查看: 4462|回复: 1
[NI驱动程序] NI Vision Acquisition Software 2023 Q1 Win11 32/64bitEng 视觉采集软件VAS23.0版 适用LabVIEW2023Q1/VDM2023Q1
    昨天 16:03
     楼主| 发表于 2023-2-21 12:08:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    视觉采集软件属于驱动程序软件,用于采集、显示和保存各类相机的图像。NI视觉采集软件(VAS)使您能够采集、显示和保存各种行业标准相机(包括Gige Vision、USB3 Vision和Camera Link)的图像。您还可以使用此软件轻松地控制NI视觉硬件上的数字I/O。借助一套易于使用的函数和示例程序,您可以使用LabVIEW和C/C ++快速创建应用程序。VAS视觉采集软件不同于VA视觉助手(Vision Assistant),视觉助手是VDM视觉开发包中的辅助工具,没有单独的安装包,安装VDM时可选择视觉助手安装。
    视觉采集软件2023 Q1
    发布日期:23-2-3
    包含的版本:2023 Q1完整版,版本号23.0.0
    语言:英文
    文件大小: 2943420416 字节 (2.74 GB)
    修改日期: 2023-02-04 09:52
    MD5: 639802e562074ef63adb2f34fac4da76(官方正确)
    SHA1: 09535db1a660cf0249fa4a6c8f65343218d7c284
    SHA256: 6fec86babf93aac8a25e9aa7d9f7f810847cf40ae0fa158fa730f5bb3be622c8
    CRC32: b27c4397
    请注册登陆视觉论坛账号,购买附件查看下载地址
    VAS2023Q1.txt (606 Bytes, 下载次数: 18, 售价: 10 圆)
    没有什么实质更新,新功能仅升级对LabVIEW 2023 Q1的支持。
    Vision Acquisition Software 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for Vision Acquisition Software 2023 Q1.
    • Vision Acquisition Software Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Vision Acquisition Software Documentation: New features, behavior changes, and other documentation
    Vision Standards Support
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    Accessing the Documentation and Examples
    Vision Acquisition Software (VAS) allows you to acquire, display, and save images; control digital I/O on NI image acquisition devices; and configure your driver software and hardware.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/vision for the latest information about Vision Acquisition Software.
    Vision Acquisition Software includes the following drivers:
    • NI-IMAQ is driver software for Camera Link cameras.
    • NI-IMAQdx is driver software for the following device types:
      • Camera Link cameras in Windows using supported frame grabbers:
        • PCIe-1427
        • PCIe-1433
        • PCIe-1437
        • PXIe-1435
      • ISC-178x smart cameras
      • GigE Vision-compliant cameras
      • USB3 Vision-compliant cameras
      • DirectShow-compatible cameras (Windows), UVC-compliant webcams (Linux RT)
    • NI-IMAQ I/O Driver Software that helps you program reconfigurable frame grabbers with LabVIEW FPGA and helps you program DIO without LabVIEW FPGA for Compact Vision Systems, Industrial Controllers, and other PCIe-based devices using the Vision RIO API.
      • Reconfigurable Frame Grabbers (requires LabVIEW FPGA):
        • PCIe-1473
        • PCIe-1477
        • NI 1483 FlexRIO Adapter Module
      • Devices supporting the Vision RIO API:
        • CVS-1458
        • CVS-1458RT
        • CVS-1459
        • CVS-1459RT
        • IC-3120
        • IC-3121
        • IC-3171
        • IC-3172
        • IC-3173
        • PCIe-8237
        • PXIe-8246
      • Note  LabVIEW FPGA can optionally be used to reconfigure the FPGA on Vision RIO devices, but only DIO functions are available for external connections.
    • Note  New versions of Vision Acquisition Software no longer support the following hardware:
      • NI 17xx and NI 177x Smart Cameras
      • NI EVS-1463, -1463RT, -1464, and -1464RT Embedded Vision Systems
      • NI CVS-1454, -1455, -1456, and -1457RT Compact Vision Systems
      • Analog cameras
      • Parallel digital cameras
      • Basler and Axis IP cameras
    • Note  New versions of Vision Acquisition Software no longer support the following real-time operating systems:
      • VxWorks
      • Phar Lap ETS
    Additional Driver Software Requirements
    Some hardware requires driver software in addition to Vision Acquisition Software drivers. Refer to the NI website at ni.com/drivers for information about these drivers.
    • The NI PCIe-1473R and NI PCIe-1473R-LX110 require NI FlexRIO software to access the DRAM resources in a LabVIEW FPGA project.
    • The NI 1483 FlexRIO Adapter Module requires NI FlexRIO software.
    • The IC-312x and IC-317x industrial controllers require NI Industrial Controller Device Drivers to access FPGA resources and to discover remote real-time targets in NI Meaurement & Automation Explorer (MAX).
    Vision Acquisition Software 2023 Q1 has the following requirements:
    • 1 GHz or faster 64-bit (x64) processor
    • At least 512 MB of memory
    Vision Acquisition Software 2023 Q1 supports the following operating systems:
    Note  Vision Acquisition Software no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Vision Acquisition Software 2023 Q1 supports the following application software versions, including service packs.
    Note  The following table lists the NI application software versions, including service packs, supported by Vision Acquisition Software. The installer specifically allows side-by-side installations of Vision Acquisition Software for each of the supported versions of LabVIEW, enabling you to use Vision Acquisition Software with multiple versions of LabVIEW. NI recommends that you install LabVIEW, LabVIEW Real-Time, and any other supported development environment before installing Vision Acquisition Software.
    NI Application Software
    Versions Supported by Vision Acquisition Software
    NI LabVIEW
    2020 and later
    NI LabVIEW Real-Time Module
    2020 and later
    NI LabVIEW Real-Time 64-Bit Module
    2021 64-bit and later
    NI LabVIEW FPGA Module
    2020 and later
    NI LabVIEW FPGA 64-Bit Module
    2020 64-bit and later
    NI LabWindows™/CVI™1
    2019 and later
    Vision Development Module
    7.1 and later
    NI Vision Builder for Automated Inspection
    2.5 and later
    1 NI-IMAQ I/O is not supported in NI LabWindows™/CVI™.
    Vision Acquisition Software .NET Support
    Development and runtime support for .NET driver features are no longer included as of Vision Acquisition Software 19.0 and later. Refer to GitHub page NI IMAQdx for .NET for more information about open-source versions of NI-IMAQdx.
    The following table lists the machine vision and imaging standards supported by Vision Acquisition Software.
    Machine Vision or Imaging Standard
    Version Supported by Vision Acquisition Software
    Camera Link®
    2.1
    GenICam™
    3.3
    GigE Vision®
    2.0 (Selected features)
    USB3 Vision®
    1.0.1
    Download the Vision Acquisition Software installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "Vision Acquisition Software Support for LabVIEW" package supports applications using Vision Acquisition Software ​with LabVIEW minimum supported version or later. When installing Vision Acquisition Software, this package will be recommended if you have already installed LabVIEW minimum supported version or later and installs to the LVAddons directory.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ.
    • Run NI MAX.
      • Double-click the NI MAX icon on the desktop. You can use NI MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces to display a list of the image acquisition devices installed on your computer.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with NI MAX.
    Configuring a Remote PXI/Compact PCIe Image Acquisition Device
    Beginning with Vision Acquisition Software 19.0, NI-IMAQ Real-Time is not included for installation. However, you can still interact with remote real-time targets that have been set up using previous versions of NI-IMAQ and are running currently supported versions of LabVIEW Real-Time.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the NI MAX help window to install software.
    • Launch NI MAX.
    • Expand NI-IMAQ Devices.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the NI MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to configure NI-IMAQdx.
    If you are using a USB webcam or other DirectShow-compatible camera, ensure that the camera driver is installed and functioning. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    Instructions for configuring an USB3 Vision, GigE Vision, or IP camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    • Install the NIC.
    • Choose Browse my computer for driver software.
    • Browse to the driver location. The newest driver version is installed to \NI-IMAQdx\Staging\NI GigE Vision.
    • Click Next.
    • Click Close.
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps.
    Complete the following steps to configure NI-IMAQdx for Windows.
    • Connect the camera.
    • Run NI MAX.
      • Double-click the NI MAX icon on your desktop. You can use NI MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • For USB3 Vision cameras, NI-IMAQdx may not be associated with the camera if a third-party driver is installed. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
    Configuring NI-IMAQdx for the LabVIEW Real-Time Module
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx.
    • Run NI MAX.
      • Configure your network settings. Refer to the Remote Systems Help in NI MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the Real-Time target, using one of the following options:
      • Click Add/Remove Software on the NI MAX toolbar to launch the LabVIEW Real-Time Software Wizard.
      • Follow the instructions in the LabVIEW Real-Time Software Wizard to install NI-IMAQdx support for the RT target. It will reboot after installation is complete.
    • Press to refresh the NI MAX configuration tree. Your camera should be listed in the Remote Systems list.
    • Added support for LabVIEW 2023 Q1 and later
    Documentation and examples are installed onto your hard drive with Vision Acquisition Software. To view the documentation, select Start»National Instruments»Vision Documentation. Some application-specific documents are installed to the application help folder, as listed in the following sections.
    Refer to the NI Product Documentation Center at ni.com/docs for the most recent versions of product documentation.
    Vision Acquisition Software Documentation for NI MAX
    • You can access the Measurement & Automation Explorer Help for NI-IMAQ and the Measurement & Automation Explorer Help for NI-IMAQdx from the NI MAX Help menu by selecting Help»Help Topics»NI Vision. These documents are installed to \MAX\Help.
    Vision Acquisition Software Documentation for LabVIEW
    • You can access the NI-IMAQ VI Reference Help, NI-IMAQdx VI Reference Help, and NI Vision-RIO VI Reference Help from the LabVIEW Help menu.
    • NI Example Finder—Illustrates common applications you can create with Vision Acquisition Software. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. Vision Acquisition Software examples for LabVIEW are installed to \examples\Vision Acquisition, where is the location LabVIEW is installed. The examples for NI 1483 are installed to \examples\FlexRIO\IO Modules\NI 1483.
    Vision Acquisition Software Documentation for LabWindows/CVI
    • NI-IMAQ Function Reference Help—Contains reference information about NI-IMAQ functions for LabWindows/CVI.
    • NI-IMAQdx Function Reference Help—Contains reference information about NI-IMAQdx functions for LabWindows/CVI.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each function to access help for that function, control, function class, and function library. The niimaq.fp, NIIMAQdx.fp, and imaqio.fp function panels are installed to \CVI\Bin.
    • Example programs are installed to
      • \Public\Documents\National Instruments\CVI\samples
    Vision Acquisition Software for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application. This document is installed to \Vision\Help.
    • To view text-based example programs, select Start»National Instruments»Vision»Examples, and then select the driver you want to see examples for. You can also navigate to \Public\Public Documents\National Instruments.
    Vision Acquisition Software no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 1996–2023 National Instruments Corporation. All rights reserved.
    发表于 2024-1-29 15:03:51 | 显示全部楼层 来自:台湾省新竹市 中华电信
    GMT+8, 2026-2-24 20:52
