查看: 2399|回复: 0
[LV工具模块] LabVIEW 2023 Q1 Datalogging and Supervisory Control Module Win11 32bitEng LabVIEW2023Q1数据记录与监控模块DSC23.1
    4 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2023-3-16 10:15:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    LabVIEW 2023 Q1数据记录与监控模块23.1
    发布日期:2023/2/26
    包含的版本:2023 Q1完整版/运行版,版本号23.1.0
    应用程序位数:32位(DSC到目前为止,仅有32位版本,64位LabVIEW下无此模块)
    Full完整版
    文件大小: 1142953984 字节 (1.06 GB)
    修改日期: 2023-02-07 21:52
    MD5: 2b7a941c3e7fbdeb29a36f4786220485
    SHA1: 0e9a7ea319a0f2ec7bfdea04559986b2283570be
    SHA256: 56ee8f6668d97432e9797ea605c7601a87f1973e275f12ceb9788240d237d210
    CRC32: e421b605
    请注册登录视觉论坛会员,购买附件查看下载地址
    DSC2023Q1.txt (632 Bytes, 下载次数: 4, 售价: 10 圆)
    RunTime运行版
    文件大小: 1068554240 字节 (1019.05 MB)
    MD5: 2a0cb117ffd92e7653db96445c4572fd
    SHA1: beb6f39574c669d29ae8b942b3f12bc3962079ea
    SHA256: 7e3b0f90a1eee05c7c7b513457945729d41a78502bef4f259a232a2289c38b2c
    CRC32: d6dbadc3
    DSC2023Q1RTE.txt (679 Bytes, 下载次数: 0, 售价: 5 圆)
    DSC2022Q3/2023Q1均未更新自述文件,参考2021版本
    LabVIEW 2021 Datalogging and Supervisory Control Runtime Readme
    July 2021
    This file contains installation instructions and compatibility information for LabVIEW Datalogging and Supervisory Control (DSC) Runtime.
    • Manuals: New features, behavior changes, and other documentation
    The LabVIEW DSC Runtime allows you to run applications built with LabVIEW, the DSC Module, and the LabVIEW Application Builder on a computer without the DSC Module installed. The DSC Runtime contains components that enable the DSC Module features in the built applications.
    The DSC Runtime has the following requirements:
    • Depending on the components you choose to install, the computer must have the following amount of free disk space:
      • 1.0 GB free disk space if you install all components of the DSC Runtime except the Shared Variable Logging Support component
      • 2.5 GB free disk space if you install all components of the DSC Runtime
    • At least 512 MB of RAM
    The DSC Runtime supports the following operating systems:
    • Windows 10 (version 1909)
    NI installs the DSC Runtime using NI Package Manager. If you do not already have NI software installed, the DSC Runtime installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the DSC Runtime by using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Note  The NI OPC Servers application installed with the DSC Runtime provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    SQL Server Support
    The LabVIEW 2021 DSC Module requires Microsoft SQL Server 2012 Service Pack 4 (SP4) Express. This component is installed by default when you install the DSC Module.
    To install the LabVIEW 2020 DSC Module on a machine that has a previous version of the DSC Module installed, you need to upgrade the Microsoft SQL Server version from 2008 R2 to 2012 SP4 Express. Because upgrading the Microsoft SQL Server affects the Citadel database, you must backup your Citadel data before upgrading. Refer to the Archiving Citadel Data topic in the LabVIEW Help for detailed information about archiving the Citadel database.
    The Advanced Signal Processing Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2000–2021 National Instruments Corporation. All rights reserved.
    375311H-01
    GMT+8, 2025-12-5 13:11
