查看: 1529|回复: 0
[NI软件套件] NI Test Workflow 2023 Q1 Standard Win11 32bitEng NI测试工作流程23.0标准版-32位英文
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2023-3-17 09:02:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    测试工作流程是NI推荐的软件集合,适用于研究、验证和生产测试应用程序的工程师。
    测试工作流程为工程师提供了针对特定应用的工具,从图形化编程环境到无代码和交互式软件应用程序,从而为其选择合适的工具。工程师可以使用测试工作流软件来执行快速特定测试、构建自动化测试系统、自动化数据分析和报告、开发测试序列等。
    标准版包含:
    应用程序软件
    LabVIEW完整版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem高级版
    发布日期:2023/2/7
    包含的版本:2023 Q1完整版/标准版 版本号23.0.0
    语言:英文English
    应用程序位数:32位
    文件大小: 2671403008 字节 (2.49 GB)
    修改日期: 2023-02-08 09:53
    MD5: ff8cbf1a6065da4c07affe5d01b5d245
    SHA1: 0d4bbc2497db32311f7cb14c1ceaeae8d9856a0c
    SHA256: 22722f3a04c28cd8e247dad83f998a19d9d9f699600132e72e3d716cbba86e17
    CRC32: 8ce0537b
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    TestWorkflow2023Q1Standardx86Eng.txt (634 Bytes, 下载次数: 0, 售价: 20 圆)
    Test Workflow 2023 Q1 Standard Readme
    January 2023
    This file contains installation instructions and compatibility information for Test Workflow 2023 Q1 Standard.
    • Test Workflow Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Test Workflow Standard Bundle
    Test Workflow 2023 Q1 Standard supports the following operating systems:
    The following products are included in the Test Workflow Standard installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    DIAdem2022 Q464-bit
    G Web Development Software2022 Q364-bit
    LabVIEW2023 Q132-bit and 64-bit
    FlexLogger12023 Q164-bit
    InstrumentStudio2023 Q164-bit
    1FlexLogger 2023 Q1 does not support 2023 Q1 NI driver software.
    If you are using the Test Workflow .NET Class Library, .NET Framework 4.0 (minimum) is required. The Test Workflow 2023 Q1 Standard .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Test Workflow installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow. For more information on Test Workflow activation, refer to Activating a Product.
    Refer to the readme of each product for where to find examples.
    Test Workflow no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-5 14:10
