查看: 1826|回复: 0
[NI软件产品] NI IP to FPGA Conversion Utility 2023 Q1 Win11 64bitEng IP至FPGA转换工具23.0
    前天 16:03
     楼主| 发表于 2023-3-16 15:02:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    IP至FPGA转换工具可帮助您将自定义算法导出为FPGA比特文件,以便在包含板载FPGA的NI硬件上进行部署。
    IP至FPGA转换工具是一个软件实用程序,可用于将自定义算法和知识产(IP)核导出为FPGA比特文件。您可以使用导出的比特文件将Mathworks Simulink中创建的自定义算法或IP部署到硬件FPGA。该工具支持转换HDL兼容的Simulink模型。Simulink是The MathWorks, Inc.的注册商标。
    发布日期:2023/2/3
    包含的版本:2023 Q1完整版,版本号23.0.0
    应用程序位数:64位(官网上写的程序位数是64位,但是在自述文件中则写着兼容32位的LabVIEW、LV FPGA模块、R系列多功能RIO,看安装包里的内容,大概率是64位的,自述文件中可能是错的,具体版本还请确认清楚。不过该程序也只有这一个版本,如果不兼容相应的位数,只能改其它的LV、FPGA环境。)
    文件大小: 444356608 字节 (423.77 MB)
    修改日期: 2023-02-04 09:51
    MD5: a6776e61d930aa5ae3c6a727bfe9aef9
    SHA1: a0fb5cb040df28760c1582a7ec6f72a6bed853c6
    SHA256: dfede1e5d1ae22822187805809bdec787cbed987c22c221fde736ee982a70183
    CRC32: 92f72c7e
    请注册登录视觉论坛,购买附件查看下载地址
    IP至FPGA转换工具2023Q1.txt (604 Bytes, 下载次数: 0, 售价: 10 圆)
    IP to FPGA Conversion Utility 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for IP to FPGA Conversion Utility 2023 Q1.
    • IP to FPGA Conversion Utility Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Use the IP to FPGA Conversion Utility to export custom algorithms and intellectual property cores (IPs) as FPGA bitfiles. Exporting to bitfiles allows you to deploy custom algorithms to NI FPGA hardware. This utility supports the conversion of HDL Compatible MathWorks Simulink® models.
    IP to FPGA Conversion Utility 2023 Q1 has the following requirements:
    Version
    Bitness
    LabVIEW Full or Professional Development Systems2019, 2020, 202132-bit
    LabVIEW FPGA Module2019, 2020, 202132-bit
    NI R Series Multifunction RIO with LabVIEW 2019/2020/2021 Support2022 Q432-bit
    Refer to the LabVIEW Readme, LabVIEW FPGA Module Readme, and NI R Series Multifunction RIO Readme for additional system requirements and supported operating systems.
    IP to FPGA Conversion Utility 2023 Q1 supports the following operating systems:
    Note  IP to FPGA Conversion Utility no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Download the IP to FPGA Conversion Utility installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Expanded hardware support. For more information, refer to Supported Hardware.
    The IP to FPGA Conversion Utility 2023 Q1 supports the following NI FPGA hardware:
    • PXIe-7820R
    • PXIe-7821R
    • PXIe-7822R
    • PXIe-7846R
    • PXIe-7847R
    • PXIe-7856R
    • PXIe-7857R
    • PXIe-7858R
    • PXIe-7861
    • PXIe-7862
    • PXIe-7865
    • PXIe-7866
    • PXIe-7867R
    • PXIe-7868R
    To access help for the the IP to FPGA Conversion Utility, open the command line and enter ip2fpgaCLI –help. For more information on using the utility, refer to the supplemental documentation.
    IP to FPGA Conversion Utility no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2022–2023 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-25 02:41
