查看: 1926|回复: 0
[NI软件产品] NI Requirements Gateway 2014 Win32Eng 需求网关NIRG2014
    7 小时前
  • 签到天数: 3808 天
     楼主| 发表于 2022-12-7 17:38:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Requirements Gateway应用软件可将开发和验证文档直接链接到文档和数据库中的正式需求。
    Requirements Gateway可指定哪些应用程序、测试和仿真模型与记录的需求相关联,以捕获可追溯性信息。您可以使用Requirements Gateway来捕获和比较项目快照,以查看差异以及需求和覆盖率随时间的变化。该应用软件集成到LabVIEW、LabWindows/CVI和TestStand以及常用的需求描述工具,如Telelogic DOORS、IBM Rational RequisitePro和Microsoft Office等。
    发布日期:2014/8/4
    包含的版本:2014
    受支持的操作系统
    Windows 7 64-bit
    Windows 8.1 32-bit
    Windows Server 2008 R2 64-bit
    Windows XP (SP3) 32-bit
    Windows Server 2003 R2 32-bit
    Windows 7 32-bit
    Windows 8.1 64-bit
    Windows 8 64-bit
    Windows Vista (SP1) 32-bit
    Windows Vista (SP1) 64-bit
    Windows 8 32-bit
    语言:英文
    应用程序位数:32位
    文件大小: 315716896 字节 (301.09 MB)
    修改日期: 2022-03-25 06:09
    MD5: b21f399f5e0f0c295f3573ae7de4feff
    SHA1: 773861a2aa8248205ad247b31f207c6eeeff8a4c
    SHA256: 00477d371295b65afc10d81ee1fc9b1f7c6e3adca97b5b8a055561a5cac3c3ba
    CRC32: db30a315
    请注册登录视觉论坛账号,购买附件查看下载地址
    NIRG2014.txt (526 Bytes, 下载次数: 3, 售价: 10 圆)
    NI Requirements Gateway 2014 Readme
    August 2014
    This file contains important information about NI Requirements Gateway, including system requirements, bug fixes, and known issues. Refer to the NI Requirements Gateway Version 2014 Release Notes for information about changes since Requirements Gateway 2012, including new features, and for information about getting started with Requirements Gateway, such as system requirements, installation instructions, and licensing information. Refer to the What's New in Requirements Gateway topics for previous versions of Requirements Gateway in the NI Requirements Gateway Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    Licensing
    Requirements Gateway 2014 is the upgrade version of Requirements Gateway 2012. NI Requirements Gateway is a requirements traceability solution that links development and verification documents with formal requirements defined in documents and databases. Requirements Gateway improves the quality of the development process by effectively managing requirements traceability and impact analysis throughout the life cycle of a project.
    National Instruments recommends the system requirements described in the following table to run Requirements Gateway 2014.
    System RequirementsRecommendedMinimum
    Processor1 GHz 32-bit or 64-bitPentium III, Celeron 866 MHz, or equivalent
    Memory512 MB256 MB
    Hard Disk Space
    512 MB
    Video AdapterSuper video graphics array (SVGA) resolution or higher1024 × 768 resolution
    Use the following Microsoft Windows operating systems and service packs with Requirements Gateway 2014.
    • Windows 8.1 (32-bit or 64-bit)
    • Windows 8 (32-bit or 64-bit)
    • Windows 7 (32-bit or 64-bit)
    • Windows Vista Service Pack 1 (32-bit or 64-bit)
    • Windows Server 2012 R2 (64-bit), Windows Server 2008 R2 (64-bit), and Windows Server 2003 R2 (32-bit)
    Requirements Gateway does not support Guest user accounts on Windows. Requirements Gateway supports Administrator and Limited accounts on Windows 8.1/8.0/7/Vista and Administrator, Power Users, and Users accounts on Windows XP.
    Use the following National Instruments application development environments (ADEs) with Requirements Gateway 2014.
    • LabVIEW 2011 SP1 or later
    • LabVIEW Unit Test Framework Toolkit 2011 SP1 or later
    • NI LabWindows™/CVI™ 2010 SP1 or later
    • NI TestStand™2010 SP1 or later
    Refer to the NI Requirements Gateway Version 2014 Release Notes for third-party product versions that Requirements Gateway supports.
    Licensing
    Requirements Gateway relies on licensing activation. You must activate a valid Requirements Gateway license before you can run Requirements Gateway. To activate Requirements Gateway, use the serial number you received as part of your installation package. Refer to the NI Requirements Gateway Version 2014 Release Notes for more information about licensing in Requirements Gateway.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in Requirements Gateway. You can also view this list by date.
    You can access the list of bugs fixed in the current version of Requirements Gateway online. Refer to the National Instruments website for a list of bug fixes in Requirements Gateway.
    Refer to the NI Requirements Gateway Help, accessible by selecting Help»NI Requirements Gateway Help, for information about Requirements Gateway.
    Using NI Launcher
    Finding All Programs
    NI Requirements Gateway Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Requirements Gateway will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Requirements Gateway that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2006–2014 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 17:28
