查看: 2859|回复: 0
[NI软件产品] NI Requirements Gateway 2012 Win32Eng 需求网关NIRG2012
    1 小时前
  • 签到天数: 3792 天
    连续签到: 43 天
     楼主| 发表于 2022-12-7 17:36:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Requirements Gateway应用软件可将开发和验证文档直接链接到文档和数据库中的正式需求。
    Requirements Gateway可指定哪些应用程序、测试和仿真模型与记录的需求相关联,以捕获可追溯性信息。您可以使用Requirements Gateway来捕获和比较项目快照,以查看差异以及需求和覆盖率随时间的变化。该应用软件集成到LabVIEW、LabWindows/CVI和TestStand以及常用的需求描述工具,如Telelogic DOORS、IBM Rational RequisitePro和Microsoft Office等。
    发布日期:2012/8/3
    包含的版本:2012
    受支持的操作系统
    Windows 7 32-bit
    Windows Vista 32-bit
    Windows Server 2008 R2 64-bit
    Windows 7 64-bit
    Windows Server 2003 R2 32-bit
    Windows Vista 64-bit
    Windows XP 32-bit
    语言:英文
    应用程序位数:32位
    文件大小: 281767048 字节 (268.71 MB)
    修改日期: 2022-03-25 06:13
    MD5: a6407d7d82571b4a15b27021c3925c58
    SHA1: b35d51e5c075117fa6c592a9445bd3f580820377
    SHA256: c0ea4fcc76d19bc26a06b99b92cef92405cf28381343dd704ac7bcc8b755ca69
    CRC32: cdd3b291
    请注册登录视觉论坛账号,购买附件查看下载地址
    NIRG2012.txt (522 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Requirements Gateway 2012 Readme
    August 2012
    This document contains information about known issues and bug fixes in NI Requirements Gateway 2012. Refer to the NI Requirements Gateway Version 2012 Release Notes for information about changes since Requirements Gateway 1.1, including new features, and for information about getting started with Requirements Gateway, such as system requirements, installation instructions, and licensing information. If you do not activate a Requirements Gateway license, Requirements Gateway operates in Evaluation Mode. Refer to the What's New in Requirements Gateway topics for previous versions of Requirements Gateway in the NI Requirements Gateway Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    Contents
    Supported Platforms
    Installing Requirements Gateway Silently
    Licensing
    Supported Platforms
    Use the Microsoft operating systems and service packs described in the following table with Requirements Gateway 2012:
    Operating SystemRecommended Service PackRequired Service PackComments
    Windows 7 (32- and 64-bit), including Starter EditionService Pack 1
    Refer to the Requirements Gateway and Windows 7/Vista section of the NI Requirements Gateway Version 2012 Release Notes for more information about using Requirements Gateway on Windows 7/Vista.
    Windows Vista (32- and 64-bit) Business, Enterprise, or UltimateService Pack 2Service Pack 1
    Windows XP
    Service Pack 3
    Service Pack 2Requirements Gateway supports only R2 editions of Windows Server.
    Service Pack 2
    Requirements Gateway does not support Guest user accounts on Windows. Requirements Gateway supports Administrator and Limited accounts on Windows 7/Vista and Administrator, Power Users, and Users accounts on Windows XP.
    Refer to the NI Requirements Gateway Version 2012 Release Notes for additional recommended system requirements.
    You can install Requirements Gateway without viewing any installation dialog boxes. Refer to the National Instruments KnowledgeBase article 4CJDP38M, Automating the Installation of a Single Installer, on the National Instruments website for information about installing National Instruments software silently. Refer to the NI Requirements Gateway Version 2012 Release Notes for more information about installing Requirements Gateway.
    Licensing
    Requirements Gateway relies on licensing activation. You must activate a valid Requirements Gateway license before you can run Requirements Gateway. To activate Requirements Gateway, use the serial number you received as part of your installation package. Refer to the NI Requirements Gateway Version 2012 Release Notes for more information about licensing in Requirements Gateway.
    Refer to the List of Known Issues in Requirements Gateway 2012 on the National Instruments website for a list of known issues in Requirements Gateway 2012. You can also view this list by date.
    The following bugs that existed in Requirements Gateway 1.1 or earlier have been fixed in Requirements Gateway 2012.
    IDFixed IssueIssue Details
    173426Requirements Gateway does not prompt you reanalyze a project after you modify a VI in a LabVIEW projectIf you configure a Requirements Gateway project document to analyze a LabVIEW project, Requirements Gateway does not prompt you to reanalyze the Requirements Gateway project if you modify a VI in the LabVIEW project.
    173467You cannot navigate directly to a LabVIEW control or global variable from Requirements GatewayWhen you navigate to an element within a LabVIEW global variable or control (.ctl) file, LabVIEW launches but does not open the file.
    228855Browsing for Telelogic DOORS modules can fail when you are using Requirements Gateway in Evaluation ModeBrowsing for Telelogic DOORS modules can cause licensing errors when you are using Requirements Gateway in Evaluation Mode.
    279354Saving a project to the desktop with Windows 7 (64-bit) disables the Add a document buttonIf you save a Requirements Gateway project to the desktop on Windows 7 (64-bit), the Add a document button is disabled on the Project pane of the Configuration dialog box.
    284094LabVIEW 2010 can crash when you use Requirements Gateway to analyze VIs saved with LabVIEW 2009When you use LabVIEW 2010 with Requirements Gateway to analyze a LabVIEW project saved with LabVIEW 2009, LabVIEW 2010 crashes when analyzing certain VIs in the project. LabVIEW 2011 fixes this issue.
    292000Requirements Gateway incorrectly evaluates VIs with the same name saved in different project librariesIf a LabVIEW project contains multiple project libraries and two or more of the libraries contain a VI of the same name, Requirements Gateway does not recognize that the VIs are in different application instances and displays the VIs in red in the main window.
    297275Requirements Gateway crashes when you generate a report that contains a Generation structure that specifies the same name as the reportIf a custom report contains a Generation structure that specifies the same name as the report itself, Requirements Gateway crashes when you attempt to generate the report.
    297791Clicking empty space on the Attributes tab of the Types pane can cause Requirements Gateway to crashIf you left- or right-click the empty space in the Available values control on the Attributes tab of the Types pane of the Configuration dialog box, Requirements Gateway crashes under the following conditions:
    • The Attribute tab lists some attribute values in the Available values control
    • You do not select any value before you click the white space
    302064Front panel and block diagram images do not display for a LabVIEW document when you enable the Intermediate File optionWhen you select the With Images variable and you enable the option in the Intermediate File column on the Details tab of the Project pane of the Configuration dialog box for a document of the LabVIEW type, Requirements Gateway does not display front panel and block diagram images.
    305809Requirements Gateway does not correctly convert multibyte characters in LabVIEW components for an intermediate fileRequirements Gateway does not correctly convert multibyte characters in LabVIEW components for an intermediate file. The LabVIEW conversion tool does not insert the proper XML tag to enable multibyte support.
    308873Requirements Gateway does not to launch if the PATH environment variable contains more than 2048 charactersRequirements Gateway does not to launch if the PATH environment variable contains more than 2048 characters. This issue can occur each time you try to launch Requirements Gateway until you modify the PATH variable to contain fewer than 2048 characters. After the first time you launch Requirements Gateway successfully, the issue does not re-occur, even if you later modify the PATH variable to again contain more than 2048 characters.
    327378Using the clipboard to copy a requirement element to a new type definition might cause Requirements Gateway to crashIf you use the Types pane context menu to copy a requirement element from a type and paste it into a new type, Requirements Gateway might crash and display the Internal error 10713 error.
    335816An error can occur when you export multiple TestStand sequence files to Telelogic DOORSWhen you use a single Requirements Gateway project document to define multiple TestStand sequence files and you export the document to Telelogic DOORS, you might receive the Can't find object with parent "MainSequence" error.
    49111Requirements Gateway cannot analyze a Telelogic DOORS module if the module name ends with a space character. (Legacy ID: 3XM8N4G0)Requirements Gateway cannot analyze a Telelogic DOORS module if the module name ends with a space character.
    Important Information
    © 2006–2012 National Instruments. All rights reserved.
    CVI, LabVIEW, National Instruments, NI, ni.com, NI TestStand, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2026-2-3 09:48
