查看: 2338|回复: 0
[LabVIEW] LabVIEW 2010 Pro Linux32Eng LV2010Linux系统专业版
    昨天 08:15
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2023-2-17 17:29:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    文件名: LabVIEW 2010 Linux Pro.iso
    文件大小: 535185408 字节 (510.39 MB)
    修改日期: 2023-02-17 11:06
    MD5: c713a5c208dd4194c1192b65aeeaea65
    SHA1: a475782fd386594f52c42324f5b769a1f1e34bd3
    SHA256: 8e952f605cc01e15dff495632477c92d68557c86f9662a929d909638963ce366
    CRC32: 9e18d5d6
    不使用Linux版本的,不清楚具体情况。看着有APPBuild模块,和写着Pro的模块,应该是专业版。专业版和完整的区别一个重要的地方就是能不能生成应用。
    百度网盘下载地址:
    注册登陆视觉论坛账号,购买附件查看下载地址
    LV2010LinuxPro.txt (381 Bytes, 下载次数: 0, 售价: 100 圆)
    LabVIEW 2010 Readme for GNU/Linux (x86)
    Version 10.0.0
    June 2010
    This file contains important last-minute information about LabVIEW 2010 for Linux, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed for LabVIEW 2010, and changes from LabVIEW 2009 and related service packs. Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and a complete list of new features in LabVIEW 2010. Refer to the LabVIEW Release Notes for installation instructions and a complete list of system requirements. After you install LabVIEW, refer to the labview/manuals directory to access these documents. You also can access the LabVIEW Release Notes and LabVIEW Upgrade Notes at ni.com.
    Refer to the National Instruments Web site for the latest information about LabVIEW 2010.
    Installing LabVIEW 2010
    Additions to the LabVIEW Help
    If you have a previous version of LabVIEW installed, you can install LabVIEW 2010 without uninstalling the other version. In this instance, LabVIEW 2010 does not replace the previous version of LabVIEW, which remains installed.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW on Linux.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW 2010.
    • The Mass Compile dialog box includes the Include warnings for read-only VIs checkbox, which determines whether the mass compile results include warnings next to the read-only VIs.
    • The Advanced TDMS palette includes the TDMS Generate Random Data VI, which generates random data that you can use to test the performance of the Advanced TDMS VIs and functions.
    • The TDMS Configure Asynchronous Writes function does not include the data mode input.
    • On the Web Server page of the Options dialog box, the Configure Web Application Server button launches NI Web-based Monitoring and Configuration on the local system.
    • On the Web Server page of the Options dialog box, the Enable Web Server checkbox is renamed Enable Remote Panel Server.
    • In the Icon Editor dialog box, select Edit»Import Icon from Owning Library to import the icon of the owning project library. LabVIEW creates a user layer with the name NI_Library and with the icon of the owning library as the glyph. If a user layer with that name already exists, the new user layer overwrites the existing user layer.
    • The VISA Find Resource function returns error code -1073807343 if the system locates no devices.
    • LabVIEW 2010 does not support the Disconnect Polys And Typedefs method.
    • If you wire a combination of signed and unsigned integers to the upper limit, x, and lower limit inputs of the In Range and Coerce function, the data type of the coerced(x) output must be large enough to represent the full range of possible input values. If the coerced(x) output is an unsigned integer, the signed input values must be positive because an unsigned integer cannot represent a negative number.
    • When a change to a VI in a packed project library impacts the inplaceness of the connector pane, by default the caller VI adapts to inplaceness changes. As a result, you do not need to recompile the VI that calls the packed library. If you want the caller VI to recompile when the inplaceness changes, remove the checkmark from the Callers adapt at run time to Exported VI connector pane state checkbox on the Connector Pane State page of the Packed Library Properties dialog box. If you make a non-inplaceness change to a VI in a packed library, the VI must recompile.
    • Due to compiler optimizations in LabVIEW 2010, VIs can execute faster but may take up to five times longer to compile. You might not notice these changes unless you are loading a large VI. Refer to the National Instruments Web site for more information about compiler optimizations.
    The following table contains the IDs and titles of a subset of issues fixed in LabVIEW 2010. This table is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDFixed Issue
    3528546KABK39Cursor PosY property does not return free cursor position on graph with multiple Y scales
    3566642FB3AVQLabVIEW 8.2 error log file: image.cpp 13192
    3645241D46100File Path Out terminal added to TDMS File Close.vi
    406464C12TDANGraph cursor position property incorrectly sets the cursor position on graph
    411484D1JQKJ7Unable to change the Display Format for Y-axis in a dynamic data type Waveform Chart/Graph
    412244DA24FXRCannot display extended types on intensity plots
    418704E2BOFWXWrite Data Storage VI doesn't update terminal correctly
    422664ELEQS00Tools»Options Menu Shortcuts do not use Windows system colors
    428894FM25N00VariantType.lvlib:GetTypeInfo.vi poor memory performance
    439314GPF7QYESave Report to File.vi copies images from Temp rather than moving them
    485803U8DLRLGEditing block diagram of a huge VI (>2MB) is very slow.
    5002842BA53P2Text in error list window does not report there are more than 100 errors.
    5078546DA2HZLRounding Error on Unsigned Quad Indicator
    522904ALFRHGAItem dropping inside of structure even though pasting outside
    534644GIEHGI5Mass Compile does not log read-only files as not compiling
    647744BQBUKLGExecutable using a DAQ timing source for a timed while loop doesn't drop out of memory when closed.
    927894DB74RCISupport Feedback Node in Simulation
    928914DIHG4NMVariables always have a coercion dot for writes if the data type is a typedef or strict typedef
    104160Right Click Wire: Delay in Appearance of Shortcut Menu
    105619Label offset for Graph annotation does not work when scale is changed
    107912Listbox data type change does not propagate to Value property
    107978VI is Not Recovered with Autosave in LabVIEW
    110494Waveform Graph with log axis draws 1st point at end of x axis
    112822Changing VI Server TCP settings only has an effect after the TCP server is enabled
    113950LabVIEW Real-Time VI freezes if I rename a CompactRIO module or an I/O variable while the VI is running
    114236Installer Builder's destination view containing project folders doesn't reflect changes made to those folders
    115738DSM is Slow with Large Numbers of Variables
    120095Storage VIs or DataFinder Toolkit crash LabVIEW when running the built web services
    121254Modal front panels aren't modal under certain circumstances
    1214593D Picture controls render non-default font incorrectly in executables
    121538Drag-selecting terminals on script nodes selects entire node
    122715Callers of a subVI are not always found in LabVIEW Project
    125640Shared Variable Timestamp updated from the client not the server
    130466Deleting element from graph cursor list causes LabVIEW to crash
    130613.NET Calculator Example in LabVIEW throws a warning upon opening
    131221Double click does not open front panel of particular SubVI
    138226Cursor locations are not consistent on a Graph
    140222Polar Plot scale is always black
    140984"Scale Range Change" Event Does Not Trigger from Autoscaling
    142947Scroll bar Reference Causes Crash When In .exe
    144874.NET integration not working with 64-bit LabVIEW
    146581Stop Timed Loop.vi does not work properly for loops with non-zero offset
    149909Specific string lengths cause .NET error 1172 in LabVIEW
    152956The cursor in an intensity graph is not always positioned correctly.
    1530802D Interpolation Returns NaN On Bilinear/Bicubic and Method
    157041Web Service build spec does not error out when there are "invalid" characters in the terminal name
    157250Histogram PtByPt.vi doesn't recognize multiple double digit numbers
    157953Source Distribution is not updating linkage to .Net Assembly DLL
    158432Diagram cleanup does not move the diagram origin
    158475ProjectLinking.cpp line 289
    160091FP.Get Image method does not get the entire panel if it's minimized
    160401Resolve Project Conflicts doesn't let you resolve conflicts if one of the two VIs is "open"
    162495ArrElem.Blinking alters string indicator
    164282Ctrl + . within 3D Graph Properties browser locks up LabVIEW
    167303Long time to delete wires
    168144Scan From File aborts the calling VI if it is pointed to a non-existing file
    168407Selection ItemPath returns wrong path when using Insert Menu Item.vi
    169678Cursor Redraw issue with xy graph
    169850proptype.cpp line 731 error when dragging and dropping a (recursive) class reference into the class data
    170180Tags inside project xml cause several issues: Cannot Save As... , Persistent dirty dot
    171487Error -1077 At Valid Mixed Signal Graph ActivePlot Property Write
    171737Graphs do not Link to Detailed Help from Right-click or Detailed Help URL in Context Help
    172487RT Get Target Information (All).vi does not respect timeout
    173651Improve Performance of MD5 VI
    173884Scale calculated wrong after changing the "Multiplier".
    174730VI Server: Default Vals.Make Current Default only saves most recently dropped control/indicator
    176167Clear Graph in the run-time menu does not work
    176914Mode.vi: misspelling in polymorphic menu name
    178530Crashes when "List Folder" references the same llb in parallel
    178919Performance degradation for functional global variables in LabVIEW 2009
    179090Add a Numeric Constant (DBL) to the Palettes
    179376TDM to TDMS doesn't work if file has no channels
    179550Standard deviation ptbypt VI needs improved performance
    180213In Place Element Structure with Variant type and indicator inside crashes LabVIEW
    180487"Must Override" setting still applies when VI changed to be static dispatch
    180739Multiply FXP Cluster generates compilation error
    181556Resample (constant to constant) VI gives error 20076
    181665LV 2009 App Builder throws error 1003 when building FPGA VI.
    182153Classic slider control increment/decrement does not work with more than 1 slider.
    182242Register Dynamic Events With Clusters Doesn't Catch Event
    182590Memory leak using the monitor remote panel
    183117No valuable debug information when deploying a Library with a single corrupt Shared Variable
    183377Redundant Items in the shortcut menu for 3d graphs
    184424VISA Property node can cause a Memory is Full Error
    185220Certain Fonts Displayed Incorrectly If Language Package is Installed
    185742Password protected classes with friends cannot be loaded in multiple contexts.
    185759Cannot properly change color map style from 3D graph property node
    186537Call Library Node does not support interfaces for complex numbers or arrays of complex numbers
    186575LabVIEW task bar icon pixelated in Windows 7
    186664Wiring a reference of Xcontrol to an indicator causes LabVIEW to show out of memory message
    186761Doubles with units are not coerced to variants properly under certain circumstances
    186972Compiler Error copy cvt str/pict/tag, csrc = 0x32
    187006Feedback node returns incorrect results with fixed-size array initialization
    187082LabVIEW 2009 32-bit error log file: Project.cpp line 3755
    187752Join Numbers does not work correctly under some circumstances
    188027Scroll Wheel on mouse scrolls VI instead of Class Browser
    188226LabVIEW 2009 32-bit error log file: NMux.cpp line 942
    188538Wrong case name shows up when VI block diagram is opened
    188663LabVIEW Class Revert Dialog In a Project Is Confusing and Misleading
    188998Upgrading Tab Controls from LabVIEW 8.2.1 to higher versions results in unexpected behaviors.
    189206Cannot set value and properties to digital graph traces while using defer panel updates
    190076Front Panel.Get Image Scaled Method ignores Max Width and Max Height parameters
    190496Initialized array into for loop with stacked shift registers crashes LabVIEW
    190852ActiveX container modifies the floating point control register
    190919Distribute System Manager 2009 cannot rename a shared variable
    191231LabVIEW 2009 Evaluation gives "Unable to View Properties" error when using some [Express] VIs
    191501Refnum to Session VI hangs VI Execution when Refnum is not valid
    191553Read UNC Path from configuration file - LV 2009
    192105ProjectItem.cpp line 1313
    192207Controls linked to the connector pane can no longer be changed when Suspend When Called is used.
    192290Write To measurement file gives Error 1 when you use the enable button twice
    192798Cannot remove dependencies from installer source files
    192975Interpolate 1D.vi has incorrect output with linear method
    193076Large Enum input to Variant to Flattened String crashes LabVIEW
    193210XML parser error when unflattening a LabVIEW class owned by a library
    193279In Place Element Structure Causes Automatic Block Diagram Cleanup to Crash LabVIEW
    193448LabVIEW 8.6.1 error log file: help.cpp line 8947
    193544Application Info Missing from Get Info Window in MAC .app File
    193616LabVIEW 2009 32-bit error log file: PathRef.cpp line 2172
    194172Wrong time format string on Format Date/Time String function crashes LabVIEW
    194277Rare instability when dynamic loading classes in combination with static VI references
    194347When a VI is loaded as top-level and needs to reserve, it does not reserve
    194515Event Structure Disconnects From Its Controls When Saving To 8.5 or Earlier From 2009
    194720Cannot use icon editor with template VI in LabVIEW 2009
    194760Waveform chart graphs data incorrectly when using lines without points
    194887Generate callback functionality does not populate callback .NET classes in LabVIEW 2009
    195026Out of Memory error from Call Library Function Node
    195168Password protected classes cannot be deployed to VxWorks target
    195804Crash while replacing Stacked sequence with flat sequence
    196125Error -4702 when running shipping example "instrument control parsing.vi" in LabVIEW 2009
    196265Writing a value by VI Server to a subVI is not picked up by the connector pane
    196527Remove password protection on Traverse VI(s)
    196570Quick Drop Doesn't Appear if Off-screen Coordinates are Stored in the INI File
    196657In LV 2009, Data Returned by SubVI No Longer Matches Data Displayed on SubVI's Panel
    196682Application Builder does not include VIs in .lvclass when building an installer
    196968LabVIEW 2009 error log file: Scale.cpp line 24
    197018Create Data Link with no VI open causes LabVIEW to Hang
    197063Compiler error F4308
    197375DWDT Digital to Digital Comparison Runs much slower
    197779Repeated Access to data value references sometimes allowed
    197789LabVIEW slows down after suspend / resume
    198031Variant To Flattened String Crashes LabVIEW
    198191Typing r or f in the layer description after selecting the layer causes rotations and flips
    198546Labels of copied Property Nodes are not attached to the node.
    198829Corrupt 8.6 VI crashes LabVIEW 2009
    198987Invalid names are allowed for .NET assembly exported VI prototype names
    199046LabVIEW 2009 Matrix primitives can be saved for previous version without warnings
    199056Trying to get the default value of a waveform Y array element fails on an array of waveforms
    199186exec.cpp, line 483
    199204VI string import - block diagram constant imports but indicator doesn't respond
    199395Crash while loading VI with digital waveform graph
    199627Right-click Create New Variable on a VI under a cRIO target creates an Industrial variable
    199730LabVIEW Run-Time Engine crashes when multiple calls to LabVIEW built assembly are made
    199995Changing reentrant VI to non-reentrant crashes LabVIEW
    200234Diagram cleanup does not align controls and indicators
    200308Charts display gaps in waveform data that has a very small dt
    200361Moving a LabVIEW class in Project Explorer: Revert option doesn't work
    200535T Test.vi Outputs are switched - T Value & Sample T Value
    200660When the Connector Pane of a VI has been rotated, the icon editor doesn't represent it correctly when "Show Terminals" is selected.
    200679Project always opens with a dirty dot if it contains a class with system VIs.
    200743Calling semTake with small timeout value can return OK incorrectly
    200877LabVIEW crashes when running a VI that has .NET property & Invoke Nodes & unsaved changes
    201077Application builder silently coerces exported DLL prototypes to default
    201109Not a Number/Path/Refnum? does not work correctly in built executables
    201140Extracting or Unzipping LabVIEW built applications using Winrar or Winzip
    201365LabVIEW VI Performance and Memory Profiler appends to an existing file
    201851TCP Transfer Rates to and from Phar Lap Target Decrease over Time
    202029Disable Autodeploy Variables Still Pop Up a Dummy Deployment Dialog
    202187Indicator on Main VI does not update when updates are made in subVI with reference to indicator
    202428LabVIEW 2009 32-bit error log file: image.cpp line 13497
    202662About dialog box VI must reside in the same folder as your top-level VI
    203049Incorrect refnum type propagation allows parent data to end up on child wires
    203695Application VI server methods Get VI CPTM CRC and Get VI CPTM CRC Old are leaking file handles
    203818Invalid Client Error When Interop Assembly Used On Machine with Both LabVIEW 64-bit and 32-bit
    203996Pulse Measurements.vi should be able to measure pulse width without 3 transitions
    204222Parallel Unflatten from String and file write cause sporadic LabVIEW Memory full or Error 74
    204307Open Application Reference in reentrant VI crashes LabVIEW
    204329CVI 2009 & LabVIEW 64-bit type conflict in extcode.h
    204638Mixed Signal Graph loses graph plot properties when graph is cleared
    204936Local variable in subroutine VIs may misbehave.
    204973Various upgrade problems when using typedef of a LabVIEW class
    205665LLB distribution disappears from installer when Properties Window is closed
    205719Use of recursion slows loading VIs and editing of block diagram
    205735Set Permissions does not work the same in LabVIEW 2009
    206329Sound File Write Sample.vi can't write .wav file
    206464LabVIEW 2009 Crashes at Compile with Indicator on Decimate 1-D Array
    207187LabVIEW Crashes when connecting a fixed-point array into a For Loop
    207276Write Registry Value Simple.vi overwrites input errors with error -601
    207524Schur reorder returns incorrect Schur Form when there is complex pair
    207593Remote Debugging LabVIEW 8.6.1 and 2009 exe crashes LabVIEW development system
    207823LabVIEW compiler error on for loops with parallelism enabled
    208083Combination of Unit Labels, Compound Arithmetic, and Indexing an Array Cause Compile Error
    20824510x performance degradation in Config File VIs in LabVIEW 2009
    208323Waveform to variant to waveform 2x slower in LabVIEW 2009 versus 8.6
    208325Variant to a large cluster 4x slower from LabVIEW 8.6 to 2009
    208398Reference prevents graph properties from being saved.
    208625Error -805 can be more descriptive for string constants wired to a Timed Structure timing source
    208641Incorrect results when integer is wired to Complex to R-Theta primitive
    208669Could not load front panel error: Scale.cpp (2776)
    209106Loading VI loads class which claims to be in memory but really isn't
    209779Allow Debugging setting in subVI takes less time than without debugging enabled
    210033XControl Reference in lvclass causes broken VI in Run-Time Engine
    210256LabVIEW crashes when cleaning up a block diagram
    210394LabVIEW 2009 and/or LabVIEW 2009 Run-Time may not launch on older CPUs
    210539Formula node causes VI to fail when compiling
    210678Upgrading from LabVIEW 7.1 to 2009 breaks .NET references
    211011B-Spline Fit VI hangs with certain data sets
    211062Auto-indexing in LabVIEW 2009 and SP1 behaves as if the array is not empty when it is
    211619Error Pop-up when error terminal are connected when using Storage VIs
    211859Dynamic API Blocking Read Node doesn't unblock at the appropriate time
    212320Compile issues after upgrading to 2009 SP1: DesktopGenInfoVisitor.cpp
    212549For Loop Parallelism Benchmarking Discrepancy
    212844Get all Dependencies in [Express] VI crashes LabVIEW if the VI is not saved
    213311Indexed 2D Array with Build Array and Decimate Crashes LabVIEW
    215339LabVIEW .NET display the trace warning during callback sometimes
    215410Performance and Memory tool crashes with large project
    215714NI Service Locator is blocked by McAfee Host Intrusion Prevention v7.0
    216280Source File Settings UI allows user to remove from panel of Always Included VI in DLLs
    216911Exception thrown when LabVIEW 09 assembly method call returns a structure containing unsigned integers
    217220Using gg format in OS Date format preferences hangs LabVIEW
    218669LabVIEW 2009 32-bit error log file: ProjectAlias.cpp line 292
    218683LabVIEW 2009 SP1 Error Log: drawmgr2.cpp 131
    218929LabVIEW 2009 SP1 32-bit error log file: ProbeRunTime.cpp line 527
    218945Error 3: could not load front panel (scale.cpp line 2797)
    219452XML GraphAnnotations does not match data GraphAnnotations at item 0
    220778Format Into String doesn't coerce data properly in a case structure if the format string is outside the case structure
    220832Enabling Parallelism on For Loop crashes LabVIEW with NI-Sync Driver
    220887Calling LabVIEW 2009 built DLLs in previous versions of LabVIEW can cause a crash
    220935PFX Certificates will work only if it's installed in the Personal Store
    221909Search and Replace string crashes LabVIEW
    222064UTC Time option in TimeStamp Properties dialog box absent in 8.6 later
    222729Empty string in Title of Dialog Information does not show default title.
    224911Installer Build Specifications reset to default/empty settings when loading LabVIEW 2009 project
    227424Initialized Feedback Node in 2009 SP1 is Slower versus 8.6.1
    229372Conditional Disable Structure doesn't compile custom symbol value when Enable Debugging is turned on in the Build Spec
    229635Debugging LabVIEW Interop Assemblies does not work
    230451Custom Type Def Controls as the Data Type for a Shared Variable are not Bound to the .ctl.
    © 2004–2010 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    LabVIEW, National Instruments, NI, ni.com, LabVIEW, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2026-4-16 06:48
