tools»Options to display the Options dialog box and select Logging from the Category list to display the Logging page.
    Step Enhancements
    • New Steps
      • Run LabVIEW 2013 (32-bit) VI step
    • Changed Steps
      • In the Zero Offset step, you can configure not to export offsets ready and avg. counter by removing the checkmarks in the Export offsets ready? and Export avg. counter? checkboxes on the Input/Output tab.
      • In the Load from LVM step, you can specify the unit type for the y-axis or x-axis of the imported signal as decibel. Select Decibel from the Y axis unit or X axis unit pull-down menu to specify the decibel reference level.
    Refer to the SignalExpress Help by selecting Help»SignalExpress Help for information about SignalExpress.
    You can modify an example project for an application, or you can copy and paste one or more examples into a project that you create. Example projects for SignalExpress are located in the signalexpress\examples directory. You can find the examples directory in one of the following ways:
    • Click Open Example Project for SignalExpress from the Getting Started window.
    • Select Help»Open Example from SignalExpress.
    Compatibility
    SignalExpress is compatible with the following products:
    • NI-DAQmx 9.5.5 or later
    • NI-SCOPE 2.7 or later
    • NI-FGEN 2.2 or later
    • NI-HSDIO 1.3.1 or later
    • NI-HWS 1.3.1 or later
    • NI-DMM 2.4.1 or later
    • NI-DCPower 1.0 or later
    • IVI Compliance Package 4.4 or later
    SignalExpress installs the NI Measurement Studio Network Variable and WindowsForms support in the .NET Global Assembly Cache for run-time purposes.
    To convert a SignalExpress project to a LabVIEW VI, you must have the LabVIEW 2010 Full Development System or later installed.
    Note  SignalExpress does not support the 64-bit versions of LabVIEW.
    The Run LabVIEW 7.1 VI, Run LabVIEW 8.0 VI, Run LabVIEW 8.2 VI, Run LabVIEW 8.5 VI, Run LabVIEW 8.6 VI, and Run LabVIEW 2009 VI steps are deprecated in SignalExpress 2013. To run a project that contains these steps, download and install the appropriate support package from ni.com:
    • Run LabVIEW 7.1 VI Step Support
    • Run LabVIEW 8.0 VI Step Support
    • Run LabVIEW 8.2 VI Step Support
    • Run LabVIEW 8.5 VI Step Support
    • Run LabVIEW 8.6 VI Step Support
    • Run LabVIEW 2009 VI Step Support
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in SignalExpress 2013.
    The following table contains the IDs and titles of a subset of issues fixed for SignalExpress 2013. This table is not an exhaustive list of issues fixed in the current version of SignalExpress. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    173678Import from ASCII step: User specified dt and Input X values combo results in failed data import
    313704Renamed log file cannot be reopened in SignalExpress
    375314When using the conditional OR with 2 start conditions and a duration stop condition, data logging continues even after duration stop has timed out
    378124Can't select "Other" delimiter in "Load from ASCII" step
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    National Instruments SignalExpress will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of SignalExpress that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2004–2013 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 19:07
