查看: 4358|回复: 0
[LV工具模块] NI Vision Development Module 2023 Q1 Win11 32/64bitEng 视觉开发模块VDM2023Q1 适用LabVIEW2023Q1
    昨天 16:03
     楼主| 发表于 2023-2-21 11:57:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    视觉开发模块提供了数百个用于开发和部署机器视觉应用程序的函数。
    视觉开发模块(VDM)旨在帮助您使用LabVIEW或C/C ++开发机器视觉应用程序,并将这些应用程序部署到Windows或NI Linux实时硬件。该模块提供了丰富的函数库,您可以访问数百个图像处理算法和机器视觉函数,以增强图像、检查对象是否存在、定位特征、识别对象、测量零件等等。VDM还包含视觉助手,该算法开发工具可帮助您开发用于在CPU或FPGA上部署的算法,以简化视觉系统设计。
    NI Vision Development Module 2020 SP2 VDM安装激活视频教程
    http://visionbbs.com/thread-27097-1-1.html
    NI Vision Development Module 2020安装教程及激活教程
    http://visionbbs.com/thread-23973-1-1.html
    视觉开发模块2023Q1Full
    发布日期:2023-2-3
    包含的版本:2023 Q1完整版,版本号23.0
    语言:英文
    文件大小: 4500684800 字节 (4.19 GB)
    修改日期: 2023-02-04 09:53
    MD5: b3a027f022f01f83f90d608de5d58e06(官方正确)
    SHA1: ee32a7d02481320ffd1f0b26dc769b3b3c53f7c7
    SHA256: 852d0cfcc5432da91251020293401e381800db5ca6e95f9f3d4993fe4c9c38b1
    CRC32: 02ead33a
    百度网盘和NI官方离线下载地址:
    请注册视觉论坛会员登录后购买附件下载查看
    VDM2023Q1.txt (595 Bytes, 下载次数: 12, 售价: 10 圆)
    VDM2023Q1官方懒得写更新说明,连个Readme都冇得。只找到一个修改Bug的记录。自述说明参考2022 Q3。NI Vision最近这两年几乎是没有更新。基本上就是升级一下适用当前新的LabVIEW版本。
    Bug Number
    Legacy ID
    Description
    Details
    2082989
    Unable to install NI VDM and NI-RFSA on a NI LinuxRT target simultaneously
    When trying to install both the NI Vision Development Module and NI-RFSA on a NI LinuxRT target with NI MAX or NISysCfg Install All, I am getting an error that states that ni-rfsa-daqmx-libs wants to install file libtbb but that file is already provided by the libnivision package.
    Workaround:
    Install the NI Vision Development Module first, and then install NI-RFSA. If using the NI System Configuration API, call Install All, clear the error thrown, and then call Install All again.
    Reported Version:
    Vision Development Module 2022 Q3
    Resolved Version:
    Added:
    N/A
    Vision Development Module 2022 Q3 Readme
    July 2022
    This file contains important information about Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    • Vision Development Module Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Vision Development Module Manuals: New features, behavior changes, and other documentation
    Deploying Vision Applications
    Documentation and Examples
    External Library Support
    The Vision Development Module (VDM) provides hundreds of image processing and machine vision functions. Along with programming libraries, the Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the Vision Development Module that are currently installed.
    Note: The Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the Vision Development Module.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision for the latest information about the Vision Development Module.
    Vision Development Module 2022 Q3 has the following requirements:
    • Pentium 4/M or equivalent processor
    • A screen resolution of 1,152 x 864 resolution video adapter with a 24- or 32-bit display (Vision Assistant)
    • A screen resolution of 1,024 x 768 video adapter with a 24- or 32-bit display (other environments)
    • At least 256 MB of memory
    Vision Development Module 2022 Q3 supports the following operating systems:
    The following table lists the NI application software versions, including service packs, supported by the Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the Vision Development Module.
    NI Application Software
    Versions Supported by Vision Development Module
    NI LabVIEW
    2019 and later
    NI LabVIEW Real-Time Module
    2019 and later
    NI LabVIEW Real-Time 64-Bit Module
    2021 64-bit and later
    NI LabVIEW FPGA Module
    2019 and later
    NI LabVIEW FPGA 64-Bit Module
    2020 64-bit and later
    NI LabWindows™/CVI™
    2017 and later
    Vision Development Module .NET Support
    Development and runtime support for .NET features are no longer included with Vision Development Module 2020 and later. Refer to GitHub page Vision Development Module for .NET for more information about open-source versions of Vision Development Module.
    Vision Development Module FPGA Support
    For more information and the complete list of Vision functions and hardware supported on FPGA, visit ni.com/info and enter the Info Code VisionFPGASupport.
    Download the Vision Development Module installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Vision Development Module. For more information on Vision Development Module activation, refer to Activating a Product.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The Vision Development Module provides the following options:
    • The ability to create NI Vision Runtime installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or custom applications.
    • One NI Vision Runtime License, which allows you to install a custom application on a single machine.
    The Vision Development Module installer provides the runtime installer for NI Vision that can be packaged for redistribution by LabVIEW, CVI, or the standalone NI Package Builder. Visit ni.com to download software upgrades for NI Vision and the NI Vision Runtime installers.
    Using the NI Vision Runtime
    You can install the NI Vision Runtime with your application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can directly include the NI Vision Runtime.
    You can use NI Package Builder to package your custom application installer along with the NI Vision Runtime installer. This may be useful if you are creating an installer for applications created in other development environments.
    The NI Vision Runtime installer may require the system to be restarted after installation. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    The NI Vision Runtime installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Runtime as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Runtime.
    In addition to including the NI Vision Runtime with the installer, you must include the appropriate LabWindows/CVI Runtime. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    • Added support for LabVIEW 2022 Q3
    • Added support for LabVIEW RT 64-bit
    • Added support for LabVIEW FPGA 64-bit
    Documentation and examples are installed onto your hard drive with the Vision Development Module. To view the documentation, select Start»National Instruments»Vision Documentation, or navigate to \Public\Public Documents\National Instruments\Vision\Documentation.
    Refer to the NI Product Documentation Center at ni.com/docs for the most recent versions of product documentation.
    The following sections describe the documents available for each application development environment and where to find examples.
    NI Vision for LabVIEW
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision and \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI
    • NI Vision C Support Help—Contains reference information about NI Vision C functions.
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the Vision Development Module.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at National Instruments\Shared\CVI\Bin\NIVision.lfp.
    • NI Vision LabWindows/CVI example programs are installed at \Public\Public Documents\National Instruments\CVI\samples\Vision.
    NI Vision for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application.
    • To view text-based example programs, select Start»National Instruments»Vision Examples, or navigate to \Public\Public Documents\National Instruments\Vision\Examples.
    NI Vision Assistant
    • To access Vision Assistant documentation from the Start menu, select Start»National Instruments»Vision Assistant Documentation, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Documentation.
    • To access Vision Assistant examples from the Start menu, select Start»National Instruments»Vision Assistant Examples, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Examples.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Flat Field Creation Wizard Help—Contains information about how to use the NI Flat Field Creation Wizard to create a dark or bright field image and perform flat field correction in a machine vision application. In the NI Vision Flat Field Creation Wizard, select Help»Online Help.
    Application Interface and Examples
    The NIEXTCCOMPILERSUPP environment variable is provided as an alias to the location of C language support files. You can use this variable when compiling and linking an application. The Application Interface files (header and library files to include in applications) are placed in a centralized location to prevent users from accidentally overwriting them and to provide this NIEXTCCOMPILERSUPP environment variable.
    Note: $(NIEXTCCOMPILERSUPP) is configured as an environment variable on the target system. The variable evaluates by default to \Program Files\National Instruments\shared\ExternalCompilerSupport\C.
    ItemInstalled Location
    header files<$(NIEXTCCOMPILERSUPP)>\include
    32-bit MSVC import libraries<$(NIEXTCCOMPILERSUPP)>\lib32\msvc
    64-bit MSVC import libraries<$(NIEXTCCOMPILERSUPP)>\lib64\msvc
    Vision Development Module no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    The Vision Development Module supports the external vision library OpenCV. Refer to the Developing Vision Applications using OpenCV and NI Vision to download the NI Vision OpenCV support utilities.
    NI Vision OpenCV support utilities enable the use of OpenCV algorithms in LabVIEW and NI Embedded hardware. NI Vision OpenCV support utilities provide:
    • Pre-built OpenCV binaries for Windows and NI Linux RT
    • C++ development files to create an interface between NI Vision Image and OpenCV Mat.
    • Utilities to create LabVIEW APIs to call OpenCV entry points.
    • LabVIEW examples.
    © 2003–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-24 23:48
