查看: 2506|回复: 0
[RTE运行引擎] LabVIEW 2023 Q1 Runtime Engine Linux64Eng LabVIEW2023Q1运行版-64位Linux系统版-在线安装方式
    前天 16:03
     楼主| 发表于 2023-2-21 10:22:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2023 Q1 RTE(自2023Q1版开始,Linux系统的社区版、运行版等使用在线安装方式安装,请保证网络畅通,IP未被墙)
    发布日期:2023/2/7
    包含的版本:2023Q1运行版
    openSUSE
    RedHat
    Ubuntu
    Linux
    语言:英文
    程序位数:64位
    文件大小: 215679 字节 (210.62 KB)
    修改日期: 2023-02-10 09:53
    MD5: 998a111a0a8123d9637e9c5bc1cd6104(官方正确)
    SHA1: b5fd2e1919b37c5ab8e6554c5f6177f27218dc7b
    SHA256: 3193a0e589393ff3c4ce40020c53c8be9abc3aaeef9fd26f7c5a04c9874e8cee
    CRC32: 27ed4677
    注册登录视觉论坛会员,购买附件查看下载地址
    LV2023Q1Linux64RTE OL.txt (600 Bytes, 下载次数: 0, 售价: 2 圆)
    LabVIEW 2023 Q1 for Linux/x86 64-bit Architecture Readme
    January 2023
    This file contains installation instructions and compatibility information for LabVIEW 2023 Q1.
    Supported Drivers
    LabVIEW 2023 Q1 for Linux has the following requirements:
    Linux
    openSUSE Leap 15.3
    Red Hat Enterprise Linux 9
    Red Hat Enterprise Linux 8
    Ubuntu 22.04 LTS
    Ubuntu 20.04 LTS
    • LabVIEW 2023 Q1 for Linux is available only in 64-bit.
    Refer to Upgrading LabVIEW for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2023 Q1.
    LabVIEW 2023 Q1 for Linux supports the following modules and toolkits.
    • VI Analyzer Toolkit1
    • Application Builder1
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2023 Q1, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2023 Q1.
    GMT+8, 2026-2-25 01:10
