查看: 2018|回复: 0
[NI软件产品] NI Requirements Gateway 2018 Win32Eng 需求网关NIRG2018
    1 小时前
  • 签到天数: 3792 天
    连续签到: 43 天
     楼主| 发表于 2022-12-7 17:40:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Requirements Gateway应用软件可将开发和验证文档直接链接到文档和数据库中的正式需求。
    Requirements Gateway可指定哪些应用程序、测试和仿真模型与记录的需求相关联,以捕获可追溯性信息。您可以使用Requirements Gateway来捕获和比较项目快照,以查看差异以及需求和覆盖率随时间的变化。该应用软件集成到LabVIEW、LabWindows/CVI和TestStand以及常用的需求描述工具,如Telelogic DOORS、IBM Rational RequisitePro和Microsoft Office等。
    发布日期:2019/5/13
    包含的版本:2018
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    语言:英文
    应用程序位数:32位
    文件大小: 405008264 字节 (386.25 MB)
    修改日期: 2022-03-25 06:09
    MD5: 3dc4961f1f3e46e553fed1babce59e65
    SHA1: 22afd4ff98145721cac0ff8f5e890b896687a479
    SHA256: 60563505b0f3663982b48ae05b38219362621e210e835b60a3e6f3f824c8c88b
    CRC32: f96ccba0
    请注册登录视觉论坛账号,购买附件查看下载地址
    NIRG2018.txt (526 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Requirements Gateway 2018 Readme
    March 2018
    This file contains important information about NI Requirements Gateway 2018, including system requirements, installation instructions, new features, bug fixes, and known issues. Refer to the What's New in Requirements Gateway topics in the NI Requirements Gateway Help for information about new features, compatibility and known issues, and bug fixes for previous versions of Requirements Gateway.
    Licensing
    New Features and Changes
    Requirements Gateway 2018 is the upgrade version of Requirements Gateway 2014. Requirements Gateway is a requirements traceability solution that links development and verification documents with formal requirements defined in documents and databases. Requirements Gateway improves the quality of the development process by effectively managing requirements traceability and impact analysis throughout the life cycle of a project.
    Requirements Gateway 2018 has the following system requirements:
    • Pentium 4M (32-bit) or Pentium 4 G1 (64-bit)
    • At least 1 GB of disk space
    • 1 GB (32-bit) or 2 GB (64-bit) RAM
    Requirements Gateway 2018 supports the following operating systems:
    • Windows 10 (version 1709)/8.1 Update 11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2018 NI Requirements Gateway dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Requirements Gateway 2018 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Requirements Gateway 2018 to an unsupported OS. Additionally, after installing Requirements Gateway 2018, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Requirements Gateway 2018 supports the following application software versions and service packs.
    Application SoftwareVersions Supported by Requirements Gateway
    LabVIEW2015 SP1, 2016, 2017, and 2018
    LabVIEW Unit Test Framework Toolkit2016, 2017, and 2018
    LabWindows™/CVI™2012 SP1, 2013 SP1, 2013 SP2, 2015 SP1, and 2017
    TestStand™2013, 2014 SP1, 2016 SP1, and 2017
    Third-Party Product Support
    Requirements Gateway 2018 supports the following third-party product versions.
    • IBM Rational DOORS 7.x to 9.6.1. You can use DOORS 8.0 only if you install Patch 5.
    • IBM Rational RequisitePro 2003.06 to 7.1.3
    • Microsoft Office 2010, 2013, and 2016
    • Adobe PDF
    Note  Requirements Gateway 2018 was not tested for compatibility with other versions of these third-party applications but might be compatible with other versions.
    Requirements Gateway exposes an ActiveX interface, but the interface is intended for internal use only and is not supported. NI reserves the right to remove or modify the interface without notice.
    Complete the following steps to install Requirements Gateway.
    Note  NI recommends exiting all programs before running the installer. Applications that run in the background, such as virus scanning utilities, might cause the installation to take longer than necessary to complete.
    Note  You cannot install Requirements Gateway to a network path or a mapped network path. You must install Requirements Gateway on a local computer.
    • Log in as a user with administrator privileges.
    • Insert the Requirements Gateway installation media and follow the instructions that appear on the screen.
    Requirements Gateway 2018 installs the following additional software components:
    • LabWindows™/CVI™ 2017 Run-Time Engine
    • NI Update Service
    • NI License Manager
    Installing Multiple Versions of Requirements Gateway on the Same Computer
    When you upgrade to a new version of Requirements Gateway, you can install the new version on the same computer that has an existing version of Requirements Gateway. Use the Requirements Gateway Install Utility to specify the active version of Requirements Gateway. Launch the Requirements Gateway Install Utility from the Start menu. The Requirements Gateway Install Utility is also located at \Shared\NIRGUtility\NIRGUtility.exe.
    Note  You must always use the Requirements Gateway Install Utility to configure the version of Requirements Gateway you want to use after you uninstall a different version of Requirements Gateway. If you do not run the utility after you uninstall Requirements Gateway, NI does not guarantee that the remaining version of Requirements Gateway still associates with the existing Requirements Gateway files.
    Upgrading from Requirements Gateway 1.0
    To comply with Windows 8.1/8.0/7/Vista restrictions on writing to the Program Files directory and to improve usability for Windows XP users who do not have permission to write to the Program Files directory, Requirements Gateway 1.1 or later installs some files in different locations from Requirements Gateway 1.0. Refer to the Directory Relocation section of the NI Requirements Gateway 1.1 Release Notes for more information about directory location changes. Visit ni.com/info and enter the Info Code NIRG11Notes to locate the NI Requirements Gateway 1.1 Release Notes.
    Licensing
    Requirements Gateway relies on licensing activation. You must activate a valid Requirements Gateway license before you can run Requirements Gateway. To activate Requirements Gateway, use the serial number you received as part of your installation package. You must also have a MyNI user profile to activate a Requirements Gateway license. Refer to the Activating Your Software topic in the NI Requirements Gateway Help for more information about how to activate Requirements Gateway.
    If you do not activate a valid license, Requirements Gateway runs in Evaluation Mode and continues to prompt you to activate a license on each subsequent launch. In Evaluation Mode, you can use all the features of the product for 7 days. You can use an ni.com User Profile to extend the evaluation period for an additional 45 days. You can activate a license at any point during or after the evaluation period.
    Requirements Gateway 2018 introduces the following new features and changes.
    • Support for IBM Rational DOORS 9.6.1 32-bit and 64-bit
    • Support for Microsoft Office 64-bit software, in addition to 32-bit software
    • Support for the ATML Test Description 3.0 schema. Requirements Gateway supports NI ATML TD files that conform to the ATML Test Description 3.0 or 1.01 schema. NI does not guarantee that the NI ATML TD type is compatible with ATML files generated by other external applications.
    • Example Program Enhancement—The Reference Attribute and Filter/Maturity Level.rqtf example, located in the \Examples directory, includes functionality to demonstrate how to use custom types and custom filters.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in Requirements Gateway.
    You can access the list of bugs fixed in the current version of Requirements Gateway online. Refer to the NI website for a list of bug fixes in Requirements Gateway.
    Refer to the NI Requirements Gateway Help, accessible by selecting Help»NI Requirements Gateway Help, for information about Requirements Gateway.
    © 2006–2018 National Instruments. All rights reserved.
    377544A-01
    GMT+8, 2026-2-3 09:48
